Toyota Prius college student
Discussion in 'Newbie Forum' started by dylan24, Jan 26, 2017.
  1. dylan24
    dylan24 New Member
    new york
    I
    Hello, I need a car for college, as I have a long commute (27 miles on way). I am looking to buy a prius, I am in love with prius. I found a few toyota prius (2006-2007 100k-140k miles) from 4995 to $6000. My budget for the prius is 6000 but I personally rather only spend 5000-5500. My question is how reliable will these cars be for a college student as I don't want to keep paying for big repairs, I can handle the regular maintenance, etc. But I need the car to give me atleast 2-3 years. Would you recommend it? Thanks for all the help.
  2. Munpot42
    Munpot42 Senior Member
    1,391
    543
    Santa Monica, Ca. 90405
    You would probably be better off with an old Corolla, battery life in a Prius becomes more problematical when the mileage tops 100k, although in some states it is under warranty until 150k.
  3. JimboPalmer
    12,470
    6,866
    Greenwood MS USA
    RCO likes this.
  4. dylan24
    dylan24 New Member
    new york
    I
    How much exactly is a battery? 2k or under?
  5. dylan24
    dylan24 New Member
    new york
    I
    Thanks for all the information, just read it a few minutes ago. Very useful.
  6. Munpot42
    1,391
    543
    2k or under for a rebuilt, 3k+ for a new one. From what I have read on this forum, new ones are much more reliable.
    RCO likes this.
  7. Moving Right Along
    Moving Right Along Senior Member
    690
    541
    The Prius is typically a very reliable car, as long as you do your research by checking maintenance & repair history before you buy. As they get older, however, there is a risk of hybrid battery failure after around 10 years or 200,000 miles, and that costs $3000 to replace. Currently, based on the figures I've found there's roughly a 3% risk for the model years you're considering, which could go up to 10% in 3 years. Basically, you've got good odds that you'll have a very reliable car through college but if you're in the unlucky few, you'll have a big bill to pay.
    RCO likes this.
  8. dylan24
    dylan24 New Member
    new york
    I
    When looking at the maintenance and repair history, what are the major components that I should be looking out for? Like at what mileage, what should be changed, etc. Thanks for the help.
  9. Moving Right Along
    690
    541
    This should give general guidelines: 2006 Toyota Prius Manufacturer Service Schedule and History - DriverSide.com
    Also, the 12v "regular" car battery should be changed every 5 years or so and all recall repairs should have been completed. You should be able to find out any recalls needed by telling the VIN to any Toyota dealer.
    When doing a test drive, pay attention to the battery meter on the "energy" setting of the display. The level should stay in the blue (or green) range and should not go up or down more than 1-2 bars. If it changes by 3 bars or more, that means the hybrid battery could be at risk of failing so you don't want it.
    #9 Moving Right Along, Jan 26, 2017
    RCO likes this.
  10. ericbecky
    ericbecky Hybrid Battery Hero
    4,371
    3,222
    Madison, Wisconsin
    As a hybrid mechanic, I can tell you that you would be better off buying a non-hybrid vehicle.
    A used hybrid in your budget range could easily have an expensive hybrid battery, tansaxle, or inverter problem come up. These repairs would be an unplanned $2,000-$3,000 expenditure.
    To reduce the likelihood of big costs, you would be better off looking for a Toyota Corolla, Honda, Fit, etc.
    The gas mileage will be decent and you still will be better off than some 20mpg car.
    RCO and bisco like this.
  11. dylan24
    dylan24 New Member
    new york
    I
    Thanks for the information, very useful (especially how to check for the battery quality). Also, at bumble bee site I see a toyota prius battery for $1,200 with one year warranty, are those bad? The dealer I am looking at does have a car fax report with all maintanence being done at the toyota dealership. He has two toyota prius one 2007 (138,000 mileage) for 4,600 and another 2005 (136,000 mileage) for 4100. He has carfax report on both, with both listing as one owner. You think I should still get a mechanic to check out those cars?
  12. Moving Right Along
    690
    541
    If it's being sold by a Toyota dealer, there should be a multi-point inspection they do prior to putting the car up for sale. And if that was done, I don't think you need to get it inspected by a different mechanic. Others may disagree, but that's my opinion.
    Regarding the hybrid battery quote you saw, there are a number of places that rebuild and resell hybrid batteries and charge considerably less for them than new ones. However, rebuilt batteries have significantly lower reliability (some can fail in a few months) than new batteries (which typically last 10 years or more).
  13. dylan24
    dylan24 New Member
    new york
    I
    Na, it isn't a Toyota dealer.
  14. ericbecky
    4,371
    3,222
    Madison, Wisconsin
    1 year warranty? Probably not good enough for your needs.
