Toyota really nailed it with the Prius
Discussion in 'Gen 3 Prius Main Forum' started by Mrpcar, Feb 21, 2013.
  1. Mrpcar
    Mrpcar Active Member
    542
    253
    Chino Hills, CA
    Recently there were several posts about how people drive their Prius, and why Prius driver drive the way they do. Also there were discussions on how driving a Prius really changes the way people drive even when they are not driving a Prius.
    Well, as it turned out I found myself adapting the "Prius techniques" very quickly. I think you guys know what I am refering to.
    So in the interest of science, I drove my daily driver a 2012 X5M the Prius way this whole week. And to my surprise I only managed to get 15.4 MPG combined city/highway, compared to my normal driving method of 14.7 MPG. So all the agony of getting tailgated, high beam flashed, and building up leg muscles to control myself not to floor the gas pedal only resulted me with a 0.7 MPG improvement.
    Mind you my X5M is the fastest production SUV in the world, the engine is very efficient. 4.4 liter twin turbo V8 that produces 555 horse power, which translates to 126 HP per liter. For reference with all the Formula 1 engine building technology my Ferrari 360 with a 3.6 liter V8 only makes 400HP. Which only translate to 111HP / liter, of course that was 2002 technology. Newer Ferraris are making more per liter now.
    So I was really puzzled at why I only received an improvement of 0.7 MPG in return for all that effort even with a very efficient engine. My conclusion was that weight (6000lb) and aerodynamic drag (SUV) probably played a big part as to why I didn't see a bigger improvement. In addition I couldn't harness any brake regeneration power, in other words lots of energy used to move my 6000lb SUV went to complete waste in term of heat and air drag.
    Thinking about all this waste in energy made me appreciate the Prius a lot more. I originally bought the Prius just for fun, and ended becoming a big advocate of this new hybrid technology. My wife equally loves it, when she come home at night the first thing out of her mouth is "Honey, I got to XX MPG now!"
    So I think Toyota really nailed it with the Prius in the name of engineering. A remarkable piece of machinery!
    Kore971, ralleia, OceanEyes and 3 others like this.
  2. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    In the US we measure mileage instead of consumption (how far will it take me, instead of how much do I consume to go a certain distance).
    This makes it difficult to compare consumption rates. In SI units (metric) the typical measuremts are in liters/100 km (which is consumption).
    When you babied your BMW you changed your consumption from 16.00 l/100 km to 15.28 l/100 km, saving 0.72.
    If you were normally getting 50 mpg in your Prius (4.71 l/100km) that same savings would have upped the mileage to 59 mpg.
    So while it didn't look like much in terms of mileage, by babying your BMW you saved as much as the difference between 50 and 59 mpg.
  3. Mrpcar
    542
    253
    Chino Hills, CA
    Ah! interesting, didn't realize that. Thanks
  4. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    So put a set of Ecopias on the X5M and maybe your mileage will rocket up to 15.7 mpg! :)
    Mrpcar likes this.
  5. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Actually, the most interesting thing about this thread is that you have a Beemer and a Ferrari and you are gushing about a plebeian Prius. That astounds me as passengers in my Prius have noted quite a bit of disgust at the value I got versus their superior SUV or V6 sedan. They are shocked by the amount of compromises I have made in the name of the almighty fuel economy. You sir, are a delight to read about.
    OceanEyes likes this.
  6. Mrpcar
    542
    253
    Chino Hills, CA
    Thank you.
    Well, when you already have the fastest transportation equipment at your disposal speed really doesn't thrill anymore. In someway it's too easy to obtain, just mush the gas pedal that's it.
    However I find it highly challenging to obtain the highest MPG possible without causing irritation to other drivers on the road. Which, is extremely difficult to do. I am a gear head, so I like anything mechanical and appreciate a properly engineered automobile (Not the Ferrari). I also like to be challenged, in comparison getting maximum MPG takes as much skill as turning a fast lap at Road Atlanta.
    Now, ever since I've bought the Prius my other car friends have not been going so lightly on me.... As they have no appreciation nor understanding of what makes a Prius tick.
    BTW, I swear I don't work for Toyota!
    OceanEyes and mmmodem like this.
  7. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Conventional wisdom in the other forums is that the Prius is for people who hate cars.
    Obviously some of us disagree.
  8. gus6464
    gus6464 Junior Member
    16
    My only complaint about my new Prius is I wish it had just a bit more pep sometimes and that it didn't feel like a porker sometimes in the handling department. The porker factor will be somewhat alleviated with the chassis reinforcement parts plus the lowering springs.
  9. Mrpcar
    542
    253
    Chino Hills, CA
    Yes I would agree, I wish it had an additional 30 HP at my disposal. Which is why I've been researching super charging or turbo charging solution. To my surprise nothing... available.
