Toyota Sat Nav routing
Discussion in 'Gen 2 Prius Audio and Electronics' started by Prius_SGP, Jun 30, 2008.
  1. Prius_SGP
    Prius_SGP New Member
    58
    Saint Genis Pouilly, France
    Hi
    Ok real newbie question here - I have tried to find the answer on the Net, the forums and using the search tool but still not been able to find it.
    I'm still awaiting my Prius but found a great site that demonstrates the functions of the Sat Nav : Toyota Navigation System
    What I've not been able to confirm, is whether the nav has auto route adjustments? i.e. If I make a wrong turn or miss the exit, does it reroute without you needing to do anything? Or will it just shout at me to turn round? :confused:
    Unfortunately the test model didn't come with nav so I wasn't able to test it fully.
    Cheers.
  2. Marvinh
    Marvinh Marvin
    189
    NY - Long Island
    Yes! It has auto route adjustments. Just make a wrong turn and it will re-calculate. Marvin
  3. Prius_SGP
    58
    Cheers Marvin.
    Had a horrible thought that it was like my fist GPS where I needed to re-enter every time.
    Pheww
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    Jill will keep nagging you until you get back on track. The rerouting is very fast, almost instantaneous. The factory nav system works well, but the user interface is a bit different than Garmin's and Tom-tom's. I like it just fine, but some people never adapt to it.
    Tom
  5. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    Yes, it does re-route if you make a wrong turn, or choose not to follow it's orginal guidance. But I have found it trys to get you back on the original (often poor) route for way too long, instead of recalculating a better route in the direction you are driving.
    If you have ever used or owned a garmin unit, you will be sorely disappointed with fact. nav. Neat integration, poor operation.
  6. KayakerNC
    KayakerNC Member
    399
    Eastern North Carolina
    I have a Nuvi200W, so it may not apply, but when I make a turn and "The Lady" gets stubborn and wants me to turn around, I hit "Detour" and she is happy and will re-route quickly.:car:
  7. Joekc
    Joekc Member
    265
    16
    The most common command I get when I miss something is "Please make a legal U-Turn." This occurs even when a legal/illegal u-turn is not the best solution. As my signature suggests, I'm not a big fan of the Nav system, having used Garmin previously and loved it.
    I've done a lot of testing in areas I know well and the routing is seldom perfect and often bad. I know to ignore it when it tries to send me into bad areas, but I worry about traveling in unfamiliar cities.:(
  8. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    One thing I've taken to doing is setting my destination while sitting in my drive way, then suspending navigation. I know how to get from my house at least 95% of the way to my distination and don't need HER nagging at me over a route I know. When I get close (a few miles away) I resume navigation. The route is plotted from my current location fairly quickly and I get guided to the address I'm going to.
  9. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    I'm having no problems with the NAV until the Lady starts in on me... "You never listen to what I tell you, do you?" "I said Make a legal left-turn"
    "Are you listening to me... Helloooo?"
    "See? Now we're lost, I told you so..!"
    ZC1
    Data Daedalus likes this.
  10. Joekc
    Joekc Member
    265
    16
    Sounds like you're talking about the Lady sitting next to you ;)
  11. aaf709
    3,862
    2022 Prius Prime
    The only time I had the "make a legal U-Turn" happen to me was when I was out in the boonies near Fallbrook. I found out later it was because part of the road was on a military base. I was allowed to be there, but the car didn't know it.
