Toyota replacing coolant pump in 650,000 Prius hybrids
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by a_gray_prius, Nov 30, 2010.
  1. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Yeah, as plain as day, the recall notice stated 'pedal entrapment does not occur in vehicles with proper, secured floormats', which mine has.
    The service advisor was tricky - dropped my car off for door panel replacement (which I was glad for), they knew pedal recall not done. It was after I dropped the car off, driving my old pickup to work, the advisor called 'hey, can we go ahead and do the pedal modification otherwise you'd have to sign a waiver'. Tricky huh.
    I said, go ahead if that's how you want to do it. It's cut on the bottom, but what the heck, there's no outstanding, red flag recalls on the car.
    It's all kinda sad and senseless though. I'm sure one could find floormats that get stuck over top of the modified gas pedal.
  2. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    ^^ The dealerships are sticking Toyota with higher bills by pushing the pedal nonsense.
  3. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    I'll be one of those asking for reimbursement - had mine replaced at 104k miles in Oct 2008.
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Heck... when I took my car to a local dealer for some unrelated work a few months ago, they didn't even ask me about whether I wanted my gas pedal trimmed. They did it w/o asking and told me afterward it was trimmed. It seemed to surprise the service advisor too.
    I told them I didn't ask for it and I had concerns since some folks said their dealers did a very crude job of cutting pedals. The advisor replied that anyone who is unhappy w/the shape of the pedal can get a replacement pedal assembly for free (IIRC, it's Toyota policy), presumably shaped "right" but they'd have to order it. In the end, I was ok with it. The dealer did a pretty good job trimming and it doesn't affect drivability or comfort (for me).
  5. Prius 06
    Prius 06 Member
    283
    29
    Ontario, Canada
    160,000 kms on the 06 and the only thing ever done to it is the coolents have been changed, tires (only second set not including winters), I did the spark plugs at 100,000kms myself, and done the transmission fluid myself every 50,000kms.
    This has been the best car either of us (my wife and I) have ever owned!
    Average 1000kms per tank in the summer and about 800kms in the winter.
    It truely asks for so little.
  6. ericisbacchus
    ericisbacchus Junior Member
    91
    Kansas City
    I just got off the phone w/ Toyota, and they said to send the invoice/receipt to:
    Toyota Motor Sales
    19001 S. Western Ave.
    Dept. WC10
    Torrance, CA 90509
    Also send a copy of the title or registration.
    I'm not too optimistic on that front, though. That guy didn't really sound like he knew what he was talking about. I'm getting my damn money back...I just expect it's going to take a while.
  7. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    Update.
    Well, my memory is good, just short or behind the times. Pearl has almost 60,000 km.
    The engine water pump was changed, no leaks now so far. They splashed a bit of coolant around the engine compartment (on the cowl cover) and I need to wash off the hood under cover as it was sprayed with coolant when the pump was leaking. So they did change the pump and did try hard to get all the air out!
    I keep forgetting to look, but I don't think they trimmed the gas pedal, as I refused that. Funny though, I have a soft rubber Weathertech mat sitting over top of the stock carpeted mat. The carpeted mat is properly secured and the Weathertech is also jammed in there. It's the one intended for the passenger side, and the cutout fits tightly around the "dead pedal", so it can't move. It goes -fully- under the accelerator pedal, and it can't jam as there are no edges anywhere near it. It's a generic one, that came with the anti-Prius (2001 Nissan Pathfinder LE AWD). The service writer warned they might remove it and put it in the hatch. I said fine, whatever. They didn't move it at all. I also left the Scangauge in this time, though I unplugged it. No comment from them.
    So overall, I'm a satisfied customer. I worry too much!! ;)
  8. douglas001001
    douglas001001 smug doug
    222
    Chicago
    I have a bt tech skid plate on my 07, should I take it off before going in?
  9. saechaka
    saechaka Member
    225
    Tell me about it, I'm getting my inverter pump replaced for free after 206,000 miles. Only major service done was water pump and brake actuator.:D
  10. ggarb
    ggarb Member
    86
    Silicon Valley, CA
  11. patsparks
    10,664
    567
    Adelaide South Australia
    oops, misread post I was responding to
  12. okiebutnotfrommuskogee
    okiebutnotfrommuskogee Senior Member
    1,813
    Tulsa, OK
    Had my pump done today, also let them cut on the accelerator pedal so that all the recalls are done. No cost, no questions asked, heck they even washed and vacuumed the car for free. And its not even the dealer that I bought the car from.
