Toyota Prius 2012 Need some help
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rocco Gaglioti, Apr 19, 2022.
  1. Rocco Gaglioti
    Rocco Gaglioti Junior Member
    Orlando
    0F557F9C-2E20-4726-A23A-BDDBF9F7FF39.png C0AB1366-CDC8-43F7-A54A-1AB4702E3203.png 87CE3B09-E17A-4836-AD6A-757ED9B2E812.png Hello everyone. I get these error codes and I replaced all bus bars and replaced module 1 & 2 and still get these error codes. I am 100% lost. I have no idea why my battery pack is not picking up module 1. I could use any help and feed back. Thank you
    52,396
    have you checked all the wiring and connector pins for corrosion?
    Rocco Gaglioti likes this.
  3. Rocco Gaglioti
    Orlando
    When I took off the wiring harness I took a tooth brush and cleaned each post. Do you think I need to change the fuse board or computer on the battery?
  4. PriusCamper
    PriusCamper Senior Member
    13,075
    5,306
    Pacific Northwest, USA
    Block one likely has a bad voltage sensor wire where it plugs into the Battery ECU...
  5. PriusCamper
    13,075
    5,306
    Pull the Battery ECU and open it and look inside and see how close to the board the corroded connecting pin got.
  6. Rocco Gaglioti
    Orlando
    Yes I did and there was no corrosion at all.
  7. Rocco Gaglioti
    Orlando
    C72D0B4C-50F4-4605-8E28-A894A0F3DEB4.jpeg I found the issue. I just ordered a new one from eBay. I will install it and I think all will be good now. Thank you for your help
