Toyota Prius 2011 (JDM) - Cold start engine rattling sound
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Fouad, Jul 20, 2020.
  1. Fouad
    Fouad New Member
    Pakistan
    I bought this car used few months back. It was driven 150,000 Kms. I changed all necessary parts such as: Fuel filter/pump assembly, oil/air filter, transmission oil, engine oil & spark plugs. Got my car scanned and no error codes were found. As soon as I got the transmission oil changed, my car developed a rattling noise at start up (in morning) and sometimes at low rpm during drive. I observed that this rattling noise was mostly audible when the hybrid battery was depleted and engine converted to petrol. I read some articles on internet and changed set of ignition coils, cleaned EGR pipe, throttle and hybrid battery cooling fan myself at home.
    The rattling noise is still there and I don't know what to do. Please share any solution which may help.
  2. SB6
    SB6 Member
    324
    71
    I don't know if it's related to your rattle noise (I'm still relatively new around here), but consider cleaning the intake manifold, the EGR cooler, and the EGR valve
    ZBrink, Fouad and bisco like this.
  3. Fouad
    Fouad New Member
    Pakistan
    Thank you for your valuable feedback
  4. ZBrink
    ZBrink Member
    82
    33
    Fairfax, VA
    I have a rattle whenever the ICE first starts and stops. I cleaned everything associated with the EGR and it did not solve my problem. I am currently at a loss. I'm thinking the EGR valve may just be bad.
    Fouad likes this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Have you installed an oil catch can?
  6. Fouad
    Fouad New Member
    Pakistan
    Thank you for sharing your experience, you might want to try to change the ignition coils, may be that'll help in your situation
  7. Fouad
    Fouad New Member
    Pakistan
    Please can you elaborate, never heard of it before
    Raytheeagle likes this.
  8. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Here's some light reading in the Gen3 section on the topic:):
    Oil Catch Can, Eliminate that knock!
    That should be able to answer your curiousity and give you some background;).
    I put one on our old 2010 and also on our 2019 Prime as a preventative measure(y).
    #8 Raytheeagle, Jul 21, 2020
    Fouad and Grit like this.
  9. ZBrink
    ZBrink Member
    82
    33
    Fairfax, VA
    I'm not going to throw parts at it willy nilly. I'm actually going to try unplugging the EGR valve temporarily to see if the sound goes away.
    Fouad likes this.
