Toyota: Solid-State Batteries by 2020
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Jeff N, Mar 12, 2013.
  1. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Here's a link to the typically confusing article:
    Toyota: solid-state batteries coming in 2020, 3-4 times better than li-ion
    The original source is behind a subscription pay wall so who knows how badly jumbled that was.
    Despite assertions in the article, "solid-state battery" likely refers to a Lithium-ion battery that just has a solid rather than liquid or gelled electrolyte. Lithium Air batteries are also a type of Lithium-Ion battery. Lithium-ion batteries don't use rare earth metals in any significant quantity (NiMH do).
    I wouldn't be surprised to see solid electrolyte Lithium-ion batteries being used in production cars by 2020 but I doubt they will be 3-4 better than non-solid electrolyte Lithium-ion batteries in the same timeframe. They probably be about the same but perhaps offer safety advantages or packaging improvements.
  2. Scorpion
    Scorpion Active Member
    440
    162
    Lincoln, NE
    When they say "3-4 times better", I wonder what they actually mean. Energy density? Specific energy? Power output? And most important......cost.
    If I'm not mistaken....there is a virtuous upward cycle whereby if you double energy density, then even if those cells cost 50% more, you are still coming out ahead, because you'd need less than half as many for a given EV distance, after factoring in reduced weight.
    Maybe this is a misdirection from Toyota, and they are waiting for the EV-95 battery patent, shelved by Chevron, to expire end of 2014? It seems that would be the path to truly affordable PHEV's, since they beat Li-Ion in cost, and the higher specific power output offsets the modest weight gain.
    One can hope :sneaky:
  3. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    The NiMH patents were freed from the evil hands of Chevron around 2009 and are now apparently owned by BASF.
    The literal EV-95 battery used in the old EV Rav4 is quite a bit heavier than the current generation Lithium-ion packs used in EVs today. It also is dependent on rare earths which may be subject to supply issues. There have been improvements in NiMH design since then but I think the consensus is that NiMH is unlikely to be able to keep up with the near-term improvements in Lithium-ion design which are leaving the labs for commercialization over the next few years.
    The improvements for Lithium-ion for EV use are mostly focused on energy density by both weight and volume. Higher density means fewer cells for larger capacity packs and therefore lowers costs due to raw materials and manufacturing overhead.
  4. austingreen
    austingreen Senior Member
    13,713
    4,231
    Austin, TX, USA
    My guess? These are some form of lithium polymer (lithium ion that uses gel or solid electrolyte). We have had these for about 2 decades.
    One problem with these types of batteries is they don't work well in very low temperatures. That may require a liquid or resistance conditioning circuit. This is not really a problem in a phev. When compared to the power to volume of the current prius phv battery, a lithium polymer might get 3 -4 times the power in the same space. That really could help with regen braking. The goal seems to get cost to the car makers down to $200-$300 /kwh which definitely seems doable in the near future. My laptop has a lithium polymer battery, so does the sonata hybrid. I'm sure toyota is talking about a different chemistry, but these things are not that far out in the future. Lithium air will take a long time to make it from the lab to cars, I would say at least a decade.
  5. austingreen
    13,713
    4,231
    Austin, TX, USA
    Its an urban myth that these ovonics cells are so much better. The tesla pack in the current rav 4 ev, are much better than the ovonics cells in the original rav4 ev. We have an apples to apples comparison available.
  6. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    I am thinking the old (Chevron) patent issue on large format NiMH is dead now that Li batts are king. I am dubious Toyota would officially say something like that article purported.
    austingreen likes this.
  7. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    Can't yet to see what they come up with! Google
  8. austingreen
    13,713
    4,231
    Austin, TX, USA
    Thanks that confirms that solid state means they are working on a lithium polymer battery (which is a form of lithium ion). Since it is so far out there, seven year it must be significantly different than current lithium polymer. I am thinking the 3 to 4 times is for the batery pack. In the prius phv the 4.4kwh is 80 kg or 55 wh/kg. I would expect this new pack to be at least 3x or 165 wh/kg. The 41.8 kwh battery pack in the rav 4 ev weighs 380 kg or 110 wh/kg. That makes the 165 wh/kg definitely doable. A start up using US government research and partially funded by gm has a battery pack with 200 wh/kg working in the lab. Let's say we want a 8 kwh for the 2020 prius phv to give a 25 mile aer range (scaling from the c-max and volt). That pack at 165wh/kg would weigh 49 kg, much lighter than the 11 mile pack in the current pip. It also would likely be able to supply 100 hp of power electrically to the motors. That would be a huge improvement. I'm thinking that that battery pack in 2020 would cost toyota about $2500.
    Sergiospl likes this.
  9. Sergiospl
    3,938
    1,351
    28
    Would like to see a 20-25 mile ev range for next Gen, but not at the expense of cargo space.
    2016 will be a very interesting year if Volt 2.0 or EV2 comes out with improved battery Pack, say 45 ev range.
  10. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    ...3-4x more power? what is Toyota talking 0 to 60 in 25 miliseconds...get me a G-suit!
