Featured Toyota's Master Plan for a Low Carbon Future
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Prius Pete, Feb 13, 2020.
  1. Prius Pete
    Prius Pete Active Member
    183
    178
    Toronto
    Prashanta likes this.
  2. Tideland Prius
    16,683
    You don't need that kind of speed for a PHEV.
  3. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    But if you are setting up for the long-term, knowing a 40-amp line will be enough for decades makes the capacity choice easier.
    bwilson4web likes this.
  4. Tideland Prius
    16,683
    You're not reading my posts properly. I'm talking about the car. You're talking about the home setup. Please read it again. I have no problem with what you said, it's just that it's not relevant to what I said.
    Raytheeagle and bisco like this.
  5. john1701a
    12,840
    5,312
    58
    Actually, I did. I was just being polite by not bringing up the topic of "want" because the "need" should go without saying. Heck, we know that the included L1 charger can pull off an overnight recharge.
    Keep in mind, the quick partial recharge for running short errands is handy already, at 3.6 kW. When you only need a few miles to reach the local store, it's really nice...
  6. bisco
    52,895
  7. bwilson4web
    16,552
    Good people can agree to disagree. My background suggests the incremental costs of the car based, 6.6 kW to 10 kW is trivial. Gaining 3.4 / 6.6 = ~52 % improves L2 charging speed and pays off during the +10 years of operation.
    Tideland Prius likes this.
  8. Trollbait
    12,832
    So does the Spark Ev and Bolt. The amount of change from the Trax platform the Bolt was based on was enough that GM felt they could call it a new platform. They started with the Trax, because SUVs have more space to play with for these batteries. The C-HR EV and Rav4 Prime get underfloor packs, but the Prius Prime did not, which would have solved lots issues with the car's packaging.
    For longer range EVs, Toyota is working with Subaru on an all new platform.
  9. bwilson4web
    16,552
    No one has to use all 10 kW. In the summer, I use Time of Day charging to wait until after midnight. This reduces the heat stress on the car and the grid voltage float is higher. But I've also set my charging current to 27 A when on a NEMA 14-30, 30 A circuit to reduce the risk of tripping the circuit breaker.
    A higher capacity, built-in charger can be operated at lower power levels to match the feed circuit. But a lower capacity charger can never be set higher. The incremental cost of a 10 kW charger is trivial or rather the savings from a smaller capacity charger is nothing compared to lost human time waiting for a charge.
  10. Trollbait
    12,832
    When charge time is the issue, a DC charger is going to be used, and the charger on the car is irrelevant.
  11. hill
    9,041
    ... editing
    I was gona say Mitsu Outlander does above 10K - but that's using its Chademo port ... & very few plugin's have one at home
    #91 hill, Feb 16, 2020
  12. Tideland Prius
    16,683
  13. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    Dynamic Force 2.0 and 2.5 are D4S, and since this 1.5 is derived from, I bet it will be both DI/PI.
    Missed the bottom of this. My fault, I couldn't translate.
    14million hybrids must have been sold on another planet?
    #93 telmo744, Feb 17, 2020
    john1701a and Prius Pete like this.
  14. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    If it was then it would produce 3/4 the power of the 2.0 engine, that would mean 80 kW, but it produces only 67 kW.
    2.0 and 2.5 engines are rated as 41% efficient in hybrid application. Prius 1.8 and this new 1.5 engines are rated 40% efficient.
    telmo744 likes this.
  15. telmo744
    2,181
    769
    Portugal
    But the 1.8 produces 71kw, using the sabe output per displacement, the new 1.5 would get only to 59kw by the same logic. But...
    I guess you are right!
    Toyota dynamic force engines - Wikipedia
    This Yaris 1.5 engine is FXE, not FXS like the Camry, etc.
  16. bisco
    52,895
    apparently, because toyota thinks they need government incentives to make them successful
  17. Prius Pete
    183
    178
    Toronto
    Obviously having government incentives for hybrids and not just EVs would make hybrids even more successful at displacing conventional vehicles than they already are now without such incentives. It could also be a more effective use of government money on a $ per unit of CO2 saved basis. That's what Larry Hutchinson is saying in the original post.
    Prashanta, telmo744 and john1701a like this.
  18. Trollbait
    12,832
    If Larry was being honest when he spoke about technology neutral solutions, he would be calling for incentives based a car's CO2 emissions or fuel economy. The Mazda3 with SkyActiv-X gets 52.3mpg and 96g/km CO2 emissions on the WLTP. The EPA could be 47mpg without any traction battery at all. ICE cars, diesel and gas, are getting more efficient, so why exclude them if buying them would mean lower emissions. People might choose sedans and hatchbacks over SUVs with an incentive, and those emit less for the same size.
    Or call for a carbon tax. Having to pay more will get people to change behavior faster than getting a discount on purchase made every few years or so.
    Of course, tech neutral incentives for carbon emissions would exclude some Toyota hybrids, and a carbon tax would hurt the majority of Toyota's models.
    Toyota is just jealous of missing out on government funds. If they were serious about emissions, they would have started spreading hybrid tech out to other models sooner, maybe even have some hybrid only. They could adjust the prices of ICE and hybrid models so that they are closer. Lincoln had the same price for the base ICE and hybrid for their sedan, and its hybrid had some of the highest take rate at the time; higher than the Camry's.
  19. Rmay635703
    Rmay635703 Senior Member
    2,705
    1,730
    Somewhere in Wisconsin
    2013 Chevy Volt
    I’m just excited it’s a three banger, we don’t get enough of those over here.
  20. Rmay635703
    2,705
    1,730
    2013 Chevy Volt
    Yeah but in reality we get told we are cheapskates and need to spend hundreds extra on title/registration tax
    because we don’t burn enough gas.
    Prius Pete and bisco like this.
