Toyota recalls 482,000 Prius and Lexus vehicles for safety issue
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by KeinoDoggy, Jun 28, 2016.
  1. RRxing
    RRxing Senior Member
    2,540
    1,815
    NEPA
    Per the recall notice (NHTSA Recall No. 16V-487) I received about a week ago:
    "Any authorized Toyota dealer will install retention brackets on the curtain shield air bag inflators at NO CHARGE. These retention brackets are designed to prevent the inflator chambers from entering the vehicle if separation occurs."
    The notice also said to schedule an appt. as soon as possible with a dealer, so I'm guessing the parts are available.
  2. Danger
    Danger Member
    175
    22
    Frisco
    I am still waiting for my notice to bring my Prius and Sienna in for the airbags. I just got a letter saying that my autos have a problem and to wait for a notice to bring them in. The notice was 4 months ago.
    51,642
  4. Mendel Leisk
    41,085
    Got my second "we're ready now" air bag notice, about a week back. Scheduled to be done this Wednesday. Several other Canadian owners have posted about getting second notice, including Tideland?
    Probably a staggered roll out.
  5. OBJ
    OBJ Member
    62
    27
    Stouffville, Ontario, Canada
    I have my appointment this Wednesday too.
  6. Rebound
    Rebound Senior Member
    3,995
    2,643
    Portland, OR
  7. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    ...and Toyota continues to install crappy, defective, dangerous Takata airbags in all their vehicles. I got the recall notice for my 2016 recently.
    Which will kill us first... the collision, or the air bag going off.
  8. DavidA
    2,344
    1,820
    Chicago western burbs
    My air bag recall service was done a week ago. I never got the second notice. I called them 2 weeks back and asked when they might be ready. The service tech said they had been doing these for a couple weeks and parts had been in stock. It took them 1.75 hours total time and they also checked the EGR valve (another recall).
  9. Coast Cruiser
    2,267
    2,571
    The article I posted a couple days ago, quoted Toyota as saying "We don't want to destroy Takata, so we continue to partner with them." Don't recall the exact words. But it also does say Toyota may consider using replacement parts from other companies.
    What's wrong with this picture... Going to the dealer and having them tear out my Takata airbag, and/or Takata airbag parts, and then replace those same parts with possibly more defective Takata components? Replacement airbags in Nissan were also found to be defective.
    I wish I could permanently disable/disconnect all the air bags in my car.
  10. DavidA
    2,344
    1,820
    The side curtain airbag recall does not replace the possibly defective air bags with another air bag. The recall has the service tech install a barrier to hopefully prevent the canister pieces from becoming shrapnel when it deploys.
  11. Coast Cruiser
    2,267
    2,571
    My recall is for the passenger seat airbag. Down by the legs somewhere? Beside the seat?
    But in my opinion, every part is questionable… Not just the bag itself, but every part and component that goes with it.
  12. ou812
    ou812 Junior Member
    40
    At Miracle Toyota in Florida now having it done.
  13. Bluegrassman
    Bluegrassman Active Member
    229
    185
    US
  14. ou812
    ou812 Junior Member
    40
    Well it took them 2 and a half hours to complete, there was no visible damage to the cars interiour aside from the colored rubber moulding around the door looked like it was slightly stretched. That's it, thank god.
  15. ChapmanF
    17,868
    This seems to be the procedure (turned up in a Google search for that $5 bracket kit part number).
    Can double as a decent set of instructions on how the headliner comes out (even though they don't take it out in the procedure, but only loose enough to work at the edges).
    -Chap
    ou812 and working1 like this.
  16. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    My VIN number doesn't show anything yet. I have to wait and see if anything comes up.
  17. ChapmanF
    17,868
    Page 4 of that procedure PDF has a table of affected VIN ranges; you could see if your VIN is in one of those. (You might notice the WMI+VDS columns account for the first 8 VIN positions and the VIS is the last 8, and there's one position in between that the table doesn't care about; don't let that throw you.)
    The note suggests that you're definitely not affected if no range in that table includes your VIN, but even if one does, there's still a chance you're not affected (it refers to a more specific "attached VIN list" that's not included in this PDF).
    -Chap
  18. OBJ
    OBJ Member
    62
    27
    Mine was done, I did not check the entire interior of the car but no visible damage. It took two hours including a complementary car wash.
  19. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    Technically, the inflator is sealed and pressure can build up from heat and crack it just from sitting, presumably with the windows up, baking the interior of the car. Doesn't have to do with deployment at all. They say it is more likely to happen to cars that aren't driven.
  20. macman408
    macman408 Electron Guidance Counselor
    1,179
    367
    You're both right. It's not an *intentional* deployment, but apparently it does at least partially inflate the airbag when it fails. Along with sending pieces of the inflator into the cabin, possibly injuring somebody (if you have a habit of sitting in your car, parked in the sun, for several hours, on a hot summer day).