    PS- lovely color on that Lexus
  11. austingreen
    13,713
    4,231
    Austin, TX, USA
    I'd love it if it worked that way. If I read the second article correctly, they are talking about getting the energy density up from 55 wh/kg (prius phv) to 165 wh/kg - 220 wh/kg. At the lower end of the range that would let toyota drop a battery with more the twice the range in that 2020 prius phv and drop the weight at the same time by 31 kg - 68 lbs, making it weigh roughly what the non plug-in weighs. In order to get more power to the wheels, you need a more powerful mg2 also, but it would be a small change. To cut 0-60 times in half you need to roughly quadruple hp,
    The press release is not all that interesting in terms of toyota doing something really different. The Tesla/Panasonic battery pack in the RAV4 EV is at 110 wh/kg. Toyota had been talking down battery improvements. This gets them more in line with Tesla, Nissan, and GM on expecting battery improvements. Here is the envia promised battery release
    One Step Closer to Game-Changing Electric Vehicle Batteries | The Energy Collective
    That is something that may perhaps make it out in 2016, the energy density is also for the battery, not the whole pack, so discount those figures a little. There are risks of commercializing it and keeping those densities, but lots of other chemistries are possible. Getting 3 times more than the current prius phv battery energy to weight seems quite conservative.
    Sergiospl and wjtracy like this.
  12. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    Does anyone know in general if the charging equipment, etc is typically compatible with the various Li- battery tech? I'd love if in 10 yrs you could swap to the more dense battery technology in a current model PIP without having to change much else.
  13. acdii
    acdii Active Member
    1,124
    131
    Lion, Life, Lipo have different cell voltages, so no you cant interchange charging systems without adjusting for the cell voltages. Charge a Life pack at Lipo rates and you will kill it, charge a Lipo at Lion rates and it will never fully charge.
    The one thing that scares me about Lipo packs is their ability to burst into a VERY hot flame when damaged or over/under charged, shorted. When properly cared for, very stable, but do one of the above to it, and it will go up in flames rather quickly and produces a nasty hot flame. I hope they package them well in the Hyundais.
    Oh forgot to mention, charge any Li battery with a NiMh charger and it will kill it, may even cause it to go boom.
  14. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    True if you charge an individual cell (differente voltage), but if you talk about the whole battery pack with same nominal voltage and with BMS integrated in the pack, I think you can charge it with the same input. Am I wrong?
  15. acdii
    acdii Active Member
    1,124
    131
    Depends on the BMS, but in theory, you may be able to. It is just voltage and current. The BMS is what keeps it from going BOOM. As long as you dont overdo the input voltage, it should be OK. The BMS should regulate the current put into the pack. It is usually the amount of current put back into the pack that can kill it. On the RC packs, its the C rating, if you put in more current than the C rating of the pack, you can expect the pack to live a very short life. A 1 C rating means you can put in roughly 10% of the Mah for the charge rate. So a 3300 mah pack at 1 C is 330 mah charge rate, or .3 amp.
    Since the car packs are designed to dump huge amounts of current back into them on a regen, it really shouldnt be a problem then, as long as the voltage is kept under the max rating. for Lion, no more than 4.2 volts per cell max, go over that and those cells will pop.
  16. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    I assume the EV elec motor uses its fair share of rare earth metals? Not that it matters to me, just saying that's not necessarily big deal in battery choice.
  17. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Right, it's not a huge deal but there has been some uncertainty in near-term supplies in the recent pass.
    The EV motors typically do use rare earth metals in their permanent magnets but Toyota has made noise about researching alternative motor designs and Tesla already uses inductive motors that don't use rare earth metals.
  18. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Lipo (Lithium-ion polymer) describes one aspect of the electrolyte used to separate and transport the Lithium ions between the cathode and anode. The characteristics you are describing above like voltage levels and temperature stability (fire!) are mostly determined by the chemistry of the cathode and anode and not the electrolyte itself.
    A typical Lipo cell uses the same liquid electrolytes used in most Lithium batteries but solidifies or gells it with plastic polymers (like polyvinylidene flouride, according to Wikipedia) to stabilize its movement within a pouch cell for mechanical packaging reasons.
    Life (Lithium-ion Iron Phosphate) cells are just a type of Lion (Lithium-ion) cathode chemistry based on Iron rather than Manganese, Cobalt, Nickel or some combination of those.
    Lion, Life, Lipo would therefore typically describe a single cell voltage which is the voltage of a Lithium-ion Iron Phosphate cathode paired with a carbon anode.
  19. acdii
    acdii Active Member
    1,124
    131
    All three have different voltages though, you cant charge a Life at a Lipo voltage or rate, or Lipo with a Lion rate. The only one that does tend to go up in flames are the Lipo packs though, I have had a lion pack leak, but no fire.
    Just an idea how quickly a damaged Lipo can burn. Same thing can happen if over charged, even over discharging beyond its capacity can cause similar results.
  20. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    No, you are mixing and matching different concepts in a way that doesn't make sense.
    There are a lot of confusing articles about batteries (including on Wikipedia) that describe "Lithium Polymer batteries" as if they were some kind of fundamentally different technology from "Lithium-ion batteries". However, as far as I can tell after reading a wide range of research papers and books on Lithium-based batteries, that's just confusion and bad terminology. If you have links or citations that say otherwise I would like to see them.
    Cell voltage is a result of the voltage potential between the chosen cathode and anode materials and has little to do with the type of electrolyte.
    Google: "define lipo"
    A clear description of what I'm getting at can be found here:
    Li-polymer Battery: Substance or Hype? – Battery University
    I suspect the lipo cells you have used are Lithium-ion Cobalt (LiCoO2) (same cathode chemistry used in Boeing 787 and Tesla Roadster) which is widely considered to be the least temperature stable Lithium-ion cathode chemistry. Their intense flameouts are not primarily due to whether or not they use polymerized electrolyte. The cells used on the 787 appear to use a prismatic construction with non-polymer electrolyte.
