Toyota dealership says semi-synthetic oil....?
Discussion in 'Gen 3 Prius Main Forum' started by rfcviper, Nov 23, 2013.
  1. rfcviper
    rfcviper New Member
    Hey Everyone,
    My local salesperson says the dealership uses semi-synthetic oil. I am sure it is supposed to be 0W20 motor oil and I wasn't aware you could get that in anything besides synthetic. I'm hoping he was wrong and misinformed and they use synthetic. If not, I may just take my Mobil 1 0W20 to them and have them use that instead....
  2. DavidA
    2,328
    1,812
    Chicago western burbs
    Maybe he is using semi-knowledge or maybe the dealership is using the stuff they buy in 50-gallon barrels which could be anything. AFAIK, 0W20 is synthetic, and that's what's best for the engine to go 10K miles before the next scheduled oil service.
    I bring a 5-QT MobilOne container and tell them to use that in my car. I am really hoping that is what they have used.
  3. rfcviper
    rfcviper New Member
    Thanks. That is exactly what I thought. I only use Mobil 1 in my vehicles and I sure hope they change my oil using synthetic. If that is what is recommended, that is what they should be using.
  4. El Dobro
    El Dobro A Member
    6,979
    3,214
    You can get 0w-20 in a synthetic blend.
  5. bisco
    49,490
    i would expect all the dealership's to use toyota approved lubricant's. but that may be expecting too much.:cool:
  6. tristan91
    tristan91 New Member
    By "semi-synthetic" does he mean they are using a synth-dino blend, or a "fake" synthetic (e.g. Group III) oil?
    Is Mobil 1 still made from Group IV?
  7. El Dobro
    El Dobro A Member
    6,979
    3,214
  8. Mendel Leisk
    38,726
    First off, if it's 0W20, it likely (if not conclusively) is synthetic. Still, my take: if it's "0W20", and a quality oil, that's all that matters.
  9. DavidA
    2,328
    1,812
    Would the dealership care/dare to show you the oil they're filling your car with, if you ask nicely? If they can't prove it, or won't show you, then bring your own oil.
  10. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    If you can't trust them to use what they say they are using, go somewhere else.
