Toyota to add solar panels to Prius hybrid: Nikkei
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by lob, Jul 6, 2008.
  1. theoriginalwheelstv
    theoriginalwheelstv New Member
    I don't know about solar panels but my dealer sold me a wind turbine.
  2. priusenvy
    priusenvy Senior Member
    1,765
    Silicon Valley, CA
    You know that's a perpetual motion machine you've got there, don't you? Just give the Prius a push, and the blade starts spinning, generating power for the Prius, which then moves under its own power, causing the blade to spin faster , generating more power for the Prius, causing the blade to spin even faster, etc...
    I power my Prius with a cat with a piece of buttered toast on its back. Simpler and less costly than your wind turbine approach.
  3. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    If the A/C has it's own dedicated battery, and it charges while your Prius sits in the parking lot all day, you should be able to power the A/C compressor for the 10 minutes it takes you to drive from work to lunch each day, right? (charge that occurs after lunch will be saved for the next day's lunch drive)
  4. Tideland Prius
    16,547
    Audi had the A8's A/C run off solar panels built into the size of the moonroof. Toyota has it covering the roof which is larger than a moonroof so yeah that's plausible
    Well then you can have your A/C in rush hour traffic without draining the battery as fast.
