Toyota Safety Sense P (TSS-P)
Discussion in 'Gen 4 Prius Technical Discussion' started by GaryD1, Aug 30, 2016.
  1. GaryD1
    GaryD1 Active Member
    302
    138
    Seagrove, NC
    To become standard on all 2017 Prius? are these features where you can turn them off and on. How do owners like safety sense that come with some 2016 models? Pros, Cons
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    What features are included?
  3. GaryD1
    302
    138
    Seagrove, NC
    Toyota Safety Senseâ„¢ P 7 combines an in-vehicle camera and front-grille-mounted, millimeter-wave radar for enhanced performance and more functionality.
    • Pre-Collision System 8 with Pedestrian Detection function 5 (PCS w/PD) —Vehicle Detection & Pedestrian Detection
    • Lane Departure Alert with Steering Assist function (LDA w/SA) 9 (EPS-equipped vehicles)
    • Automatic High Beams (AHB) 6
    • Dynamic Radar Cruise Control (DRCC) 10
    Toyota Safety Sense
    Our standard Toyota Safety Sense™ P (TSS-P) 14 is an active safety package that combines the Pre-Collision System 15 with Pedestrian Detection 24 (PCS w/PD), Lane Departure Alert with Steering Assist (LDA w/SA), 16 Automatic High Beams (AHB) 27 and Full-Speed Dynamic Radar Cruise Control (DRCC) 17 to assist you. TSS-P’s comprehensive features create in-the-moment safety designed to support your awareness and decision-making on the road. Best of all, it comes standard on every 2017 Prius.
    #3 GaryD1, Aug 30, 2016
  4. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    ..........for a $500 increase in Msrp on non ATP / Non touring models that is ;)
    But yeah it's well worth the minimal cost increase I believe. I paid the extra money to get those features (plus the Moonroof and HUD) on my 2016 via the Advanced tech package. I use all the features daily! I feel they make driving safer and more enjoyable. The insurance companies seem to think so too :)
    #4 Blizzard_Persona, Aug 30, 2016
    chinarut, RCO, GaryD1 and 1 other person like this.
  5. wrprice
    wrprice Active Member
    415
    308
    Houston, TX
    Four Touring
    Most, if not every, function can be disabled if you so choose. Most are set through the vehicle information menus. Auto high-beams has a button on the knee panel. LDA has a steering wheel button but can also be disabled in the menu, I think. The steering assist can be disabled separately from the warning.
    DRCC can be "downgraded" to standard cruise control, but this must be done every time you switch the system on. You use a long press of the on/off button instead of the normal short press. I'm not aware of a way to disable DRCC by default.
    All that said, the systems are very unobtrusive and I would recommend leaving them fully enabled. While I don't rely on them for safety, I will appreciate any that they provide in a moment of need.
    chinarut, pilotgrrl, RCO and 2 others like this.
  6. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    I don't have TSS but have all the same safety features in our Outback. I do turn off the lane warnings whenever I drive on twisty/curvy roads as I prefer to "clip apexes" which means I cross or touch inside pavement lines with regularity and the audible tone warnings get real old, real fast. Default is "on" so it has to be turned off again after every engine restart.
    FWIW
    chinarut, RCO and GaryD1 like this.
  7. krmcg
    2,592
    2,392
    Whittier, CA
    I also toggle back and forth based on the road I am going to take.
  8. alanclarkeau
    7,045
    7,593
    They're all standard on even the base Australian models - and, yes, I use them all the time.
    Automatic High Beam is set by putting the High/Low beam stalk into "HIGH" position, and it automatically works out (very well) whether you need High or Low beam. Around town, I leave it in LOW, though.
    RCO likes this.
  9. Tideland Prius
    16,602
    Oh interesting. So there isn't a separate button for Automatic High Beam? (i.e. you can't manually turn on your high beam?)
    Not a bad idea considering I've seen people drive around the city with their high beams on.
    RCO and alanclarkeau like this.
  10. alanclarkeau
    7,045
    7,593
    Not that I've found - but anything is possible. Maybe if I had Headlights on manual, the Auto High Beam might not work - haven't tried it, and it's nearly midday now here, so I'll have to wait till it's dark.
  11. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    I'll rate each feature out of 10:
    Lane Departure Alert with Steering Assist: 7/10 - works well, but they shouldn't have even have the steering assist because it barely steers the car. I want the car to actually swerve back into the lane. I like the feature though. It warns you when the car thinks you should take a break from driving.
