Toyota's runaway-car worries may not stop at floor mats-LA TIMES
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Jasonsprite, Oct 18, 2009.
  1. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    I hope the CHP boycott's Toyota too. Their officers are apparently too friggin' stupid to drive them, and the rest of us don't need the total bullshit hysteria that the CHP are capable of generating.
    Cripes, when will this absolute nonsense end???
  2. patsparks
    10,664
    567
    Adelaide South Australia
    No danger of accidentally locking the steering on a Prius, there is no steering lock.
    What about that Corolla? When my Prius glides, the engine is off but all the ancillaries still work, what about the Corolla?
    My choice, move to neutral, maintain power steering and brakes. Not that I have ever or will ever need this.
  3. bwilson4web
    16,391
    This is a plot of four runs, GPS recorded data, of high speed, pulse and glide versus the equivalent, cruise control speed. The glide was effected by holding "N" for ~1 second. The pulse happened by shifting into "D" and hitting cruise control resume. You have to hold it in "N" for one second and shifting into "D" works every time with my 2010 Prius.
    Now if you press and hold "Power" for 3 seconds, the car will shutdown and you will have to come to a complete stop to start it again. I do not recommend using "Power" unless "Neutral" fails ... so far, "Neutral" works every time.
  4. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    I went and test drove the 2010 Prius today and it shifted between drive and neutral, no problem. I don't get it. When I test drove the 2010 Prius about a month ago, it would not shift back into drive unless the car was at zero mph. Two different Toyota dealers, two different Priuses, and two different results. :confused::confused:
    Perhaps this is the variable.
    Thanks for the info. "45" is the magic number then. I rarely shift into neutral above 45 anyhow, it's usually sub-45 that I shift into neutral.
    Makes sense. Since I don't own a Prius (yet?), I can't experiment with it. When you shifted into neutral, did you notice any change in resistance? For example, in my Corolla, when I shift into neutral, from engine braking, there is an obvious reduction in resistance and the car coasts/glides much further.
    Again, same question: can you feel a difference in resistance when shifting between drive and neutral? Also, and this is a question for an electrical engineer (or anyone who has experimented and learned on their own), is there a difference in resistance whether a generator is hooked to electrical wires or not hooked up?
    Excellent. Problem solved?
    Thanks! :)
    The powersteering runs out of pressure after about fifteen seconds. This is not a problem for me. The truck that I learned to drive in did not have power steering at all. We had to use these things on our arms called muscles. :D The reason I leave the engine running in my Corolla? After about 30 seconds, the power brakes run out of pressure. :eek:
    And here's the money question: You are driving over a patch of ice or very slick road and want as little resistance as possible. In a traditional car, you would either disengage the clutch or shift into neutral. Will "glide" on the Prius offer as little resistance as neutral? (from an intuitive standpoint; not a "I hooked up twenty sensors and computers" standpoint)
    This actually brings up another question: In my Corolla, I often shift into neutral before going down a steep grade or braking in the rain. The reason for this is that the Corolla transmission, with only four gears and wide gear ratios, the car jerks when downshifting downhill. As a precaution, to prevent the jerk (and potential loss of traction), I disengage the transmission before it has a chance to create a problem. If I am correct, the Prius does not have a transmission. The engine is directly coupled to the drive shaft and a powerful motor assists the engine at low speeds. But even then, does regen ever create a problem while braking downhill ?
    Schlage (available at Home Depot) now makes keyless entry for houses.
    Thanks! :)
    (responding to the graph, something that we discussed in another thread, was that at 52.5mph, wind resistance is significant enough that constant velocity is more efficient (due to greater wind resistance (F=-kx^2) while pulsing above 52.5mph); however while coasting from 30mph to 0mph, wind resistance is low enough that pulse and glide prevails (due to the fact that you can glide for much longer due to minimal wind resistance causing the vehicle to decelerate compared to the rate of deceleration at freeway speeds). And yes, I know very well that everyone here already knows this. I just felt like typing it so I can feel special. :D haha.
  5. Doc Willie
    1,717
    144
    Out there, somewhere
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    You must have done something different. They all work this way. It's not speed related.
