Toyota Shows Distain: Even for their Own RAV4-EV
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by hill, May 6, 2014.
  1. inferno
    inferno Senior Member
    1,072
    405
    Hate to play devil's advocate but I'm envisioning highways of traffic filled with FCV. All that water vapor, really wouldn't cause any problems? Any vapor going to the atmosphere is bound for trouble. Especially in massive quantities. Build an artificial rainforest, it'd effect earth's climate. However, all those cars will produce more climate than a rainforest.
    Sounds like a good movie, but obviously a far-stretch right now in even the next decade. Like yous aid, we're already shooting many nasty things in the environment.
    Ultimately, if there''s a great battery tech...
  2. DrPepperholik
    DrPepperholik Active Member
    342
    108
    Spartanburg, South Carolina
    This is what I envisioned and I thought it sounded like a great movie or a book. Kind of like WALL-E but with pollution not garbage.
    I pictured California with the smog problem but instead of smog it's all water vapor.
  3. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    I'm not a fan of hydrogen for personal vehicles, but water vapor is just not an issue.
    First, the amount of water vapor is not much more than the water vapor produced by gas autos.
    Second, water falls out of the atmosphere quite quickly, hours or days vs decades for CO2.
    There are a bunch of reasons hydrogen is not workable, water vapor isn't one of them.
    3PriusMike likes this.
  4. 70AARCUDA
    70AARCUDA Active Member
    845
    209
    Tucson, AZ
    Like the constant drizzile in Los Angeles depicted in the move BLADE RUNNER?
    #244 70AARCUDA, Jul 22, 2014
  5. Zythryn
    6,408
    4,407
    7 pounds of H2O are produced from burning a gallon of gasoline.
    Burning 1 Gallon of Gasoline Produces 20 Pounds of CO2 - by blinkin - Newsvine
    Looks like hydrogen fuel cells will generate about 3 times as much water, about 20 pounds per kg of H2 (which is equivalent to a gallon of gas).
    So if 33% of our vehicle fleet became FCEV, you would have an equivalent amount of water as today.
    Or, if 67% of our light vehicle fleet were electric! and the other 33% FCEV, you would have the same water emissions.
    If 20% of our LVF moves to FCEV and 80% to EV, it would be a net loss of water vapor emissions.
    I just don't see it as an issue, especially since I don't ever see FCEVs getting more than 1% market share nationwide.
    #245 Zythryn, Jul 22, 2014
  6. dipper
    dipper Senior Member
    1,242
    252
    If only FC can fix CA's drought problem.
    Even when the rainy seasons come back, CA will still be out of water. People are moving in and large condos/apartments (with new homes of course) are being build every where. H1b Visa are given out like Candies. And foreign investers are buying homes with cash since their money are worthless at home.
    As a result, water is used up. Dams are being destroyed to satisfy fish and environmental groups.
    I am all for FC if only they fix CA water issue as a by product.
    OR
    The water vapor destroys CA Mediterranean weather. Becomes Florida like. :D
  7. austingreen
    austingreen Senior Member
    13,672
    4,210
    Austin, TX, USA
    You have to remember that hydrogen is very costly to transport, and that its production takes water. That means that most production will be local - Southern California, but will require water is pumped to southern california. If the reaction CH4 +2O2 -> CO2 + 2H2O would solve southern California's water problems then they should build less efficient but inexpensive ocgt natural gas generaters (peaking plants) and stop importing power where they want the water vapor.
  8. wjtracy
    wjtracy Senior Member
    11,367
    3,608
    Northern VA (NoVA)
    In the news today. Linde starts shipping H2 fueling stations.
    Linde opens Vienna hydrogen station | News | gasworld
    The ionic liquid compressor is a new idea. Interesting.
  9. bwilson4web
    16,204
    Uh Oh!
    At those pressures, a catastrophic failure would resemble a grenade going off. Ask a submariner . . .
  10. hill
    8,803
    If you mean like the subariners on the Kursk? They're silent on the topic.
    Curiously, the good folks at Linde seem to have forgotten to mention what kind of volume (Liters) of hydrogen they're boasting about ... and what kind of heat is generated when hydrogen gets compressed to > 14k Lbs psi.
    But here's my favorite part of the article;
    OK, that production / time line number will be hit in 50 months ..... tens of thousands (minimum of 20,000) of hydrogen cars. ...... these "experts" are saying they'll be putting out 400 hydrogen cars a MONTH .... if they start producing cars right NOW today. Hydrogen cars are priced at a heavily subsidized price of ~$70,000 .... that's high - especially considering GM's European Volt/Ampera sales are light years lower than 400 month ... yet the Ampera is something like $30,000 less than a fuel cell car!
    Who ARE these experts ??
    Crap Ampera sales numbers means the Ampera gets the ax .... Volt is "no-mas" in Europe.
    DailyTech - Report: The Chevy Volt’s European Twin, Opel Ampera, Gets the Axe
    Like Toyota 's disdain for plug-ins .... you have to ask yourself .... Is GM following suit by showing disdain for its plug-in as well?
