Toyota to test plug-in Prius PHEVs on public roads
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by clett, Jul 19, 2007.
  1. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    <div class='quotetop'>QUOTE(Tideland Prius @ Jul 19 2007, 01:11 PM) [snapback]481770[/snapback]</div>
    Cell phone batteries have occasionally been recalled, due to instances of "spontaneous emission of super heated gasses, and rapid self-disassembly"... the Kyocera 7135 smartphone, for example, made the news when its batteries began to self-destruct 3 years ago. Other phones have had similar issues. So has the Dell laptop computer, much more recently.
    I'd also prefer to not be driving something at highway speeds when it decided to "self-disassemble"
  2. clett
    clett New Member
    537
    Scotland
    As for the lithium-ion concerns, please remember that the new LiIon chemistries (iron phosphate and titanate) are FIRE PROOF and hugely abuse tolerant. It's really only the old-skool lithium-ions using cobalt based electrodes that can catch fire like that (and these are the type widely used in phones/laptops because the slightly better run time of cobalt sells better than safety).
    As for the economics of a PHEV, a Prius can actually go 5 miles per kWh (200 Wh/mile).
    Thus, gasoline at $3.00 per gallon and 50 mpg gives a gasoline cost of 6 cents per mile.
    Then, depending on how much you pay for electricity, the electric PHEV costs would be:
    15c / kWh electricity: 3 cents per mile
    10c / kWh electricity: 2 cents per mile
    5c / kWh electricity: 1 cent per mile
    So big savings are possible, depending on where you live.
    People living in apartments etc will charge up in the parking lots at Walmart etc while doing their shopping.
  3. EVdriver
    EVdriver Junior Member
    39
    <div class='quotetop'>QUOTE(MarkMN @ Jul 19 2007, 09:12 PM) [snapback]481773[/snapback]</div>
    Well, this is a common misconception. If you compare the efficiency pathways of the electric and the ICE car (well-to-wheel efficiency) you could see that the electric car at least 2 times more efficient than the ICE one. It is advisable to look over the pollutant numbers as well:
    <div align="center">Debunking the Myth of EVs and Smokestacks</div>
  4. zzyzx
    zzyzx Junior Member
    92
    16
    <div class='quotetop'>QUOTE(Tideland Prius @ Jul 19 2007, 08:09 PM) [snapback]481991[/snapback]</div>
    This inspired me to look it up. Seattle City Light is 3.76 cents for the the first 10 kWh, and then 7.93 cents
  5. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    <div class='quotetop'>QUOTE(Tideland Prius @ Jul 19 2007, 11:09 PM) [snapback]481991[/snapback]</div>
    Well, the "Generation" charges are only $0.06490 / kWh. However, then you need to add the "Transmission", "Distribution", and "Transition" charges. I have no idea what "Transition Charges" are, or how "Transmission Charges" differ from "Distribution Charges".
    Generation Charges: $0.06490 / kWh
    Transmission Charges: $0.00550 / kWh
    Distribution Charges: $0.04760 / kWh
    Transition Charges: $0.03030 / kWh
    for a total of $0.1483 / kWh
  6. Tideland Prius
    16,547
    <div class='quotetop'>QUOTE(Marlin @ Jul 20 2007, 12:58 PM) [snapback]482397[/snapback]</div>
    Still, that's the final cost you pay... :blink:
  7. des101
    des101 New Member
    I heard someone on CSPAN2 talk about plug in hybrids. I feel after hearing this that they have a lot of promise. Most people would plug in during non-peak hours, this would 'balance the grid". You would probably pay less for the electricity that way. Another option in windy states (most of the west), would be that it could theoretically make wind energy more usable. Wind tends to increase at night. You plug the car in at night. Another possibility is that you might theoretically be able to sell back electricity to the utility that you make parking your car during the day-- this could be used as reserve (theoretically) if their were a loss of power. Partly spent batteries could also be stored.
    I think this would initially be sold as a "commuter car" with no attempt to make this a car for trips, etc. There could be infrastructure and so forth which is way more feasible than hydrogen. I would be perfectly happy with a car that could only go say 200 miles. I don't think this would be a sole option that everyone would get.
    But anyway with solar or wind energy, you could run a totally green car. Even without I think the studies indicated that the a plug-in is more friendly than it might appear because it uses the power at off peak times.
    It also creates power that could be sold back.
    --des
  8. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(Rae Vynn @ Jul 19 2007, 08:50 PM) [snapback]482007[/snapback]</div>
    As Clett so nicely pointed out - these are not the same batteries. They aren't managed the same, etc. And if you are concerned for your safety on the highway - get the heck out of your gasoline car. There are few things we could stick in a car that are more dangerous than a tank full of gasoline.
    <div class='quotetop'>QUOTE(des101 @ Jul 20 2007, 11:33 PM) [snapback]482687[/snapback]</div>
    I can't figure out why you think they wouldn't work beyond commuting. These cars will be ever bit as capable as the Prius... with the ADDED benefit of a few miles of battery-only miles. After the battery is depleted, it becomes a gasoline hybrid just like the Prius... until you can plug it in again. This is a long-range car, that has short-range EV capability.
    Ah, are you talking about a battery-only car? For that I agree - an emphasis on commuting is a perfect fit. There is NO other automobile better suited to commuting than an EV. But I thought this was about PHEVs? Maybe I'm confused... For the record, we use our 100-mile-range EV every day, and for well over 90% of our trips. We need the Prius for the one or two times per month that we stray outside our range.
    Absolutely. Solar is what powers mine. And those who use the grid use almost 100% off-peak power. We can power millions of EVs just on the under-utilized off-peak power we already have - though most people fear all these scary extra power plants that we'll need for EVs. Please note that the gasoline industry is the single biggest consumer of electricity in the world.
