Toyota Premium Horn Install
Discussion in 'Prius v Accessories and Modifications' started by WilsonC, Mar 12, 2016.
  1. WilsonC
    WilsonC Junior Member
    Bay Area CA
    2015 Prius v wagon
    Bought the Toyota Premium Horns (500hz and 400hz) from Sigma Automotive online. It took many months to arrive, the slowest order I have ever had. I think someone possibly swam from Japan to east coast to ship it to me. Anyway here are some photos from my install. This was plug and play, easier than oil change, so everyone can do this.
    Tools needed: Very small flat blade screwdriver, stubby phillips screw driver, 12mm and 14mm recheting wrenches, maybe a vice to unbolt the horn brackets.
    Remove the top plastic cover to gain access to the horns.
    More photos on the stock horns.
    Remove the Toyota emblem so you can reach in to grab the horns. Take off two screws from the back of emblem with stubby phillips screwdriver and gently release 4 clips before removing it.
    Loosen the nut and rotate the new passenger side horn (500hz, matching the high frequency stock horn) on the included bracket, so the trumpet is facing down to aovid water intrusion. I used a 14mm recheting wrench here.
    Unbolt the passenger side stock horn with 12mm racheting wrench and disconnect the factory wiring. Connect factory wiring to the 500hz horn then bolt down using the stock bolt. Note the horn casing is touching the front grill slightly so simply bend the bracket by a few degrees.
    Bent bracket.
    Now on to the driver side. Unbolt the stock horn using the 12mm racheting wrench. Disconnet factory wiring from the horn and set it aside.
    Again on driver side rotate the trumpet so it points down to eliminate water intrusion. The bracket was on very tight for me, so I had to use a vice here. I was very careful not to tighten the vice too much because I didn't want to crack the horn casing.
    Driver side horn (400hz, matching the low frequency stock horn) installed with stock bolt after connecting the stock wiring harness. Again horn is touching the grill slightly so it needs adjustment.
    Bend the horn bracket slightly again so horn casing is not touching the grill.
    I didn't have to use the hardware and wiring that came with the horns. Like I said, plug and play, 100%.
    Reinstall the plastic cover and you are done. New horns sound great, loud and carry a nice lower European tone to it. This mod took me about 15-20 easy mins, very well worth it.
    I didn't record it personally.But there is a link to side by side comparison audio clips. I can't post it here because I am too new to this board.
    Need one more post to be able to add link to my reply.I need one more postHere is the link: トヨタ アクセサリー | 快適・便利 | プレミアムホーン | トヨタ自動車WEBサイトEnjoy!
    KLD_Prius_PI_Synergy and bisco like this.
  2. Air_Boss
    Air_Boss Senior Member
    4,235
    1,191
    New Yawk
    "Noble sound quality will produce a premium driving."
    LOL! Love Google translate...
    52,671
    wow, what a difference. very noble!(y)
    Air_Boss likes this.
  4. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    BTY, you do not need to use a tiny pick on those round Toyota clips. With you finger, just push them in to unlock.
  5. Drewintoledo
    Drewintoledo Junior Member
    49
    Ohio
    2015 Prius v wagon
    good stuff... back in January I was going to put my Buick Roadmaster horns in my Prius :) But.... I didn't realize there were four horns in the Buick. So, I only took 2 of them out and stuck them in the little guy. I never thought about posting in the forums.
  6. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    OP, great post and excellent pictures. :)
    FYI, for everyone, you don't have to spend more for the "premium" horns, the ones in this thread work well too. ;)
    Horn Upgrade --- DIY | PriusChat
    Audio in linked video in first post.
  7. WilsonC
    Bay Area CA
    2015 Prius v wagon
    I recently upgraded the horns on my 2014 Prius Plug In, Sigma Automotive is no longer in business so instead I ordered Hella Horns from Amazon. These Hella horns are specifically made for factory Toyota connectors so they are also plug and play just like the Toyota Premium Horns I purchased several years ago. To me the Hella horns sound just as good as the Toyota Premium Horns, but at a faction of cost. Here is the link if you are interested:
  8. VirginiaLeePrius
    VirginiaLeePrius Junior Member
    47
    Space Coast, FL
    2024 Prius Prime
    SE
    I searched for 08522-B1010 KIT on Ebay and found several. I tried to upload before and after videos and sound files but nothing worked!
    #8 VirginiaLeePrius, Apr 20, 2025
  9. VirginiaLeePrius
    47
    Space Coast, FL
    2024 Prius Prime
    SE
    Attached are my before and after soundclips.
  10. VirginiaLeePrius
    47
    Space Coast, FL
    2024 Prius Prime
    SE
  11. Dan H
    Dan H Member
    49
    28
    Miami FL
    2015 Prius v wagon
    Can you tell if they are louder than the stock horns? I have never felt the 2015 v horns were not impressively loud. Compared to my 2005, the v has some serious honkers. This thread made me look into upgrading so I bought the "FIAMM 74100 El Grande". I'll post a review in a different thread.
  12. VirginiaLeePrius
    47
    Space Coast, FL
    2024 Prius Prime
    SE
    I found them significantly louder but I don't have any decibel numbers to bear it out. Those I've shared my before and after files seemed to agree. One of the most impressive facts about the kit to me was how absolutely complete it was. Is it that hard to add horns ... no .. but I had respect for the kit.
  13. Marguerite14
    Marguerite14 New Member
    singapore
    Stock 2015 CTS-V horns are decently loud but tend to have a more mid-pitch, Euro-style tone, which can get lost in traffic noise.
