TOYOTA PRIUS READY SIGNAL BUT HAS NO POWER ON DRIVE OR REVERSE!,HELP
Discussion in 'Generation 1 Prius Discussion' started by Faisal, Apr 13, 2013.
  1. bwilson4web
    16,217
    The Hayes manual is a light-weight version of Volume 2 that deals with mechanical repairs. Their diagnostic section is unusually light and they really don't have a clue as to how our Prius works. I know because I bought one and compared to the Toyota shop manuals, it is not very detailed and lacks insights.
  2. Patrick Wong
    18,210
    6,510
    1. I suggest you access techinfo.toyota.com for factory repair manual information including interpretation of the various DTC.
    2. If the replacement inverter works and was correctlly installed then it is reasonable that the transaxle might be at fault given the continued presence of P3125.
    3. I am not aware of any "rebuild" facility available for the transaxle. You would probably have to purchase a used unit from a salvage yard.
    4. What prevents you from reinstalling the engine MAF sensor and any other missing parts?
    5. Was this car in a front end accident?
  3. Faisal
    Faisal Junior Member
    58
    2002 Prius
    I
    what is an engine maf sensor? and the air box and inverter are out because i am taking the car apart to take the transmission out, we already tried reinstalling a new inverter and the car still didnt run on reverse and drive. it turns on and gives ready signal. but does not run. . and the car is clean title so i dont think its been in any accident.
  4. Faisal
    58
    2002 Prius
    I
    ok so i replaced the inverter and replaced the airbox and now its showing NO CODES. it says zero codes. but why wont it run then??
    i also replaced another maf sensor from another r prius and the other prius works fine with the sensor from my prius.
    the car turns on and shows READY sign but it wont move back and forth, and right now the engine doesnt even turn on i cant hear any engine noise maybe because the axles of my car is out right now
    the car turns on and shows READY sign but it wont move back and forth, and right now the engine doesnt even turn on i cant hear any engine noise maybe because the axles of my car is out right now.
  5. Patrick Wong
    18,210
    6,510
    If the half shafts are removed from the transaxle, then you have no ATF fluid in the transaxle. If you have no ATF fluid in the transaxle, then you don't want the engine to turn on, because in order for it to do so, MG1 within the transaxle has to spin up.
    If MG1 spins up without ATF fluid, that will probably damage the power split device within the transaxle (similar in operation to a differential, but its purpose is to allow power to flow between the engine, MG1 and MG2.)
    If the car shows READY and no warning lights appear, then there is some hope that the car might start. I suggest that you fully assemble the remaining missing parts and see if the car will start. If it doesn't start and there are no DTC logged, then I suggest you have the car towed to your local Toyota dealer for a diagnosis. Good luck.
  6. Faisal
    58
    2002 Prius
    I
    so i should put the axles back on and the CV joints back on(cv joints connect to the transaxle if im correct?) and then start it again? like i said, before i disassembled anything. the car would turn on and the engine would turn on and off every 5 seconds or so. and when i put it on drive or reverse it wouldnt move but the engine would make a loud shutter sound like if something is broken inside. the DISPLAY screen for the navigation and etc.. is WHITE (blankk) not showing anything. so what would u think? given this information.
    do you think this has anything to do with the ECU under the passenger seat? since the display is blank and it was turning on and off before, showing me a red triangle and also a car with an exclamation mark going through it(by the way we already got the hybrid battery replaced). but now its completely blank.
  7. Patrick Wong
    18,210
    6,510
    I think you should seek professional assistance by having your car towed to your local Toyota dealer or hybrid independent specialist.
  8. Faisal
    58
    2002 Prius
    I
    ;[. they charge to much for diagnosis. thats why i bought my own little scanner lol. before it was showing 4 codes and now its showing 0 codes.
  9. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    **Mod Note** Merged this thread with a 2nd thread started in the 2nd gen forum. Please do not cross post topics across multiple forums.
    At this point, I think the consensus is that you may be in over your head and that professional assistance is required. While a dealer may not be a requirement, someone who has worked on these cars before is highly suggested. What you're attempting to do by saving money may cost more in damaged parts simply from lack of experience.
    Take the advice of Bob, Patrick, and others and get local, professional, and competent help. It really will save you in the end.
  10. Faisal
    58
    2002 Prius
    I
    i put everything back in that i took out and everything works properly. its just the same as before i even took anything out.
  11. Faisal
    58
    2002 Prius
    I
    the only reason why i dont like going to the dealer is because they BS about whats wrong with the car. my dad took our other prius there and they bsed us they said it was the inverter and then they didnt wanna tell him what was wrong with it. after that we took it to some local mechanic and he put inverter coolant pump and inverter coolant and the car started working properly
  12. bwilson4web
    16,217
    You might contact these folks and ask about independent mechanics:
    Auto Careers Development Center - Hybrid and Electric Vehicle Repair Training
    They have a 'shop finder' page but it is not always current:
    Hybrid Shop Finder | Auto Career Development Center
    I would recommend giving them a phone call for their most recent and current recommendations. BTW, they also have video training and the one I took was pretty good. It doesn't hurt to ask.
    As for your current project car, the codes posted are pointing at the engine ECU and possibly a failed, DC-to-DC inverter. This is the part that generates 13.8-13.9V needed to recharge the 12V battery.
    Faisal likes this.
  13. bwilson4web
    16,217
    I don't think there is anything 'magic' about the Prius that prevents anyone with what I consider to be ordinary technical skills and the good tools and books can't figure out. But Haynes is at best a 'parts to swap' manual and exceptionally light on the diagnostic aspects. Swapping parts, especially with the Prius, is an especially poor approach. And this is a computer operated car, we just tell the computers what we want to do and they try to respond. When they can't, they are able to give error codes and diagnostic information.