    As for handling, I fixed it by installing all the necessary add ons. The car handles extremely well now, almost at BMW 3 series level in comparison.
  10. fuzzy1
    10,698
    This measure, HP/liter, must not be confused as a measure of fuel efficiency. It is a measure of engine compactness, an unrelated metric.
    Go over to CleanMPG.com and read the sticky thread about 'Beating the EPA'. It has plenty of hints and tools, more than you may want or dare to apply, but you should find plenty of ideas to boost your non-hybrid MPG more than that.
    I did that for a year in my '97 Subaru (still in the household) before acquiring a Prius, and it made a world of difference. A car that originally achieved 22-25 mpg in winter, 25-27 in summer, now gets 27-30 in winter, 30-33 in summer.
    And more at high elevation, where the thinner air produces significantly less air drag. A couple weeks ago it achieved 34 mpg across Wyoming, then 33.5 mpg from Winter Park to Gunnison CO while crossing four mountain passes.
    I believe you misread the OP. He is expressing U.S. MPG, not foreign SI consumption. The liters in his figures refer to engine displacement, not fuel consumed.
    cwerdna likes this.
  11. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Not at all. He sounded disappointed at the mileage improvement he got with the X5M. My point was that he actually reduced his *consumption* by a good amount (even if it doesn't impress when expressed as mpg).
    Mrpcar likes this.
  12. billinmd
    billinmd Member
    184
    28
    Bel Air, MD
    2020 Prius Prime
    Most of the folks that I've had in my Prius remark about how smooth it is, and how it is a lot larger inside than one would expect. And strangely, with the number of cars that I've owned over the years, this is the only one that my family members have insisted that I let them know if I plan on selling it so they get first crack at it.
    OceanEyes and Mrpcar like this.
  13. mmmodem
    2,732
    1,703
    Bay Area, CA
    I know exactly what you mean. My previous cars include an Integra GSR and WRX. My friends drove a Mustang, Prelude, Miata, and a Celica. When I got a Civic with an automatic, it was like I dropped out of the gang or something. One friend went so far as to say, "No, you're not driving. I am. I can't stand your following distance and letting all those cars get in front of you." I just got the Prius and so far? Coworker's comments have not been flattering except from fellow Prius owners. My friends haven't stopped laughing since the Civic.
    I'm like you, I appreciate efficiency. I got one friend to upgrade from a Prelude to an Insight and one coworker from a Tundra to a Prius. Slow and steady...
  14. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    There is an answer today for more power and more fun to drive car : 2012 and later Camry Hybrid. Not the 2011, the '12 and later.
    new Camry hybrid has 200 total system horsepower and is quicker 0 to 60 (under 8 seconds) than the regular non-hybrid Camry, not far behind the V6 either.
    Camry hybrid is also more fun to drive - sure feels like it has a lower center of gravity, and has 'dual-link' independent rear suspension, keeping all four incontact with the ground around turns.
    Best part? Fuel gage was still pegged on 43.x MPG average ( I rented LE, not XLE which is 3 mpg less in city) after 180 miles, and a the pump it came out to 46 MPG average. I was exactly pussyfooting it either. Choice is - pump in 8 gal (Prius) or 10 gallons after 400 miles?
    Camry hybrid is a very good car. I'm tall with long legs and driver's seat a bit short bottomed for me, other than that, I like it.
    cwerdna likes this.
  15. Mrpcar
    542
    253
    Chino Hills, CA
    But the Prius is better looking, so that pretty much kills it for me with the Camry.
  16. Tideland Prius
    16,678
    An interesting read. Thanks for sharing! The mpg game does make the drive anywhere more entertaining.
  17. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    Got back from PA, Had all the power I need for passing and hill climbing up them thar moutains.:)
    DBCassidy
  18. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Yep.
    A bunch of people here have pointed out exactly what Car and Driver: Mileage? No, it's Your Gallonage that Really Counts | PriusChat has pointed out.
    To go from 14.7 to 15.4 mpg over 100 miles results in a savings of 0.31 gallons. That's similar to going from 44 to 50 mpg, in terms of gallonage (0.27 gallon delta).
    Mrpcar likes this.
  19. Mrpcar
    542
    253
    Chino Hills, CA
    So for the extra 2 buck chuck saving I decided to step on it and make people eat my dust in the "M". :p
  20. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    "So in the interest of science, I drove my daily driver a 2012 X5M the Prius way this whole week. And to my surprise I only managed to get 15.4 MPG combined city/highway, compared to my normal driving method of 14.7 MPG. So all the agony of getting tailgated, high beam flashed, and building up leg muscles to control myself not to floor the gas pedal only resulted me with a 0.7 MPG improvement."
    That's a 5% increase gained without additional expense. How much more did you want? Increasing your tp should give another bump.
