Toyota Prius 2nd Gen. - converted to LPG hybrid
Discussion in 'Gen 2 Prius Technical Discussion' started by mandrei83, Jul 5, 2010.
  1. Yes
    52.8%
  2. No
    15.3%
  3. Why not something else? (PHEV, Solar and more)
    15.3%
  4. I'm not sure if it worth the investment
    24.3%
Multiple votes are allowed.
  1. painless_81
    painless_81 Junior Member
    Moldova, Chisinau
    Re: Toyota Prius 2nd Gen. - converted to LPG bybrid
    I'll surprise you. In our little country a few prius lpg, including my :)
    p.s. one CNG prius!
  2. tdn
    tdn Junior Member
    Russia
    Surgut town, Tumen region.
    RHD drive is all over Russia, just in Vladivostok, much more.
    Photo will be late, after weekend.
    CNG on my country is very bad - no refills, and very little can be reached at a gas station
  3. uart
    uart Senior Member
    4,220
    1,209
    Australia
    I'd love to have a CNG converted prius. I could fill it up at home for 1.6 cents per MJ :D
    BTW petrol here is equivalent to about 4 to 5 cents per MJ (150 cents per liter and 33 MJ per liter approx).
  4. tdn
    tdn Junior Member
    Russia
    Now i took pictures from my installation
    This reducer
    LPG ECU
    LPG temp and pressure sensor
    LPG injectors VALTEK 30 red 3om.
    LPG tanks
    Tomassetto LPG filler well
    Installation was carried me on their own. Valtek 30 upp is 0.45 mm, holes 1.5 mm, pressure 1.1 bar. Fuel consumption will inform further.
    Questions?
  5. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    Wow!
  6. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    How does the Prius perform in the cold in winter?
  7. tdn
    tdn Junior Member
    Russia
    I bought a car a few months ago and not yet ready to say that either of the winter operation. I can say for sure that I will be installing heating engine similar webasto and may be car alarm with a remote start engine. I know car salon warm in extreme cold for long.
  8. shot
    shot Junior Member
    Germany
    Hi
    Could you show your map and modeling card of the KME software please?
    What offset and mult parameter you using?
    How easy was it to get a Map in a specified RPM?
    I'm converting my Prius with KME Diege System to LPG/GPL.
    Tank is installed (58L). I'll continue next weekend.
    Thanks
    Heinrich
  9. shot
    shot Junior Member
    Germany
    Anyone of the LPG /GPL user of the 1.5 l Prius engine thought about the valve clearance and checks?
    I had a Subaru with 'soft' valve seats that had more valve checks or LPG than on gasoline.
    Any experiences yet?
  10. Stormz
    Stormz Member
    105
    Perth, Australia
    Time to revive an old but amazingly interesting thread :)
    Anyone know if LPG conversion is possible in Australia? Apparently they can only use Euro 2004 approved kits here. Am waiting on a reply from one of the places that do conversions.
  11. sidecar
    sidecar Member
    342
    45
    Australia
    With LPG at around half the cost of petroleum and widely distributed I can see the advantages. But one of the problems in au will be satisfying a fairly stringent retrofit tank, because they want a sealed cofferdam between the tank and the cabin. Personally I cant see any way around that unless some space, enough for a decent capacity, can be gained from the removal of the petrol bladder
  12. Dolce_Vita
    Dolce_Vita Member
    228
    25
    Sydney, Australia
    I'm also interested in a LPG conversion in OZ, it'll half my (already cheap) fuel bills and makes much more sense than PHEV (for my usage).
  13. radi123
    radi123 New Member
    Sofia
    Hi Prius Fans,
    Can you please tell me, if you have any information regarding increased engine issues/wear or any official responses from Toyota regarding converting Prius to run on LPG. I'm looking to actually to convert the new hybrid Auris, which should have the same engine.
    Many thanks,
    Rado
  14. tdn
    tdn Junior Member
    Russia
    A large number of car rides on LPG. Generally, when properly installed, no problems in the engine and the car is not observed. Type of vehicle and engine is not important.
  15. wjtracy
    wjtracy Senior Member
    11,364
    3,607
    Northern VA (NoVA)
    Great job. Re: poll I would consider this more for my *other* car than my Prius. Good question about LPG availability, used to be good due to refilling propane tanks for barbeques, but now we just trade-in empty tank for a full tank.
  16. wjtracy
    11,364
    3,607
    Northern VA (NoVA)
    P.S.: a friend of mine in Germany has an LPG converted car too (spare tire port tank).
    Just saying, USA talks about alternatives, but we like to pick "winners" (eg; EV) instead of opening the field for all options. I cannot think of a good reason why LPG is cheaper in Europe, except taxes on gasoline are so high there.
  17. iyas
    iyas New Member
    Mauritius
    Andrei,
    Thanks for your kind reply.
    In fact i'm in Mauritius Island... Google for it & here its Summer:)
    In fact i actually have a LPG (Lovato) installed Nissan fb15 for 8 years... still running done over 100K KM since converted. it does 1L/10KM LPG in traffic jams/mixed
    I'm thinking over either a axio fielder or a prius like yours since we get recon cars from japan.
    IAlready got some experience with conventional cars conv with LPG... but as for prius??? i fear sensors & valve wear (since i presume the engine block is not the same a a conventional block as for corolla?), etc.
    If we consider having 5L/100KM(Petrol)... money speaking: I'm now getting half as much with my old nissan. (our price of petrol >= 2 times LPG)... then LPG conversion is tickling my mind :mod:
    What's your experience till now?
    Have you enquired about Valve wear?... I've read about lubricants for that... vlube... something like that.
    please advise
    Thanks
    Yas
  18. simonthegreat
    simonthegreat Junior Member
    Estonia
    Hey mandrei83! I came to idea to make this kind of change too, then googled and discovered your thread here! Really great work! Thank you for that! :) Quite some time has passed, any update on that? I was contacting local service providers, they made me an offer around €1140 for IV generation LPG system and told IV is the latest could be mounted on 2nd gen Prius. Which generation did you use on your/friend's car?
    Thank again, man! If you weren't so far away from me I'd let you to do the job :)
  19. R-P
    R-P Active Member
    804
    288
    Netherlands
    Did some research on Lexus RX400h a few years back but could not find anything on them... Thought the engine was not suitable for some reason...
    So very (pleasantly) surprised to find this thread :D
    Should do it quickly, as in 2012 and 2013 I don't pay roadtax on my Prius, and LPG roadtax is higher than gasoline*. So may even save myself the increased roadtax for the next two years!!!
    As a matter of fact, I'll give the government agency that controls this a call to verify.:cheer2:
    * why LPG roadtax is higher than gasoline (less polluting = more expensive) is one of the best kept secrets of the Dutch government: no one seems to know. :confused:
  20. mandrei83
    mandrei83 Member
    139
    32
    Stockholm, Sweden
    @simonthegreat: I would strongly recommend it to buy yourself all the components required to do this mood, they will cost you about 600EUR with the shipping in your country. Then, if you want a good work, go to my friend from Romania and he will do it for you for max. 200EUR. I wouldn't count that the service which has made you that offer will put you the latest STAG-300 Plus kit... So, take care and good luck with your mood!:)
    @R-P: Netherlands it's quite a special country, from the car taxes point of view...:)
    I would strongly recommend you to install this LPG kit in a foreign country and not to declare in NL to your authorities if you will put LPG on it and will cost you more. Go to my friend from Romania, as advised to simonthegreat user.
