Toyota-Leviton Charger Install
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by ppimd, May 1, 2012.
  1. Rebound
    Rebound Senior Member
    3,673
    2,241
    Portland, OR
    It's a very interesting question, but I don't think your test proves that the EVSE serves as a 12V "battery tender." For one thing, once charging competes, it appears that everything shuts off, and if so, any 12V charging would stop. So if, for example, you go on a trip and leave your PiP plugged in, I'm not convinced that the 12V battery would be charged. I would love to learn if this were true, it would be fantastic!
  2. Rebound
    3,673
    2,241
    Portland, OR
    Here's the math:
    4 watts x 730 hours / 1,000 = 2.92 kWh/month.
    At ten cents per kWh, leaving the charger always connected will cost 29.2 cents per month. Of course, you plug it in 3 hours per day anyway, so the incremental cost would be closer to 25 cents per month.
  3. mrbigh
    3,686
    684
    Long Island, NY
    The 12v auxiliary battery will recharge by the main DC-DC converter while running. It is not another way.
  4. ronlprius2
    ronlprius2 Junior Member
    55
    San Francisco
  5. Rebound
    3,673
    2,241
    Portland, OR
    I don't understand if you're answering my question. Does the HV battery maintain the 12V battery charge when the EVSE is plugged in? I know it charges the 12v when the car is in Ready mode, but I don't know what happens during charging.
  6. fjpod
    fjpod Member
    419
    71
    New York
    Except I pay 25 cents per kwh.
  7. seek
    seek Junior Member
    32
    Tewksbury, MA
    I suspect that people that quote a very low rate don't add up all the lines that are then multiplied by the kwh used (ie. taxes, renewable energy, fuel surcharge, etc.)
  8. Allannde
    Allannde Just a Senior
    874
    138
    Washington State
    Rebound
    My later checking confirms what you said. When the EVSE charging stops any charging of the 12v battery stops. Then I plugged in my battery tender and when it said my 12v battery was full, it tested at 12.6v! There definitely is some charging of the 12v battery with the EVSE, but not enough to trash the Battery Tender. To be fair, there was a dome light and perhaps some other draw on the battery at the time which would have depressed the reading.
    Allan
  9. cwerdna
    cwerdna Senior Member
    12,539
    2,104
    SF Bay Area, CA
    It'd be interesting to see the electric rate schedule for your area and to know your monthly usage vs. whatever baseline you're allocated.
    Possibly, but here are two really cheap areas:
    2011 Rates
    Seattle City Light: Electric Rates & Provisions
Loading...
