Toyota Dealer in Monroe Mi sucks
Discussion in 'Prius c Main Forum' started by xerox6135, Apr 9, 2013.
  1. xerox6135
    xerox6135 Member
    170
    93
    michigan
    I took my C in for 15,000 mile service tire rotation. Also stated the fuel gauge never goes to full anymore and I had a vibration in the front end. I got the car back (which I marked the tires) and you guess it they did not do anything and yes the paper work stated they did ,was told they had no idea what was wrong with fuel gauge and all of the prius c had a vibration in front end. So they claimed they open a case with Toyota to see if anyone else was having this problem. Wow if this is what owning a Toyota is all about I have owned my first last and only man what a disappointment Elite Toyota in Monroe Michigan shame on you .
    49,509
    agreed, i would be very disappointed if my car exhibited those problems and the dealer couldn't do anything. i hope you get a satisfying response from toyota, they are usually very good.
  3. B2FiNiTY
    B2FiNiTY Active Member
    979
    226
    Try another dealer
    ztanos likes this.
  4. DKTVAV
    DKTVAV Active Member
    510
    101
    I got the same thing for my first 5000 miles service in Huntington Beach, Orange County CA. My next service is closed and don't know which one to trust.
    As I mentioned before on my other thread we should have a sticky for the trusted dealers around so members here can benefit from it.
  5. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    Sometimes it can be hard to find a trustworthy dealer. They aren't required to do anything above and beyond "in the name of Toyota." They are only required to pretend that they did it and then take your money. Stealerships are independent of Manufacturers, but this is the way across the board.
  6. RocMills
    RocMills Active Member
    789
    276
    Las Vegas, Nevada
    All Cs have a vibration in the front end? Mine must be defective, it does not vibrate in any way.
    carolD and CMJAnew like this.
  7. boppo
    boppo Active Member
    799
    138
    Owego, NY
    RocMills.
    I would not drive it until u get a stealer to look at it. Lol
    RocMills and ztanos like this.
  8. vernon birdman
    vernon birdman Active Member
    330
    141
    Vernon BC Canada
    I guess that the Canadian C's are defective too. No vibrations here except the good vibrations
    RocMills, ztanos and citroenjohn like this.
  9. citroenjohn
    citroenjohn Active Member
    139
    103
    Mid-Michigan
    I'd talk to the dealer management and then Toyota if need be. No pun intended, but, the squeaky wheel gets the attention. When you bought the car you were to receive certain maintenance for free as part of the price. You didn't (tire rotation); and someone in the chain of command would surely like to know. My MI C2 also does not have the optional front end vibration and I'm quite happy without it.
    RocMills likes this.
  10. xerox6135
    xerox6135 Member
    170
    93
    michigan
    Took the C to Jim White Toyota and they found problem with fuel gauge the fuel gauge board is bad Toyota is having a lot of problems with 1st gen Prius c fuel gauges most fail showing a 1/4 tank when really tank is empty so I am lucky. Front end vibration tires out of balance. I will always use Jim White Toyota for service great place
    carolD likes this.
  11. vernon birdman
    330
    141
    Vernon BC Canada
    Interesting about the gas gauge. I will look into this on my next visit to my dealer. Mine hasn't shown a full tank since about the sixth fill up.
  12. maddog61
    maddog61 Junior Member
    44
    No front vibrations either....I have original tires on alloys and winter tires on steel rims. The summers tires were just rotated and still smooth sailing. Fuel gauge still working . Sounds like u may have lost a weight on one wheel ,also Toyota rims can be hard to balance.........
