Toyota Super Long Life Coolant
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Erik K, Jan 3, 2016.
  1. BruceInOKC
    BruceInOKC Member
    190
    Oklahoma City, OK
    Thanks, Mendel and CR94.
  2. genonervo
    genonervo Junior Member
    Boone, NC USA
    This coolant meets Toyota specs at walmart online; Valvoline Asian Vehicle Formula Antifreeze 871668 was $8.38 a few days ago now $11.97.
    I'm new...says I can't post links yet.
    • Silicate free, phosphate Hybrid Organic Acid Technology
    • Provides protection of 5 years or 150,000 miles
    • pre-mixed 50/50.
    • Color is pink
    j12piprius likes this.
  3. Mendel Leisk
    42,332
    Somebody's making Toyota''s coolant, and possibly they're also retailing it under another name, cheaper. Or what they make for Toyota might be unique.
    All considered, not worth gambling. Same story as the transaxle fluid. And for me even the brake fluid, it's a once in a while, trivial expense.
  4. Mendel Leisk
    42,332
    I'm starting to catch on, lol. You've posted the same message in three threads.
  5. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Thank you so much for this bulletin! I have been accidentally using the red to top off our '12 Prius v and was panicking today when I realized there might be a difference!
  6. jack black
    jack black Active Member
    225
    142
    I
    to be fair, the memo talks about pink LLC used in japan that may not be the pink SLLC available in USA.
    if your top off was small, that shouldn't be an issue. being in CA, distilled water is fine for small top offs, especially if evaporation and no leaks..
    for the record, i used zerex asian in mine. the valvoline flavor is cheaper, but blue.
    the best bang for the buck is this: OEM Concentrate, Extended Life, Radiator Antifreeze Coolant, Pink | 879899 | Pep Boys
    #46 jack black, Jan 18, 2018
    j12piprius, mjoo and jzchen like this.
  7. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Thank you.
    So Zerex is not Valvoline? (I thought it was. Very confused)!
    So far the difference I saw, not reading every bread crumb of this thread, is that red that I had in stock for our '04 Sienna has diethylene glycol, in about 4-5%, which diluted would be 2 - 2.5%. Whether significant, I have no clue....
  8. jack black
    225
    142
    I
    the difference is in the anti-corrosion additives. LLC is good for 3 years, SLLC is for 10 years.
    jzchen likes this.
  9. JC91006
    16,936
    8,647
    Best bang for the buck stuff comes from valvoline asian formula sold at walmart. $11.99 everyday and often goes on sale for $8.99.
    j12piprius and jzchen like this.
  10. jack black
    225
    142
    I
    have you clicked my link? it's $14.90 for the CONCENTRATED antifreeze and not the diluted one. not every store has it in stock though, but i just purchased 2 gal for prius and another toyota.
  11. JC91006
    16,936
    8,647
    I didn't click your link, but usually the CONCENTRATED stuff is good for only 30,000 miles, the premix stuff is usually good for 50,000-100,000 miles
  12. jack black
    225
    142
    I
    if you didn't click then you don't know this concentrated is extended life, "up to 150,000 miles or 5 years."
    CR94 likes this.
  13. JC91006
    16,936
    8,647
    I did say "usually" concentrates are like that. Example: Toyota coolants.
