Toyota to Use Zip Ties to Fix Floor Mats
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by ggood, Oct 8, 2009.
  1. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    Reminds me of the poster whose dealer recommended using zip ties to stop would be thieves from stealing her wheel covers:
    [IMGLINK]http://priuschat.com/forums/attachments/newbie-forum/17139d1248987815-stolen-hubcaps-dsc04329.jpg[/IMGLINK]
    I hope in this case that Toyota dealers have enough good taste to use black-colored ties. :p
  2. Muhahahahaz
    Muhahahahaz Member
    136
    CA
    LOL... are you serious? I knew there was no sane reason to remove my *properly installed* floor mats. :rolleyes:
    Toyota "requests common sense." You know, I request that every day, but it never seems to make a difference... People will still continue to screw up in new and exciting ways...
    Stupid is as stupid does, I guess. :rolleyes:
  3. richard schumacher
    7,664
    1,044
    United States
    Several drive-by-wire cars have a brake-accelerator interlock: when the car is moving, if both the brake and accelerator are pressed the accelerator is ignored. That seems worthwhile for the PR value alone starting in the next model year. It's too expensive for any sensible recall, of course.
    Somewhere out there is at least one idiot who will find a way to create a safety hazard with the zip ties. They'll tie the mat to the movable seat instead of the fixed seat mounting rails, or to the gas pedal itself, or some damn thing.
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Alright...you caught me, I was exgagerating a little. But my point is still the same, Zip Ties are cheap. I mean really, even if it's use, cut, clean and use new ones, how expensive is it EVER going to become? For the purpose of Mat Cleaning, a lifetime supply of zip ties are going to be easy to obtain and keep.
    If and when Toyota comes up with a permanent solution great, but zip ties work and the fact that I might have to replace them everytime I clean the mat? Not a big deal.
    Also the key to this "solution" is that it allows Toyota and Dealers to continue to sell all models (even past models) without a significant hardware change. My guess is that maybe "moving forward" no pun intended, Toyota might make a change in how the Mats are secured from a hardware standpoint, but I if the NHTSA accepts this as an acceptable solution for cars being produced immediately and in the past then I don't see Toyota making another change to already existing models. It's a whole lot cheaper to provide Zip Ties than physically have to recall millions of vehicles for a installed hardware change or update.
    Also for those calling the solution Mickey Mouse? Why? If it works who cares? Is it better if it requires drilling into the floorboard? Is it better if it requires destruction of all existing mats and recreation of a totally new mat? This is a simple, inexpensive fix, if it works and is safe and solves the problem then give me a pair of ears and call me Cubby!
  5. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    someone will cry foul when they explain how much these things will pollute the environment when they get tossed. We'll need to find a semi-permanent green solution.
  6. DaGeek
    DaGeek New Member
    48
    Because if it sounds Mickey Mouse, and it appears Mickey Mouse in my Prius then... you know the rest...
  7. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    Reality check. This is for show.
    The carpetted floor mats are not the problem. Doing this to the carpetted mats is an ( unnecessary ) redundancy because these mats are very very unlikely to cause the problems that the AWM's cause. But something has to be done.
    This will accomplish the 'something has to be done' goal at little or no cost.
  8. wildbottom
    wildbottom New Member
    99
    Wonder if they sell gray color zip ties. The zip ties might scuff the plastic cover because it has teeth in on the inside. I
  9. Tech_Guy
    Tech_Guy Class Clown
    868
    123
    Silicon Valley, CA --- Land of Fruits & Nuts
    If Toyota took this issue seriously, they would not have used zip-ties. A more permanent solution would be to take a 3/8" drill and drill 4 holes through the carpet (2" from each corner) and chassis. Secure the carpet to the chassis with 2" x 3/8" bolts (Grade 8), 2" washers, and locknuts. Tighten the bolts to 40 foot-pounds with a calibrated torque wrench.
    Now I dare any lawyer to file a lawsuit against Toyota due to carpet slippage.