    With a Prius-aware scanner and the Toyota shop manuals, anyone who understands how to read a volt meter and handle a torque wrench has a good chance of keeping them running. Over the 12 years of NHW11s in North America, pioneers (who were my teachers) taught us about the obscure aspects not covered in even the Toyota manuals. But that is why some of us hang here and the other places mentioned in the sticky.
    We're willing to share our expertise and even explain the why behind what we suggested. Consider how much we're charging for this advice . . . the alternative is to ask Mr Google . . .
    Your codes point to the engine ECU and this is rare but not unknown. But the first step is to fault-isolate the problems and share what you learn. Please, start with diagnosis and only swap parts as empirical data identifies parts that need replacing. Besides, the tools you need for proper diagnosis are really neat (Ok, I'm an engineer and few understand how we think.)
  14. Faisal
    58
    2002 Prius
    I
    where can i get the proper tool?i have the
    Actron / OBD II code reader for 1996 and newer vehicles
    . i dont know whether this is good or not? and they dont accept returns for it. i bought the most basic one from autozone. yes i understand how to re install and uninstall everything, so i dont see why i cannot do this. i went from knowing nothing about the prius to knowing how to install an inverter, inverter coolant pump,axles; thanks to Priuschat[: and was going for the transmission until i told my dad that we should install everything back on and read the codes since we got the code reader late, and it wont show any more codes now. i just cant find the problem, thats all.
    Thanks
  15. bwilson4web
    16,217
    I'm sorry to hear this. The over-the-counter OBD scanners are able to read out a few codes but the details needed are not there. But Prius-aware scanners that I have tradeoffs:
    1. Scangauge II ($150) - to make it Prius aware, you'll need to add XGAUGE definitions. The sticky has them but it also needs a 'pig-tail' or the special ISO-9141/KWP2000 only cable. It can also be used to improve driving technique and learn more about this car.
    2. AutoEnginuity ($500) - requires your laptop but is a full-up, diagnostic package. I had one until a virus destroyed my virtual PC image. It works and there is support, a solid product but not something to use in general driving.
    3. miniVCI ($35) - a Chinese hack of the Techstream-Lite, their "XHorse" retailer is the only one I've to work on both my wife's ZVW30 and our NHW11. It took almost two weeks to arrive and requires your laptop.
    Ok, let's start with basics:
    1. What is the 12V battery voltage now? It may need to be recharged.
    2. Absence of codes is bad suggesting the ODB buss may be 'broken'. We'll need to fault isolate once we know the 12V battery is OK. I'll try to post some suggestions but the team may have some suggestions.
    3. Search on "Chapman" and "code flash" - he has done some original work on how to jumper the OBD connector to get the ECUs to flash their error codes.
    Later tonight,
  16. Faisal
    58
    2002 Prius
    I
    i will let you, know 12v battery. buty we already charged it before and it still didnt work, and we got the hv battery replaced by a professional who did muy dads other car. so we knopw that both were ok. i will check the voltage again tyhough. and do u think i xcan use tech sctream fro mthe toyota tech website and use a MFCcable or whatever to use my laptop with the tech stream software to connect to the cars computyer? instead of buying a scanner? or the scanners mu8ch better?
  17. Faisal
    58
    2002 Prius
    I
    ok i put gas in my car and now the engine turns back on. on drive it doesnt make a shutter sound, it makes an accelerating sound but it goes on and off on and off.but on Reverse it makes a shutter sound. on the other hand i have codes p0300 and p3125. so im going to change the inverter from my dads running prius with no codes and see if that will take out p3125.
  18. Faisal
    58
    2002 Prius
    I
    started the car, let it run, now its showing codes p0500 and p3120, can anyone tell me what that means?
    p3125 and p0300 is not there anymore.
  19. bwilson4web
    16,217
    After swapping the inverter from your Dad's car? Sounds like the one removed is bad.
    What are you using for coolant? Most of us find bleeding the inverter loop a pain.
    Again, this is why the Toyota Diagnostic Manual, Volume 1, is so useful:
    • P0500 Vehicle Speed Sensor Malfunction - "During vehicle is being driven, no vehicle speed sensor signal to ECM", DI-108 to DI-109
      • Combination meter
      • Skid Control ECU
      • Open or short in vehicle speed sensor circuit
      • Vehicle speed sensor (one on each wheel)
      • ECM (engine control module, aka. engine ECU)
    • P3120 HV Transaxle Malfunction - "The HV ECU checks the energy balance and detects abnormality if the magnetism of the motor or generator greatly decreases.", DI-257 to DI-270
      • 234 INFO code - small reduction in motor magnetism (aka., MG2)
      • 235 INFO code - large motor reduction
        • HV transaxle (motor)
        • System main relay
      • 236 INFO code - small reduction in generator magnetism (aka. MG1)
      • 237 INFO code - large geneator reduction
        • HV transaxle (generator)
        • System main relay
      • 239 INFO code - shaft damaged
      • 240 INFO code - generator locked (if engine runs, not possible)
      • 241 INFO code - torque limiter sliding
      • 260 INFO code - generator temp sensor problem
    The "INFO code" tells us what is failing which could be as simple as a loose connection or something worse. This is where a Prius-aware scanner pays for itself. It identifies what to check. Having either the TIS service or Volume 1 of the 2001-03 Diagnostics manual would be the road-map to what is broken.
  20. Faisal
    58
    2002 Prius
    I
    ok where can i buy the mini VCI or whatever you use? and connect it to my laptop . and what software do i download onto my laptop to be able to use the both together? that way i can see for sub codes. i am going to return the haynes manual and buy the volume 1 and volume 2 of the 2001-03 diagnostics manual.maybe the one u mentioned on ebay.
    thanks for following up.