  13. SureValla
    SureValla Member
    590
    Shelton, CT
    anyone know how much it should cost at the dealership to flush the ICE coolant when they do this to the inverter coolant?
    I imagine they usually charge for both in the same service so doing only ICE should cost half as much right?
  14. okiebutnotfrommuskogee
    1,813
    Tulsa, OK
    It is a totally different system. The radiator actually has two sections, one for the engine and one for the inverter.
  15. David Beale
    5,963
    1,987
    Edmonton Alberta
    The BT tech plate won't interfere with their work. They do it from above. Even if they needed to remove it, it would be easier than the stock part to remove.
  16. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Thanks for posting this. I just called and scheduled my car for the replacement. I've never had to perform repairs in this car yet (123,000miles) and I'd rather not have any unexpected ones!
  17. SureValla
    SureValla Member
    590
    Shelton, CT
    Just called Rockland Toyota in NY, the guy hadn't heard about the recall at all and when I explained it to him (kind of a weird situation) and asked how much it would be to also replace the engine coolant he said that they were on the same system and replacing the inverter would thus replace the engine.
    Has anyone actually called their dealership to schedule this yet?
  18. David Beale
    5,963
    1,987
    Edmonton Alberta
    He's wrong (what a surprise!). Two separate circuits. It's described that way in the shop manual as well. One section for the engine cooling system wherein there is no mention of the inverter cooling system. Another section for the "hybrid system", wherein they describe each of the components of it including the hybrid cooling system.
  19. tableround
    tableround New Member
    27
    Grosse Pointe, Michigan
    Clearly this is going to be an odd one.
    After reading this on Prius Chat I wanted to know if I would be reimbursed for this repair back in April '10.
    Here is their response:
    Dear Mr. Yeager-Stiver,
    Thank you for contacting Toyota Motor Sales, U.S.A., Inc.
    We apologize for the inconvenience and added expense you experienced in this matter.
    The warranty for the water pump is 5 years or 60,000 miles, whichever comes first, from the date of first use for your vehicle. Based on the VIN (Vehicle Identification Number) you provided, JTDKB20Uxxx, your vehicle was no longer under warranty at the time of repair and we do not show any Special Service Campaigns or recalls on this vehicle for the condition described. Once a vehicle is beyond the warranty parameters, responsibility for the cost of repair falls upon the vehicle owner.
    If in the future a Special Service Campaign (SSC) or recall is issued that would cover your specific concern, Toyota would review your repairs for reimbursement at that time.
    We again apologize for the inconvenience and expense this has caused you.
    Your email has been documented at our National Headquarters under file #.
    Renee Toussaint
    Toyota Customer Experience
    After calling the 1-800 number (1-800-331-4331) I was told there is a voluntary repair job for a limited time and I can have the job "re-done," or if I choose to be reimbursed I can submit materials for a judgement once I visit a dealership and have them clear my VIN in their computer system and then mail the following:
    Submit repair order
    Submit proof of ownership – registration copy
    Submit proof of payment of the invoice – copy of credit card receipt, monthly statement
    Go to dealer to clear the system showing work was done - submit this paperwork as well
    6-8 weeks later I will be informed of their decision.
  20. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Last spring and summer when Toyota was in the middle of the Anti-Toyota media blitz, and the DEATH TOYOTA media scare...Toyota came out and said they were going to change and upgrade their commitment to quality.
    You just sit back and see if you witness any real tangible change, or if it's all talk.
    I'd say Kudos to Toyota.
    Despite the complaints...they probably could of kept on ignoring this problem...and just limiting replacement to only those failures inwhich the owner complained loudly enough or couldn't be convinced it was just normal.
    650,000 coolant pump replacements might be defined by convience for Toyota as a "Customer Service" campaign...because I'm sure they don't want the term "Recall" in the headlines again...but in either case it at least it's the right thing to do for the customers.
