Toyota Prius Won't Start, P position malfunction warning
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Steven Stolle, Jan 29, 2020.
  1. Steven Stolle
    Steven Stolle Junior Member
    25
    Bellflower, CA
    We have a 2011 Toyota Prius with 294k miles. Yesterday after driving the car with the usual starts and stops, the car wouldn't startup again. The instrument display was dead. We jump-started the battery as per owner manual instructions. We used the emergency start up procedure and the car started. After driving the car for 45 minutes to recharge the battery more fully, we parked it and powered down the vehicle. We attempted to restart the car again but it wouldn't start and the display was dead. We repeated the previous procedure using emergency instructions and the car restarted. However, the instrument panel then displayed a P position malfunction warning light. The car drives normally but after shut down it can't be restarted. We can't start the car normally at all, it must be jump-started to drive it. The P position malfunction warning light appears every time. I know this sounds like a failing battery condition but what does the warning light have to do with a failing battery? The battery indicator on the display isn't showing a bad battery condition. Please help with this phenomenon. Thanks!
    j12piprius likes this.
  2. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    Twelve-volt batteries are not supposed to last nine years. It's the battery.
    Raytheeagle likes this.
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    The genuine Toyota Battery has a 84 month warranty. (Keep the receipt)
    Or get a 'cheap' battery.
    www.amazon.com/ACDelco-ACDB24R-Advantage-Automotive-Battery/dp/B010GKJ8F6
    When you turn off your Prius, it puts itself in P by battery power. (it is a 12 volt motor)
    With a bad battery, it won't successfully put itself in P, and you get your error. (There is also a risk your car could move with a dead battery)
    #3 JimboPalmer, Jan 29, 2020
    ASRDogman likes this.
  4. Steven Stolle
    25
    Bellflower, CA
    Thanks for your reply. I have a strong feeling your answer is correct.
  5. Steven Stolle
    25
    Bellflower, CA
    It was exactly as you said it was. The car works again. Thank you!
    Rebound likes this.
