Toyota Prius P3190 poor engine power, P0A0F -204 ENGINE FAILED TO START Solved
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by DavidDavid, Mar 11, 2023.
  1. DavidDavid
    DavidDavid Junior Member
    29
    Toyota Prius P3190 poor engine power, P0A0F -204 ENGINE FAILED TO START Solved, I had these above codes, so I thought I’ll share this video with everybody, the vehicle sounded like it needed a head gasket or an engine, but all it needed is fuel pump. I made this video to help everybody. Search for this video in youtube "
    Toyota Prius P3190 poor engine power, P0A0F -204 ENGINE FAILED TO START Solved"
  2. Tombukt2
    Tombukt2 Senior Member
    13,853
    2,515
    Durham NC
    So the engine essentially just run out of gas permanently No I don't guess it can run. But I guess tec stream I would think should show you that the fuel pump isn't pumping isn't that right?
  3. Shahzad Nayyar
    Shahzad Nayyar Junior Member
    94
    25
    Pakistan
    One point to remember is to NEVER drive ur prius when the fuel is too low.
    The fuel pump is located inside the tank and needs to be submerged to stay cool. If you drive for too long with low fuel, it will start to deteriorate
    Tbkilb01 likes this.
  4. DavidDavid
    29
  5. DavidDavid
    29
  6. Tombukt2
    13,853
    2,515
    Durham NC
    Doesn't tec tell us about fuel pump? I mean it is one of the first things you're supposed to check on a nice engine for running and running problems fuel and fuel pressure need to be relatively close or in the range the Toyota gives for the fuel pump which is pretty decent most Toyota in tank fuel pumps for EFI have been the same pretty much since the mid eighties I use a Toyota EFI fuel pump in one of my motorcycles It's the same pump.
  7. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    Awesome job and follow up David. For sure will help someone else down the road.
    TomK
    Tbkilb01 and DavidDavid like this.