    Automatic High Beams: 10/10 - Works VERY well. The headlights (high and low beams) work very well and are bright. The automatic high beams recognize an oncoming car instantly (and instantly switches to low beams). I love it.
    Dynamic Radar Cruise Control: 10/10 - Also works very well. The car doesn't overreact when someone cuts you off. Maintains speed and follows cars really well.
    Pre-Collision System: 11/10 - This can save people's lives. It brakes for you when you're about to hit something. It works in my garage all the time. It stops the car when I'm about to hit the wall.
    I rate the whole system 10/10. I'm happy Toyota is trying to make TSS-P standard on all their cars. There are settings to turn all this stuff off.
    chinarut, pilotgrrl, RCO and 3 others like this.
  12. Tideland Prius
    16,602
    Ok. Here in North America, we have a button to the left of the steering wheel that says AUTO, along with a high beam symbol. We have to press that button and push the headlight stalk away (into high beam mode) to activate the system. This allows us manual control over the headlights (if we want to switch back to low beam for example or if it's in low beam and you want to manually switch to high beam because you're travelling in an alley with no lampposts and you're travelling below the required 34km/h for the system to work).
    Sorry I'm being pedantic but the last part about stopping the car in the garage is actually the "Intelligent Clearance Sonar" system. Cars without PCP will not have ICS and therefore will hit the objects in the garage.
    RCO, 'LectroFuel, wrprice and 2 others like this.
  13. Colin Jones
    Colin Jones Member
    99
    174
    Aberdeen/UK
    Business Edition
    Yes - that's odd - here in EU there is an auto high beam button on the knee panel. This remembers it's setting when powered off/on. If it is off, the high beam push on the stalk works as normal, if it's switched on, then you still need to push the stalk to activate the high beam mode, but it then decides itself when to switch high beam on/off after that.
    RCO, GaryD1 and alanclarkeau like this.
  14. alanclarkeau
    7,045
    7,593
    I found it - it's near to the HUD & VSC switches. And, oddly enough, it was OFF. But the Auto High Beams were working fine - in AUTO mode, at least. I haven't gone for a drive since turning it ON. Interestingly, the only reference to in the manual is on Page 20 where there is a diagram of the dashboard and switches.
    I'll test it and report back.
    RCO, Tideland Prius and GaryD1 like this.
  15. Colin Jones
    Colin Jones Member
    99
    174
    Aberdeen/UK
    Business Edition
    You don't have a partner do you? My wife sometimes stabs randomly in that area (or hits it with her knees, as she is short and has the seat really far forward!) when reaching for the power switch. On occasion I come back to various permutations of HUD settings/Auto headlights after she's been driving. :)
  16. alanclarkeau
    7,045
    7,593
    No, sadly not any more. Only 2 dogs, and they've yet to go for a ride in the new car - much to their annoyance. I have a back seat cover which I fit which they sit on, and I need to modify it slightly for the different spacing of the seat belt holes.
    RCO likes this.
  17. GaryD1
    302
    138
    Seagrove, NC
    I would like to know, how the high beam does when you approach a vehicle from behind? Do they dim automatically?
    RCO, 'LectroFuel and alanclarkeau like this.
  18. wrprice
    415
    308
    Houston, TX
    Four Touring
    Yes, generally speaking. The camera recognizes tail lights ahead of you. Though if it thinks they're far enough ahead it will use the brights.
    RCO and 'LectroFuel like this.
  19. MichelleStone
    MichelleStone Senior Member
    549
    818
    Mariposa, CA
    I like all the features. I do wish the Lane Keep Assist were more robust. It doesn't kick in until I've already crossed the lane line by about 12 inches. But that's fine. At least I know the limitations. Everything else seems to work well although I haven't driven at night to see if my auto brights work.
    Pros? These things will help me from wrapping my car around a tree or worse. I think I got a discount on my insurance too.
    Cons? I can't think of any.
  20. 'LectroFuel
    880
    673
    Yes, they dim, just like an oncoming car. It also recognizes the back of cars, too. That's why so many people leave on the Auto high beams all the time.
    Same with me. It also recognizes cracks in the middle of the road as a lane marker, so sometimes, it just gets annoying.
