Toyota oil burn theory
Discussion in 'Fred's House of Pancakes' started by Isaac Zachary, Feb 7, 2021.
  1. Isaac Zachary
    Isaac Zachary Senior Member
    2,779
    1,501
    It must have been the turbo version. My non-turbo got up to 50mpg on the highway (one time I even measured nearly 60mpg) but it also had the acceleration of a freight train, especially here at altitudes of 5,000-12,000 feet above sea level. I even got pulled over once going up a steep hill at 8,000ft above sea level with the car fully loaded. The speed limit was 50mph and I was going 25-30mph. The officer was concerned there was something mechanically wrong with the car seeing how it was also billowing out black smoke.
    But the car just would never die. I had more problems with door handles and CV joints than anything else. The only two things that happened to the engine was it blew an injector line once, and a fuel line once got loose and rubbed a hole through itself. This was the cheapest car to own and operate I've ever owned.
  2. Trollbait
    12,831
    I've used a flush once, but down know if I actually needed it. Many treatments were likely cancelled because they contained something nasty that you wouldn't want to be near if you knew. Kerosene can work as a flush if someone wants to try it.
  3. Isaac Zachary
    2,779
    1,501
    I forgot to mention several other high mileage older vehicles with original, non-rebuilt engines that do not burn oil. My grandfathers mid-80's Honda Accord with some 400,000 miles, our Ford Aerostar with over 300,000 miles, my Dad's 1996 Buick LeSabre with over 200,000 miles, my 1993 Mazda 323 I had with over 250,000 miles (and drove clear to Puerto Vallarta, Mexico and back), and likely a few others if I think about it. There were also a couple vehicles that I'd drive at school, the company car to reach another school and my school bus, that both had over 200,000 miles and didn't burn oil. And I had to check the oil every day, so I would know if they did.
  4. Classic Car Guy
    Classic Car Guy Active Member
    504
    135
    Northwest, USA
    Honestly it does smells like kerosene with light oil.
  5. Classic Car Guy
    504
    135
    Northwest, USA
    I have a 1986 Toyota pickup (still have it today) That pickup miraculously doesn't burn oil with 265,000 miles. maybe Ill go low 1/8 of as quart if I need to change the PCV valve. I use any oil filter, 10-40 regular oil pretty much any brand as long as it not cheap like Ray-lube or on the bottom of the barrel brand. Well that's a different story. I just use it now if I need to haul something. Other than that its a great pickup purpose vehicle.
    Isaac Zachary likes this.
  6. bisco
    52,862
    our ford windstar blew the headgasket at 85k. a common problem
  7. Isaac Zachary
    2,779
    1,501
    I truely believe that ñ
    I'm pretty sure the Windstar had a different engine than the Aerostar. What I loved the most about our Aerostar we had when I was learning to drive is that it had a 5 speed manual transmission.
  8. Classic Car Guy
    504
    135
    Northwest, USA
    "Its a classic."