    #250 hill, Jul 23, 2014
  11. austingreen
    13,672
    4,210
    Austin, TX, USA
    If you simply compress it
    PV = nRT, P = nRT/V. Since we are attempting to fill to 10,000 psi (700 atmospheres) at room temperature 273 kalvin, I would assume that the temperatuere would be less than 383 kalvin to get enough quantity of gas into the car. Its likely that there is some cooling system to remove the heat of compression. Typical values for lower pressure fills take about 3kwh of electrity to compress 1kg of hydrogen enough to fill a tank to 10,000 psi.
    I don't know, who the experts are but CARB has predicted 53,000 fcv by 2017 in california alone. Lentz from toyota recently said in the fortune interview 10,000 in that time period, and it sounded like he meant from all manufacturers.
    In Japan, METI has aproved a 2 million yen subsidy, so a toyota fcv will cost 5 million yen or just under $50,000. In the us hyundai is leasing fcv for $2999 down and $499/mo including fuel and maintenance, hyundia now reciewves $8000 federal, $5000 state ($13,000), plus 26 zev credits for each vehicle leased this year in california. Who knows how high incentives in europe will go.
  12. Trollbait
    12,528
    I think it's more just import duties and greed concerning EU incentives that lead to the end of the Ampera instead of disdain from GM. It is disappointing that the Spark EV remains a compliance car, but there isn't any visible disdain from GM towards the Volt in the US.
  13. wjtracy
    11,367
    3,608
    Northern VA (NoVA)
    I guess due to extreme high fuel taxes, I would say in Europe you get a lot more alternate fuel ideas being tried.
    Oh man, PV=nRT, you guys force me into the text books, don't forget H2 has a positive Joule-Thompson coeficient which is unusual means it heats upon decompressing...now I gotta check into this. In the small flow rates we are talking about, there will be lots of heat losses in the piping that will tend to keep things at room temp. But holy heck, Linde is not going to distribute fundamentally flawed H2 units globally if H2 FCV has any hope to succeed. We know Toyota sweats the robustness details on making sure auto technology is ready to be beta tested by consumers.
  14. austingreen
    13,672
    4,210
    Austin, TX, USA
    wjtracy, you quoted hills post. but then addressed my answer.
    Hydrogen (H2) being a diatomic gas follows the idea gas law for compression of diatomic gases, which means PV =nRT and Pf = Pi power( (Vi/Vf), 1.4). If we know the change in volume we can tell the change in temperature. Now linde or whoever is compression the gas can cool it to come back to initial temperature. In that case Pf/Pi = Vi/Vf. In any case it take energy to compress the gas, and unless you can use the heat and pressure some energy is wasted. This is approximately 3kwh /kg of 10,000 psi hydrogen. The limiting factor on how many cars can be filled a day is dependant on how fast you can compress and cool the gas. Typically in california its only 25 cars a day. For faster fills they use liquid hydrogen, which takes more energy per kg.
  15. 70AARCUDA
    845
    209
    Tucson, AZ
    Ah, but (so far) you've ALL missed one very important aspect....Vienna is in europe, not in USA, where WE ( well, me, specifically ) are located!
  16. El Dobro
    El Dobro A Member
    7,088
    3,270
    There will be a replacement.
    General Motors Confirms Death Of Opel Ampera
  17. 70AARCUDA
    845
    209
    Tucson, AZ
    ...my translation of his (Karl-Thomas Neumann) words: '...after this turkey we'll try a cheaper pidgeon...'
  18. hill
    8,803
    So I go to the link to find out what the replacement will be - only to find nothing. GM double speak / translation? .... I'm going to guess the odds on favorite will be GM replacing it with another diesel fuel burner - for which EXXON will thank GM mightily
    Meanwhile - should the hydrogen lobby gain a bigger toe hold in the E. U. - EXXON will make an even bigger boat load of cash, by hocking our NG (& Canadian tar sands) for hydrogen distillation. To further round out the irony, Toyota's head honcho just had an unusual admission recently;
    Toyota Admits It'll Take Until 2030 to Make Fuel Cell Vehicles Cost Competitive With EVs | Inside EVs
    Removing double speak - he's saying FC's have NO chance of competing w/ plug-ins for AT LEAST another one & a half decades .... best case scenario - even with huge credits/taxes/incentives. That of course will require the manufactures to continue limiting plug-in's to Pigeon hole markets, running negative PR campaigns, & halting/stalling further development of their plug-in programs.
    And now, for the final irony. The NASA engineer & author of "The Hydrogen hoax" pointed out long ago that hydrogen cars need 5 miracles to occur in order to ever bring about FC transportation. Yet the FC R&D lobby (ever since the 1970's) continues to promise, "in just 10 more years".
    In case anyone is keeping count, this makes false promise number SIX. man ... are we gullible? ... or just stupid.
    #258 hill, Jul 23, 2014
  19. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    The wording from the GM exec said to expect a replacement vehicle in the electric vehicle segment [my italics]
    Spark, anyone ?
    Anyway, the exec was IMO just admitting what is obvious: the Volt is a flop in Europe. I'm not at all surprised to read that they are not going to try and sell the Volt 2.0 (presuming that sees the light of day.)
    #259 SageBrush, Jul 23, 2014
  20. 70AARCUDA
    845
    209
    Tucson, AZ
    First, there was GM Chevrolet in europe...which failed...strike ONE.
    Second, there was GM Ampera (metric Volt) in europe...which failed...strike TWO.
    GM needs to get it's ACT together in managing european products...or find "fall-guys/gals" for impending strike THREE.
