Toyota hybrid battery-No longer available-Coud be permanent
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Sep 5, 2022.
  1. Isaac Zachary
    Isaac Zachary Senior Member
    2,541
    1,283
    51,896
    right. unavailable and discontinued are not the same word
    Isaac Zachary likes this.
  3. ChapmanF
    18,147
    I'm pretty sure the Toyota parts site says "no longer available" in those cases, which is a kind of unfortunate choice of words if what they mean is "not available right at the moment".
    51,896
    if that's the case, what will they do for 10 year warranty?
  5. fuzzy1
    10,433
    They'd probably be forced to buy back the vehicles that they can't fix under warranty.
    Prematurely ending support life for out-of-warranty product, before other units are out of warranty, may also have legal repercussions.
  6. Isaac Zachary
    2,541
    1,283
    The same modules for Gen 2 and 3 Prii are available in other batteries that are still available, such as Avalon hybrid, Gen 4, Camry hybrid, Sienna hybrid, etc. If the car is under warranty Toyota has the modules for the car and most likely still has enough for warranty work.
    It's the people who are out of warranty that may not be able to get a hybrid battery for their Toyota, at least not from Toyota.
  7. ttou68
    ttou68 Active Member
    351
    211
    Automotive manufacturers are required to supplying parts for any production vehicle model for 10 years after model end date....
    Mendel Leisk and Isaac Zachary like this.
  8. Isaac Zachary
    2,541
    1,283
    Mine will be 10 years old next year. :unsure:
  9. Elektroingenieur
    2,515
    3,283
    Three Touring
    I think this may be a myth; see my previous posting. I’d be glad to be proven wrong, however.
  10. pasadena_commut
    pasadena_commut Senior Member
    2,615
    771
    Southern California
    I called a local dealer and they had a G951047031 in stock (for $3140), even though parts.toyota.com at the same time shows "This Product Is No Longer Available" for the same part. So I asked the parts guy if it had been discontinued, and he said that as far as he knew there were just supply chain issues. He said that he had put in orders before when these were out of stock, which came up "back ordered", and eventually those orders were filled. He just had no idea if that would happen in a day or 6 months. Sounds a lot like the situation with the catalytic converters a year or so ago.
    Moving Right Along, bisco and Zythryn like this.
  11. tracy ing
    tracy ing Active Member
    384
    173
    wash dc
    They are not required to provide any parts whatsoever for any amount of time, the only issue is anything covered under a warranty, and even then, there is no rule or law the parts must be available, they could sell a car, provide a warranty, and know full well prior to sale that a part is going to fail, and that part is impossible to procure, ever. In this instance they have to provide as refund on the car, if the part fails in the warranty period and the part is covered under the warranty.
    Magnum Moss 1975
    If you can prove otherwise, post the federal or state law, I wont hold my breath.
    The ONLY exception is emissions equipment under EPA, there is a 2 and 8 year rule for those devices, and only those devices.
  12. tracy ing
    384
    173
    wash dc
    Discontinued
    Discontinued
    No Longer Available
    No Longer Available
    This Product Is No Longer Available If this product has been replaced, supersession information will appear above
    When I hit the largest toyota dealers in the usa, pretty clear, these are done and not coming back, not with this part number.
    Two years from now, the 2004 officially becomes eligible for antique tags and no more safety inspection, in Virginia
    #32 tracy ing, Sep 10, 2022
  13. bisco
    51,896
    if that is the case, it's no big deal. plenty of aftermarket options, once the supply chain is up and running
  14. pasadena_commut
    2,615
    771
    Southern California
    Not so fast. I've been down this road before with a Honda IMA pack. Just because somebody sells an aftermarket option doesn't mean that it is any good. The reliability of Honda's original sticks was mediocre (compared to the Prius prismatic cell batteries), but the replacement Chinese sticks were somehow even worse. Both the New Prius Battery stick NiMH pack and the NexPower lithium iron phosphate pack have only been around for a short time. I hope both products are reliable and last a long time in normal use, but at this point we cannot rule out the possibility that they might only be good for 4 to 5 years.
  15. bisco
    51,896
    still, for out of warranty cars, there are plenty of options. and don't assume the only longevity testing is actual years in a car. mfg's do plenty of it before mass production.
  16. Isaac Zachary
    2,541
    1,283
    Like play whack-a-mole?
    The hope-it-dies-in-11-months-not-13 "referbished" battery?
    Trade it for a bicycle?
  17. bisco
    51,896
    there are at least three aftermarket options with new cells, and some refurbished are legit like a few members here sell.
    and grid charge reconditioning is sometimes an option
    #37 bisco, Sep 12, 2022
  18. Isaac Zachary
    2,541
    1,283
    That could be. All I know is I've never had any luck with anything refurbished or aftermarket. Not saying that batteries can't be good, but I've been down that path of taking the OEM part that lasted 20 years, getting a "high quality" brand new aftermarket part, and a week later it doesn't work, send it back, get another one, week later, send it back, breaks in a week, I sends it back, it breaks again... and so on and so forth until I'm too fed up to even try again.
    NewPriusBatteries seems good.
    Project Lithium has my attention.
    I don't know who does the legit refurbished batteries, although one that takes newer wrecked Toyotas and salvages the cells would have my attention too.
    But I'm still tempted to just scrap my Prius and keep packing the Avalon with 8 people when I need to go places with 8 people. Of course it does have other problems besides just needing an HV battery, so I really shouldn't complain.
  19. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    The GreenTec refurbished with new cells is a good battery. I’ve had one of their batteries in a Camry for about four years. Good as new. Prices have increased of late, currently $2250. Lower priced options with reused cells, but I wouldn’t recommend those. Nationwide, many installation and service locations.
    Shop | Greentec Auto
  20. jdenenberg
    jdenenberg EE Professor
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    All AWDe Prii are still using new NiMh batteries so you can buy a new Gen4 NiMh battery from Toyota for many years and the Gen4 modules will fit into your Gen2 or Gen3 batteries. Just don't ask for a new Toyota Gen2 replacement battery.
    JeffD
    ColoradoCrow and Prius Rising like this.
