Toyota "WS" Lifetime ATF
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by The Critic, Oct 28, 2005.
  1. TucsonPrius
    TucsonPrius Member
    167
    16
    Tucson, AZ
    2020 Prius
    Yes, I downloaded much (all?) of the manual for $10 off of Toyota's techinfo site.
    I agree that there is probably little to no difference in reusing the washers (I think they are soft aluminum) versus replacing them, but I wasn't sure what to expect the first time I changed the fluid, so I bought 'em.
    Thanks,
    Shawn
  2. joe350gt
    joe350gt It's too windy here...
    40
    38
    Wichita, Ks.
    Jayman or Rick,
    Is there any info about doing the drain/fill of the PSD WS fluid? I haven't found anything on here yet but I'd like to do mine soon. I'm at 62K miles now and the local dealer wants $129 to flush/fill it and I don't really trust them to do it. If I had some pics/directions I think I could pull it off ok.
    Thanks in advance,
    Joe
    <div class='quotetop'>QUOTE(TucsonPrius @ Feb 10 2007, 02:24 PM) [snapback]388086[/snapback]</div>
  3. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    <div class='quotetop'>QUOTE(joe350gt @ Mar 28 2007, 11:20 PM) [snapback]413936[/snapback]</div>
    Joe,
    Just do a drain and fill ... a "Flush" is wasted on the Prius (no torque converter). I had mine done at the dealer for $85 at 61,000 miles. A lab analysis said "not bad, but just about used up". Try to save a 4 oz sample in a clean Poly bottle and have it lab tested so that we can add your experience to our database. See:
    http://hiwaay.net/~bzwilson/prius/pri_T_cold.html
    For a detailed discussion on this topic.
    JeffD
  4. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    A "flush" is impossible as the +2004 Prius there is only a drain plug and a fill plug. This may help
    http://priuschat.com/index.php?showtopic=18782
    http://priuschat.com/index.php?showtopic=7108
    Hope this helps. I'll be away another two weeks, hopefully you have enough to go on
  5. grogi
    grogi Junior Member
    For those looking to get some of Toyota ATF WS from local dealer and their reply is 'I've never heart of it', here are the OE codes:
    00289‐ATFWS
    08886-81210
    08886‐02303
    08886‐02305
    08886‐80803
    08886‐80807
    I finally managed to order the WS from local dealer after I have came with those numbers...
  6. grogi
    grogi Junior Member
    Double post
