Toyota Sees Even Split Between Prius Batteries (NA/Japan)
Discussion in 'Gen 4 Prius Main Forum' started by spwolf, Nov 10, 2015.
  1. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    Toyota Sees Even Split Between Prius Batteries | Asia Pacific content from WardsAuto
    usbseawolf2000 likes this.
  2. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    Would be a bit annoying for us in Europe if the li-ion offers more EV-Range than the Ni-MH .
  3. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    Li-ion has even less capacity than NiMH, the question is does it provide better fuel economy (charge/discharge losses) or longevity?
    I doubt it.
    I think it just has to do something with production capacities, with time they will go 100% li-ion because it will be cheaper.
    Pale Fox likes this.
  4. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    For the "standard Prius" the Li-Ion is smaller in capacity and lighter in weight. Toyota will probably use the weight difference to off-set models that push their weight limits due to options. The capacity would probably have little effect (it's not an EV). I'm told Li-Ion charges more efficiently and perhaps discharges in a similar manner. This may be why it has a smaller capacity. Because it will still work just fine with a smaller capacity. Again, the "standard Prius" IS NOT an EV. EV operation is just a bonus. Expecting better EV range is out of reality for this model of Prius. Get a PIP if that's what you want.
    I concur that it is probably just because of production capacity and may also be related to "learning" how it will perform in the real world. I would expect to see the Li-Ion mostly where Toyota have development engineers to monitor it. If the Li-Ion performs well I would expect to see it supplant the the NiMH totally - eventually.
  5. GasperG
    1,169
    601
    Slovenia
    2018 Prius
    Europe got their share of Li-ion in Prius+ ;)
  6. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Does this mean that the ECO model will not be offered in Europe?:confused:
  7. GasperG
    1,169
    601
    Slovenia
    2018 Prius
    Who said that the ECO model must have Li-ions?
  8. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    In Japan it is and make sense due to weight.
    The UK line-up as published does not include one.
  9. Trollbait
    12,831
    Reported curb weights for the trims in Japan. It appears the ECO used max weight saving there to be able to use a lower dymanometer resistance during the JC08 test.
    Based on those curb weights, it appears NiMH is limited to AWD equipped models.
  10. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Completely wrong conclusion.
  11. Trollbait
    12,831
    What? Ken{some number} posted the curb weights for the trims available in Japan. From that list, it can be seen that only the AWD models had NiMH.
  12. civicdriver06
    797
    324
    Germany
    Up to now it looks like that as allways there are only 3 trim levels available for Germany and according to Toyota UK there will be no sun/moon roof option for Europe!
    What a stupid and absolutely no sense making decision by Toyota !
    It will "scare" potential customers away to other car makers who do offer a sun roof and will make gen 3. owners with solar roof stick with the current model instead of upgrading to gen. 4 !
    Sometimes I just don't get it !
    The 3 Options in Germany are :
    Prius
    Prius Comfort
    Prius Executive
    #12 civicdriver06, Nov 15, 2015
  13. civicdriver06
    797
    324
    Germany
  14. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Wrong.
    According to ken1784 S model 2WD in Japan will have NiMH.
    According to Toyota UK all 4 trims are 2WD and according to the original post here they will have NiMH.
