Toyota Service Centre Gave Up - Engine Not Running
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mother, Oct 14, 2024.
  1. Mother
    Mother New Member
    Australia
    i-Tech
    2011 Toyota Prius iTech, 130,000 kms (Australia)
    ICE cranks but does not fire up
    Fuel smell
    EGR valve and cooler sooty, cleaned
    Delivered to local Toyota Service Centre
    Scan reports ‘Low Power’, no other recurring faults
    Injectors cleaned
    Plugs inspected, OK
    Fuel filter replaced
    E10 fuel drained and replaced with 98
    Injectors removed and operated, spray OK
    HV battery down to 1 bar
    Toyota Service Centre unable to get engine running, cause unknown
    Awaiting ‘Rescue Charge’ from Toyota Australia
    HELP
  2. Eddie25
    Eddie25 Active Member
    503
    213
    MI
    What is the low power code, P3190?
    Basically your ICE isn't able to start but the HV battery was still able to attempt to start it, but it won't 'catch' and keep itself running on it's own. I'm guessing the "rescue charge" means that the HV battery is depleted and won't even attempt to start it anymore.
    Essentially it just needs a proper "crank, no start" diagnosis (fuel, air, compression, timing, etc).
    The first thing I would do as a complete amateur would be the age ol' 'spray starter fluid into the throttle body' while (or before) trying to start it. If you can get it to stay running a bit like that you know you have a fuel issue. If nothing there I'd check for spark and after that compression. I'm sure I'm missing something, but it shouldn't be that difficult as long as you have a way to charge the battery every few start attempts. You may also have to charge the 12v.
    They'll probably be able to figure it out once it gets it's "rescue charge", but if not try to find a real mechanic or a hybrid specialist and if you have to, then build a charger yourself. It's pretty crazy how inept and un-equipped a lot of dealers seem to be.
    Edit: the "smell of fuel" would probably change my first action from 'checking for fuel' to 'checking for spark' since that's probably from fuel just not getting burned.
    Brian1954 and BiomedO1 like this.
  3. BiomedO1
    BiomedO1 Senior Member
    4,628
    2,425
    Left Coast
    I'm assuming the engine doesn't start or even idle. Check for 12Vdc power going into ignition coil - No voltage, no spark, no ignition. Check all your fuses and look over your wiring harness for chew marks and exposed wires.
    Open the Air box @ the air filter - leave everything in place. Don't want to suck something into the intake manifold. You can also inject starting fluid there.
    How much oil consumption per oil change interval were you experiencing before the motor quit? Have you kept up with factory recommended maintenance intervals? Has the 12VDC battery been checked and verified fully operational?
    I would move onto compression test if no other problems are found.
