Toyota Transmission fuild in my brake fluid, is this bad?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Groger, Nov 20, 2016.
  1. Groger
    Groger Member
    70
    25
    Hi
    Yes yes, I know, I'm am an idiot. Brake fluid was low but for some reason I thought it was the power steering fluid. Went to Toyota Parts department, told them I had a 2011 Toyota Prius and needed power steering fluid. They sold me Transmission fluid. Went home, waited until car was cold. Purred in the transmission fluid in the brake fluid reservoir. It looked strange, the fluid in the reservoir was clear brown and the fluid I had was pink. Right after I poured it, I checked the book, and yup, brake reservoir. I thought I had already checked it, I guess I was wrong.
    So, can I drive about 6 miles to the garage to get it changed? or should I get it towed?
    Thanks
  2. fotomoto
    fotomoto Senior Member
    5,629
    3,802
    So. Texas
    Do not drive it or open the drivers doors. Have the reservoir suctioned out ASAP. Refill with brake fluid and repeat suction and refill. For ultimate peace of mind then have the system fully flushed; probably due anyway.
    Good luck
  3. Groger
    Groger Member
    70
    25
    That is what I am thinking, I am going to have it towed and have a full fluid change.
  4. Mendel Leisk
    40,586
    If you have not driven it since the mix-up, I would DEFINITELY follow @fotomoto 's advice first. Take a taxi or whatever to get some DOT 3 brake fluid, at least one pint, preferably Toyota. Then, baste out as much as you can, refill, baste, refill, as many times as possible.
    Note that there is a sort of basket inside the reservoir, not that deep, with just a narrow slot through which you can get a skinny tube down deeper. And then, yeah, get it towed to dealership, tell them the whole story, ask for a thorough brake fluid change.
    FWIW, if a brake system is not leaking, and it shouldn't be: the brake fluid should NEVER need a top up. It's natural for the level to drop.
  5. slewinson
    slewinson Junior Member
    36
    30
    Australia
    Adding mineral oil to a brake system will destroy the seals, and I would replace every last one of them before driving the car. Even a minute amount will cause the seals to swell and eventually fail.
    Replaceing all the bits will be expensive!
    Simon
    MrMischief likes this.
  6. JC91006
    16,674
    8,519
    If you have some basic diy tools, you can remove the reservoir pretty easily. Use a baster and take out as much as possible and remove the reservoir and clean it out with brake fluid.
    Then take it to a garage a do a brake fluid flush out, make sure everything comes out.
  7. Groger
    Groger Member
    70
    25
    Thanks everyone, garage fixed it, they flushed it out. All good now. I was lucky, only cost $65. Also, thank you to CAA for the free tow.
    Bluegrassman and Mendel Leisk like this.
  8. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    Wow. Lucky, I hope. Only time will tell. But it sounds like you're ok. Just for your info. the master brake cylinder in the Prius is pretty expensive, due to its dual nature of regen/friction braking.
  9. JC91006
    16,674
    8,519
    $65 what a deal
  10. Mendel Leisk
    40,586
    Yeah, go and sin no more. And say ten "invalid mode" procedures, as penance:
    set parking brake
    without foot on brake, press start button twice
    foot on brake, shift to Neutral
    press brake 8 times in 5 seconds
    push park button
    push park button
    (car should exhibit blinking brake symbol, indicating in "invalid mode", for brake bleeding without techstream)
  11. slewinson
    36
    30
    Australia
    I would refuse to drive it till the master cylinder was rebuilt or replaced. Expensive? Yep, but I value my life. One droplet of oil that was missed could cause a brake failure.
    Simon
  12. Eastside
    Eastside Member
    129
    82
    NorthVirginia
    $65, Wow . . . Any chance that your mechanic wants to move south for the Winter ?
  13. MrMischief
    MrMischief Active Member
    426
    443
    Denver CO
    I would really like to hear a follow up to this in a month. Everything I think I know about brake systems and mineral oil is that the gaskets will swell and you will lose your brakes, starting with the master cylinder. And it should happen quickly.
    If your mechanic says OK... well.... he knows better than I do so I don't mean to scare you but I would really like to know if it's still fine after a month.
    slewinson and Mendel Leisk like this.
