Toyota fielder hybrid
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Muhammad hameed, Jan 4, 2016.
  1. Muhammad hameed
    Muhammad hameed New Member
    Lahore pakistan
    Someone please help the vehicle slip indicator light is on permanently, the other brake lights such as the abs are all fine, what could have had caused the problem and what should be done. Please reply asap
  2. roamerr
    roamerr Member
    135
    43
    Winston-Salem, NC
    Severe out of alignment or one of the wheel sensors being out will do it.
    iPhone ?
  3. valde3
    valde3 Senior Member
    2,002
    751
    Finland
    If all 4 tyres are same size and there’s nothing obvious wrong then you should read the codes to find what’s wrong. If you want to read the codes yourself get Mini-VCI.
  4. Muhammad hameed
    Lahore pakistan
    Could you please guide me with this code reading process please, plus the air pressure is 30 psi is that enough, and the alignment is fine I guess i will get it checked though
  5. Muhammad hameed
    Lahore pakistan
    Is there a solution if there is a problem in the sensor, and is this a very pertinent issue?
  6. Muhammad hameed
    Lahore pakistan
    This is the light please reply asap
  7. valde3
    2,002
    751
    Finland
    Do you have the mini-VCI? It’s pretty easy to use so you shouldn’t need instructions. Light just tells you that you have some problem codes will tell you what it is. Are all 4 tyres the same size?
  8. Muhammad hameed
    Lahore pakistan
    Yes they are the same size and what should be the air pressure? Plus I don't have the mini vci, how does it detecte the error code
  9. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    Hey, since when do Prius have tachs?
