Toyota to roll out Vitz-based hybrid, possibly by Dec 2011
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by SanZan, Jul 15, 2010.
  1. SanZan
    SanZan Junior Member
    68
    Japan
    In the English-language version, so not quite hot off the Japanese press, but here's what they say
    asahi.com
    In short,
    Vitz platform
    1.5l engine, Ni-MH battery
    Aiming for 43km/l on the (unrealistic) Japanese test (doesn't say old or new)
    Expected to sell for 1.5 million yen
    I've not seen mention of this on here, so I assume its a bolt from the blue.
  2. joe1347
    joe1347 Active Member
    669
    44
    AZ
    Wonder what's holding up the switch to Lithium batteries?
  3. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    They have a reliable supply of reliable NiMH batteries and have reliable NiMH battery management. Lithium doesn't add much for a hybrid and is expensive so Toyota are sticking to NiMH instead of going for an unknown.
    Other manufacturers like Ford and Hyundai that are new to hybrids have already switched to lithium because they didn't have the prior investment in NiMH.
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,531
    Southwest Colorado
    More expensive, unknown reliability, marginal performance advantage. No brainer to stay with NiMH for hybrids. EV or PHEV is a different story.
  5. UsedToLoveCars
    UsedToLoveCars Active Member
    448
    102
    Vitz = Yaris in north america.
    43 km/l = 101 mpg
    2 people like this.
  6. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,999
    Fort Lee, NJ
    NiMH makes perfect sense for a small affordable car. If it were an expensive sports hybrid, I would say Lithium.
  7. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    I am ALL OVER THAT!!
    I have found my next car. :car:
  8. JimboPalmer
    12,470
    6,871
    Greenwood MS USA
    They are going to re-release the Gen 0 Prius?
    Vitz
    Wheelbase 96.9 in (2461 mm)
    Length 150.6 in (3825 mm)
    Width 66.7 in (1694 mm)
    Height 60.0 in (1524 mm)
    Gen 0 Prius
    Wheelbase 2,550 mm (100.4 in)
    Length 4,275 mm (168.3 in)
    Width 1,694 mm (66.7 in)
    Height 1,491 mm (58.7 in)
  9. SageBrush
    11,627
    2,531
    Southwest Colorado
    A 15 mile Yaris PHEV would be ideal for us. Prius once a week for my long drive to work, PHEV as the daily driver.
    Perfect.
  10. Tideland Prius
    16,211
    Even if it was under the old 10-15 test, the Prius did 40km/L under the old test so it's still 3km/L ahead. If it's under the new test, that's pretty good.
    This could also be in response to the Fit Hybrid (or at least Fit-sized) that Honda is planning to release soon. This could be we can expect 52mpg as a combined EPA rating.
  11. Tideland Prius
    16,211
    Gen 1. The version we got in 2001 was a Gen 1.5 (i.e. the midlife update).
  12. joe1347
    669
    44
    AZ
    Ignoring cooling overhead (fans, heatsinks, etc) - aren't Lithium batteries about half the weight of an equivalent capacity (power) NiMH battery? Hence, for a smaller car - which means a lighter car - wouldn't actions that reduce weight have a bigger percentage impact as compared to a larger car? So, could wouldn't it make even sense to use lighter weight lithium batteries on the Vitz (than on the larger Prius)? Which leads back to my original question regarding what's holding up lithium batteries? Is it mostly cost - or is Toyota playing it safe and reluctant to use a new and somewhat unproven (in vehicles) technology? Namely Lithium batteries. If Toyota is just being cautious - is there a danger that more aggressive competitors could exploit Toyota's timidity and offer a better (higher mpg product). Of course, I'm just speculating?
  13. usbseawolf2000
    14,487
    2,999
    Fort Lee, NJ
    Would it make sense to pay $1k more to save 50lbs (and gain 1 cu.ft interior) for a $15k car?
  14. SageBrush
    11,627
    2,531
    Southwest Colorado
    ^^ Exactamundo
  15. austingreen
    austingreen Senior Member
    13,594
    4,132
    Austin, TX, USA
    Lithium batteries definitely have technical advantages, but there are other considerations
    CARB requires the crazy 150K mile warranty on PZEV because California considers batteries part of emissions controls. There is warranty risk with any battery changes.
    Toyota is majority owner in the leading company in Nimh batteries. They appear behind the competition in Lithium technology, but in corporate politics it is often better to wait for such a company to catch up instead of switching suppliers.
    It would not be in keeping with toyota corporate culture to introduce better technology in the vitz before offering it in the prius (soon in phv) or a Lexus model.
    Does it really matter in the vitz? The car will not likely have great acceleration or handling. Thle penalty for using the current technology won't likely stop buyers.
    Toyota will be forced to switch to lithium because of competition, but it will be on higher performing cars.
  16. usbseawolf2000
    14,487
    2,999
    Fort Lee, NJ
    It appears that way but I believe PEVE is a few year ahead of Nissan with the next gen Lithium chemistry that would give Leaf 200 miles range.
  17. austingreen
    13,594
    4,132
    Austin, TX, USA
    It will be nice if they have moved beyond the products they are showing. I don't quite know what to think of Nissan's technology. Toyota in their phv prius batteries is quoting a much higher cost and much lower kwh/kg value than lg or jci-saft. And these two Vehicle battery producers are definitely behind in kwh/kg from the assembled big li from smaller comercial batteries of tesla. Since Pansonic builds some of those cells in tesla's batteries I can't believe there is any technical reason they are far behind.
  18. Sacto1549
    Sacto1549 Member
    119
    17
    Sacramento, CA USA
    It sounds like Toyota is developing a lighter version of its Hybrid Synergy Drive system so it could work on a vehicle as small as the Yaris (Vitz). Don't be surprised that we see it available on the next-generation Yaris for the USA market in early 2012 as a 2013 model. :)
  19. johalareewi
    johalareewi Member
    393
    44
    uk
    Hybrid Yaris. Where will they put the HV battery pack? Junk the spare wheel perhaps?
  20. hill
    8,285
    It's not just California. Several states follow that warranty principal. I'll bet the handfull of folks who've had their packs die at 125,000 miles don't think a 150K warrany is crazy.
