Toyota Prius Fails Georgia Emissions Test
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by jkash, Apr 16, 2007.
  1. FBear
    FBear Senior Member
    355
    23
    Maplewood, NJ
    2015 Prius v wagon
    I live in New Jersey and any car with OBD II port just gets hooked up to their computer system, which downloads all the emissions data. They don't even use the tail pipe violation method.
  2. Tideland Prius
    16,547
    <div class='quotetop'>QUOTE(allargon @ Apr 18 2007, 07:56 AM) [snapback]425301[/snapback]</div>
    I do.. it just doesn't have to work as hard as yours :p . The Lower Fraser Valley can easily hit 30°C in the mid summer. Closer to low-mid twenties by the coast.
  3. ilusnforc
    ilusnforc Member
    404
    San Antonio, TX
    I'm not sure how they do they emissions testing, but couldn't they move the shifter to "B"? I know when I use it the ICE is forced to run continuously, even when I come to a comple stop the ICE will continue to idle.
    I don't think the A/C trick would work, I use the A/C a lot here in San Antonio yet the ICE shuts off quite frequently.
  4. Heikki
    Heikki Junior Member
    51
    Finland
    Smog check for Toyota Prius NHW 20 series:
    Activate test function and preheat engine.
    1. Do steps 2-8 in 60 seconds.
    2. Press power switch 2 times
    3. Kick down the gas pedal 2 times.
    4. Kick down brake pedal and simultaneously put gear selector to N-position
    5. Kick down the gas pedal 2 times.
    6. Keep brake pedal depressed and push park (P) switch.
    7. Kick down the gas pedal 2 times.
    8. Keep brake pedal depressed and push power switch. Engine starts. Perform smog test. Push gas pedal and you can increase engine rpm.
    9. Push power switch and engine stops.
    Do not drive car when the test mode is engaged.
  5. RAMbler
    RAMbler New Member
    31
    <div class='quotetop'>QUOTE(Tech_Guy @ Apr 16 2007, 07:21 PM) [snapback]424296[/snapback]</div>
    From the Simpsons:
    Newspaper editor: … And to protect Mother Earth, each copy contains a certain percentage of recycled paper.
    Lisa: And what percent is that?
    Newspaper editor: Zero. Zero’s a percent!
