TOYOTA PRIUS READY SIGNAL BUT HAS NO POWER ON DRIVE OR REVERSE!,HELP
Discussion in 'Generation 1 Prius Discussion' started by Faisal, Apr 13, 2013.
  1. bwilson4web
    16,130
    It comes from "X-Horses" and the second one I bought had firmware 2.0.4 which works with my wife's car:
    MINI VCI FOR TOYOTA TIS
    There may be other vendors but this one worked for me. Still it took nearly 10 days to arrive . . . negotiate.
    Also, I am using "Windows XP", a virtual PC, that keeps it isolated from my laptop. I am not a fan of Windows in any form but there have some reports that more recent versions of Windows might have trouble. I don't know about any other versions.
    Definitely Volume 1 because it and a Prius-aware scanner are your roadmap to what is broken. Volume 2 because it has specific instructions on major repairs. Avoid any "CD" as they are notorious for being poorly digitized versions of the manuals.
    Now some folks have had good luck using the Toyota online TIS service and there are daily and monthly rates. I have not tried it as 'an old man', I likes my paper books. But after diagnosis, you might find TIS to be more cost effective or reasonable alternative to Volume 2 for specific repair procedures.
  2. Faisal
    Faisal Junior Member
    58
    2002 Prius
    I
    ok i am bidding on 2 books,2001 toyota prius volume 1 and volume 2, on ebay. its like 96 bucks for both but i made an offer(hope its the right one for 2002 and 2003 also). eventually im going to buy it either way. and as for the mini vci, i have windows vista 64 bit, would this mini vci work or would it not work at all? i really like the idea of using my laptop since im really good on computers. and it is really cheaper. i want to know if it will be compatible with my windows before i even buy one. and also, isthe 2002 toyota prius 16 pin or 22 pin connector?
  3. bwilson4web
    16,130
    I don't know. You might try some Google searches. I've only used Windows XP.
    It is 16 pin. You can see it where your Autozone scanner connects.
  4. Faisal
    58
    2002 Prius
    I
    ok cool, i am checking youtube videos to see if it is compatible with other windows before i buy, because when i saw it on ebay it said compatible only for windows xp
  5. bwilson4web
    16,130
    More expensive but supported, you might look at AutoEnginuity. The developer can answer any questions but it is pricy, $500 for the basic package and the Toyota option. I've used it with both Prius without a problem and you can get it fairly quickly.
    The other option is to look over the ScanGaugeII. Check the XGAUGE definitions as I remember there are the INFO / subcodes. At $150 and the pig-tail or Prius specific cable, you'll also be good to go. Not as sophisticated as AutoEnginuity and miniVCI, it can also be used while driving.
  6. Faisal
    58
    2002 Prius
    I
    can you please send me the link to where you bought your mini vci? also for the virtual PC , do you mean a windows xp virtual machine that is like a "program" and its basically a windows xp but ur using ur laptop to open the program(windows xp) then u run the file from there?
  7. bwilson4web
    16,130
    These are the folks I bought miniVCI that worked:
    X-Horses Authorized Online Store
    They claim to be the "X-Horses" online store and their version came with firmware 2.0.4 that worked with my wife's car.
    You've got the right idea, a virtual machine that runs as a program under the native operating system. So 'Windows XP' is in effect a program running under the native operating system. This is how I run windows on a Macintosh but I can also run Linux or other operating systems under the Macintosh OS. I know there are similar "Virtual Machine" systems available designed so multiple, independent Windows systems can run on the same machine.
  8. boppo
    boppo Active Member
    799
    139
    Owego, NY
  9. bwilson4web
    16,130
  10. Faisal
    58
    2002 Prius
    I
    ok im downloading the windows xp crack and i already downloaded the virtual pc, im going to save them on my hard drive also for later use on maybe other laptops :p. hopefully the windows install works, then i will proceed on buying the minivci cable today
  11. bwilson4web
    16,130
    Sounds like a good plan.
    Virtual machines have been around for a long, long time, the 1970s, and have a lot of value. What they do is provide an additional, independent memory management system. The 'virualized' operating system can preserve and maintain legacy applications. Meanwhile, the virtual system keeps the different operating systems from 'stepping' on each other.
    In theory (and practice) you could even run DOS and DOS applications <grins>
    I think you are well on the way. Especially once you get a Prius-aware scanner running. We'll be able to use the INFO codes you post, check in our copies of the diagnostic manual and point you to where the problem lies.
    Just to recap, your car now runs for minutes, hours, long as there is gas? The inverter pump and loop have coolant in it? The traction battery shows it is charging?
    These are all good things for the next phase, figuring out the last little bits.
  12. boppo
    boppo Active Member
    799
    139
    Owego, NY
    Bob, my firmware is version 2.0.4
    bwilson4web likes this.
  13. Faisal
    58
    2002 Prius
    I
    hey can you please send me the right link to the NEWEST one and a WORKING one? i read reviews on ebay for some of the mini vcis and they said some dont work and dont install. so please send me the right one that i will be happy with. thanks.
  14. bwilson4web
    16,130
    This is the one I got that works with firmware version 2.0.4:
    MINI VCI FOR TOYOTA TIS Techstream V7.31.003 single cable
    This is the one boppo got that works with firmware version 2.0.4:
    Newest 2013 MINI VCI FOR TOYOTA TIS Techstream 2012.V8.00.034single cable free shippin
    The key appears to be the 'firmware' of the miniVCI cable:
    • 1.4.7 - works on NHW11 (our models) but only partially on my wife's ZVW30
    • 2.0.4 - works on both models, NHW11 and ZVW30
    User 'boppo' and I both report working versions of the hacked Techstream. However, his supplier reports a higher version and mine reports techstream 7.20.037.
  15. Faisal
    58
    2002 Prius
    I
    ok cool, so 2.0.4 is technically way better because its less bugged,right ? thanks. im almost done downloading the windows xp install. then ill be installing it to virtual pc. i bought the cable already. just needa wait for shipping
  16. bwilson4web
    16,130
    The cable should come with a disk with the drivers and Techstream on it.
    Yes, 2.0.4 firmware works on both of our Prius.
  17. Faisal
    58
    2002 Prius
    I
    yes it says that here, i got the link with free shipping that u and boppo gave me.
  18. Faisal
    58
    2002 Prius
    I
    windows xp now works on my PC [: and i have a disc now . just waitingfor the mini VCI.
  19. bwilson4web
    16,130
    As a 'virtual pc'?
    Windows XP is so full of bugs and is a favorite target for virus writers.
  20. Faisal
    58
    2002 Prius
    I
    yes as a virtual pc, i wouldnt download it as my default OS.never lol