    Keith
  10. msirach
    msirach Member
    321
    Southern Illinois
    You win the prize Richard!
    Smart Gas Pedals May Solve Floor-Mat Problem
  11. nyty-nyt
    nyty-nyt Member
    139
    Ontario
    Our dealer's honesty level has plummeted since a new owner took over. "Should we check and replace your cabin filter?" every oil change for 35 bucks. I wonder how much Toyota is being ripped off by him over this.
    Now that the obvious "temporary" solution has been announced, where do I find driftwood pearl color-coordinated ties for my ride?
  12. tumbleweed
    tumbleweed Senior Member
    4,067
    691
    Eastern Oregon
    It's a rip off if they want to do it every oil change, the owner's manual page 467 tells you how to remove the cabin air filter. Most of the time I just vacuum it out or wash it with water and reuse it. Even in the dusty climate where I live it will only need replacement once every few years.
    Actually tie wraps do come in colors other than white or black. I have seen red, yellow and blue. :)
  13. Bill60546
    Bill60546 Member
    388
    Chicago
    "semipermanent floor mat installation process"
    Now I come from the food and consumer products industry and I've seen more than my share of marketing-hyped advertising, promotions and buzz words but the above should be considered for the most over-exaggerated description ever. Its a 5cent zip strip for gosh sakes.
  14. GadgetCar
    GadgetCar Junior Member
    San Antonio, TX
    I'm not that familiar with the accident that caused the recall. All I heard was a 911 call while traveling over 120 mph because the gas pedal was stuck to the floorboard. Why didn't they just turn off the car? What would happen if you turned off the Prius in that situation?
  15. fgerwig
    fgerwig New Member
    WV
    I just got my 2010 Prius II two days ago. My dealership used a black zip tie on each of the corners of the mat closest to the seat on the driver's side mat. They are really not noticeable. My salesman assured me that they would notify me as soon as a permanent solution was available. As I mentioned earlier, I have not noticed them as they are same colour as the mat and the metal base of the seat.
  16. tumbleweed
    4,067
    691
    Eastern Oregon
    There are a couple of threads on this including what to do if it happened to you (very unlikely).
    Bottom line: You can shut your Prius off while driving by holding the Power Button in for 3 seconds, or you can hold the transmission selector in Neutral for 1 second (obviously better because it's quicker). You can also cram the brakes down good and hard and they will stop the car.
    http://priuschat.com/forums/gen-iii...0170-stopping-hybrid-system-in-emergency.html
    http://priuschat.com/forums/gen-iii-2010-prius-main-forum/68851-gen-iii-prius-turn-off.html
    The car involved was not a Prius, it was a non-hybrid Lexus. The car was not at fault.
  17. Silver bullit
    Silver bullit Right Lane Cruiser
    608
    211
    San Diego, California
    I haven't heard that it was proved that the floor mats caused that tragedy. The officer was driving a loaner car while his was being serviced. The officer specialized in vehicle safety inspections and I don't feel that the floor mat would be overlooked by him.
  18. Gaujo
    Gaujo Junior Member
    43
    Charlotte, NC
    that's so stupid
  19. ilusnforc
    ilusnforc Member
    404
    San Antonio, TX
    I hope nobody actually did "toss out" their floor mat as suggested by Danny's article on 9/30/2009 titled "Have a driver's floor mat in your Gen 2 Prius? Toss it out!" because I'm sure Toyota will not be issuing replacements. There was a 2010 with solar roof at a recent greenfest from a local toyota dealership, the salesman answering questions about it told me the floor mat issue was a safety advisory, not a recall, and new floor mats will likely not be issued.
  20. priusinpdx
    priusinpdx New Member
    Portland, OR
    I just brought in my 2010 for its first oil change. The service advisor said the zip tie "solution" applied only to carpeted floor mats and that Toyota is recommending completely removing the all-weather mats. (Not sure why zip ties won't work on all-weather mats). I am going to take my chances and leave the mats in as the winter rains here in Oregon are acoming (and I don't have carpeted mats).
