Toyota to put new hybrid-system
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Hornhonker, Nov 16, 2005.
  1. clett
    clett New Member
    537
    Scotland
    WOW! Thanks Ken, that link is the best Prius website I have EVER seen!!!! B)
  2. mrjagster
    mrjagster New Member
    51
    Jax, FL
    I agree. A wealth of information. Thanks for sharing.
  3. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    How big your motor will be?
    For the Prius, the MG1 is about one third of the HSD and the MG2 is two thirds, then the PSD is almost nothing. :)
    The MG1 and MG2 works together as something like an electric torque converter and a reverse funtion, no other mechanism is required.
    I believe the HSD system is smaller than your Torotrak and a big motor.
    Ken@Japan
  4. richard schumacher
    7,686
    1,068
    United States
    Torotrak is clever, but I wouldn't buy a frictional drive system. It starts wearing out from the first day.
  5. wtpooh
    wtpooh New Member
    Well, you obviously do like component counting Ken.
    Using planetary gears as power split devices are fine. Using two motors is a must in the rather complex parallel hybrid arrangement. The whole torotrak system (not just motor) fits into the same space as a 6 ratio Automatic gear - as I understand it, and using one motor reduces the overall transmission complexity.
    So to your question - "How big will your motor be ?"
    The electrical motor as part of the system fits into the same space where the clutch goes in a manual transmission, or where the torque converter goes in an automatic. The whole transmission is as straight a swap as can be achieved.
    So I'm not sure it is a "Big motor" as you describe the TRK electrical motor ?.
    As I'm trying to talk at a system package level, and with the annular motor design generating a higher power density, there would be a lower storage need (battery cell array) too ? again any facts and knowledge would be welcome. :unsure:
  6. richard schumacher
    7,686
    1,068
    United States
  7. wtpooh
    wtpooh New Member
    Hello Richard,
    err, they don't appear to wear out with the right traction fluid. (traction fluid is oil that goes very sticky when under pressure - i.e. caught between rollers, and the film caught between the rollers stops them wearing out) :blink:
    Page 8 below.
    Toroidal Drive Power Density Improvements and Longevity
    Essentially they tested well beyond anything that can ever be thrown at it and it was fine...
    Thanks for the other Prius info link too.
  8. richard schumacher
    7,686
    1,068
    United States
    What about the bearing surfaces, in addition to the roller-disk contact surfaces? How do they contain the lubricants and friction fluid so that one does not contaminate the other?
    But I'm open-minded: after they've been driven for eight or 12 years I'll consider it.
  9. wtpooh
    wtpooh New Member
    Hi Richard,
    As they have been running more and more sophisticated designs for over 10 years now and the accelerated life cycle tests are equivalent to more than a billion rotations of the drive shaft, (or roughly 20 years continuous driving), I'm concluding that they have the detail hydraulic lubrication system designed successfully. I guess you could call me open minded on that. :D
    WTP
  10. wtpooh
    wtpooh New Member
    Toyota Patent for a 3 Shaft Toroidal IVT
    This patent link by Toyota from 12th May 2005 shows that they have actively reduced the size and engagement of the electrical motor to be able to deliver the EV mode driving, and bypass the IVT gearing during low speed travel.
    Looks like you will get the best of both worlds - smooth electrical drive and smooth petrol drive...
    :eek:
    WTPooh
  11. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    Yes. The THS system is electrical complex and mechanical simple.
    Your systems is mechanical complex and electrical simple.
    So, your motor is relatively small fits into clutch space like Honda IMA system.
    We know the Full hybrid advantages with Electric only mode and it requires a Big motor.
    It is known that a complex mechanism will break someday.
    Simple is the best.
    Ken@Japan
  12. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    Nah.. just be ready to sell and upgrade later... we will get a nice price as long as we see "before" the release...
    Its like computers.. if you wait for the best one coming out next.. you'll "never" get one.. there will always be better!... and bugs will accompany any major update... I think 2009 may be a good time to update.