    You need to ask yourself if in 15-18 months will you be financially prepared to buy another $1,200 battery.
    Or during the 12 month period, pay for labor again to have a warranty replacement installed.
    I work on hybrids for a living, and I would say it is not the best choice for a college student. Unless of course you get it at some ridiculously cheap price (1,500 - $2,500) and with average miles.
    If you are dead set on a hybrid, no one is going to stop you. There are ways you can try to mitigate the risk, such as looking at the hybrid battery levels with a scanner (bluetooth obdii adapter + Android app like Torque or Hybrid Assistant)
    I'd be happy to walk you through it.
    Too often I've seen college students get burned when purchasing a high mileage hybrid. I don;t want that to happen to you.
    RCO likes this.
  15. dylan24
    dylan24 New Member
    new york
    I
    Thanks for all the responses, I truly do appreciate it. I will be working throughout college, so I will have some side cash but I'd rather not keep spending on the car (just like most people) other than the usual maintenance. Also, I would love for you to walk me through how to check the hybrid battery levels with a scanner. Thanks for all the help.
    RCO likes this.
  16. dylan24
    dylan24 New Member
    new york
    I
    Other than the hybrid battery and the 12v battery, are there any other major replacements for the gen 2 hybrids?
    RCO likes this.
  17. bisco
    49,519
    air conditioning
    brake actuator
    inverter
    tail lights
    transaxle
    problems that are difficult and expensive to diagnose
    brake shoes/pads/discs/drums
    you should search for the recent thread from a college student here (along with many others) who is stuck between a rock and a hard place because can't afford to fix his prius, can't diy and just wants it fixed. cheap.:cool:
    take a course in economics while you're there. all the best!(y)
    RCO likes this.
  18. ETC(SS)
    6,564
    Dylan....
    You keep refuting answers to your own questions from a Prius enthusiast forum regarding 3 year reliability on what will be an old or very high mileage car....and we're not talking about 3 normal years. With your commute, and in your climate you can expect to put roughly double the normal wear on this car, doing two things (working and college) that are not vehicle fault tolerant.
    If your major isn't economics, you'll also need to consider the fact that hybrids are a little more expensive than non-hybrids.
    That's cool if you plan on getting a car that has roughly 75-percent of its life cycle ahead of it because the car will have a chance to save you some $$$, but in your price range 75 percent of the vehicle's lifespan is in the rear-view mirror.
    That's just not............efficient.
    Or in purely economic jargon.....they're money pits.
    So....you're into Priuses.
    That's GREAT.
    See if you can look at this from the other end of the telescope.
    Get a car that NEEDS a transaxle or an ICE, or an Inverter, or a battery......in a year or two and with spare money.
    Yeah.
    I know.
    "What spare money? I'm a ^%$#@ college student!!!"
    What I'm suggesting is that you start a fund to get a junker and see if you can resurrect it as a project car after you have a little money kicked into a cookie jar labeled "Dylan's Prius Fund."
    Just remember.
    Non Hybrids in the $6000 range are going to need work too, and Priuses also need the same stuff IN ADDITION to stator windings, inverter pumps and plumbing, regenerative brakes, batteries, etc.
    If you've read through this forum, then you'll see that there are a lot of people that adopt elderly Priuses that just aren't financially ready to do a heart-lung transplant, and they have to sell the car off for $1000 or less....with the regrets that FANS of Priusdom are trying to save you from.
    With a little patience, a few junk yard parts, LOTS of time and Youtube vids, and a dash of luck you might be able to sell off the non-hybrid beater someday.....and continue to Love Priuses like you do now.
    Good Luck!
    #18 ETC(SS), Jan 26, 2017
    RCO likes this.
  19. ericbecky
    4,371
    3,222
    Madison, Wisconsin
    If you have a lot of extra time on your hands and don't need the car to be very reliable, then maybe a high-mileage used hybrid would be a good choice.
    Then you can do the work yourself with your tools eves/weekends.
    RCO likes this.
  20. JimboPalmer
    12,470
    6,866
    Greenwood MS USA
    If you do not change the ATF WS in the transaxle periodically, (every 90,000 miles) suspended metals may short the Motors in the transaxle for $5000. If you get a gen 2 consider changing immediately ($40 in parts, near $110 at a dealer)
    If you are unwise enough to jump start another car, or just get the cables mixed up jumping your car, you can fry the Inverter.($4000) Do not jump other cars (a jump pack you carry with you is about $35 amazon.com/gp/product/B013UJ2JCE ) and if you need to jump start your Prius, replace the 12 volt battery. ($175)
    I do not recommend a used Prius unless you have deep pockets in case you are one of the unlucky ones.
    RCO likes this.