    Hooking a generator to wires does not increase the load. Drawing power from a generator increases the load. For example, plugging a light into the wall socket does not increase your electrical bill. Turning on the light after it is plugged in *will* increase your bill.
    As for the Prius, feeling a difference between drive and neutral all depends on the load in drive. In neutral there is no load, other than drag and parasitic losses. In drive, if you feather the gas pedal to avoid acceleration and regenerative braking, it feel exactly as it does in neutral.
    You can do this with the Prius, but there is no need for it. The Prius control system is smart enough to do the modulation for you. My Gen II Prius with VSC is the most stable winter car I have ever driven, including a Jeep C-J5, a 4wd Subaru, and a Ford Aerostar van with electronic 4wd.
    No, regen never creates a problem braking downhill. It makes things a lot better, since it saves wear and tear on the friction brakes. The Prius also features an engine braking mode, called "B mode", which is like downshifting with a normal transmission. B mode is very nice for mountain roads.
    Tom
  7. philobeddoe
    philobeddoe ΜΟΛΩΝ ΛΑΒΕ
    575
    107
    Los Angeles
    * Jean Bookout awoke in an Oklahoma hospital a month after a crash in her 2005 Camry.
    She said the car sped out of control on a freeway, then smashed into an embankment after she swerved it onto an exit ramp, leaving behind long skid marks from attempts to stop the vehicle with her brakes and emergency brake.
    Bookout sustained permanent memory loss, and her best friend died.
    "I did everything I could to stop the car," she said Tuesday.
    * Nancy Bernstein, a vice president for a Long Beach community garden and former science teacher, said she was taken on an 8-mile high-speed ride by her 2007 Prius while she was following her husband in a group bicycle tour in Wisconsin. She said her Prius accelerated from 45 mph to 75 mph on a winding, two-lane highway crowded with 100 cyclists.
    "I was sure I was going to kill someone on a bicycle or myself," she recalled. "I stood on the brakes with both feet. All of a sudden, I see fire. I thought, sure, my brakes are on fire. I thought about maybe trying to sideswipe a tree to slow down."
    Eventually she was able to stop at the bottom of a hill, using her brakes and emergency brake. A local resident rushed out with a fire extinguisher.
    * Dr. David. W. Smith, an emergency room physician from San Dimas, has yet to receive a satisfactory answer from Toyota about his Lexus GS 300. Smith said he was driving with his cruise control in Central California on Highway 99 last year, not touching the accelerator, when suddenly the vehicle accelerated to 100 mph.
    The brakes did not release the cruise control or slow down the vehicle, Smith recalled. Finally, he shifted into neutral and shut off the engine. "I am sure it is the cruise control," he said. "I haven't used it since."​
    As for its position that brakes can always overcome a vehicle's engine, the safety agency and Toyota now acknowledge that a braking system cannot always counter a wide-open throttle, as is the case in sudden acceleration.​
    It would be great if one of these media outlets could solicit an expert opinion to suggest what a driver should actually do in the event of one of these rare and inexplicable episodes
    the idea that someone would sit in their car doing nothing but stand on the brakes as the car uncontrollably accelerated is mind boggling
    i can understand that there may not be enough time and input for someone to realize that by mashing on the brakes they are actually flooring the accelerator
    but sweet jesus, can't the LA Times at least put in a blurb that says SHIFT TO NEUTRAL or are they worried about liability?
  8. fuzzy1
    10,603
    Qbee already answered most of the questions directed to me, but here is a bit more. See also the Transmission Question thread for more info about what happens in Neutral.
    When shifting with foot off the throttle, i.e. it was in 'fake engine drag' mode, yes, there is a noticeable reduction in resistance. But I don't remember it being any better than what is achieved by using the pedal to make the HSI power bar vanish.
    On your Corolla, much of the in-gear drag is engine compression braking, also known as pumping loss. When the engine is idling, the pistons pull air past the nearly closed throttle plate, creating a strong vacuum. This process consumes a lot of power, causing a lot of drag, and is an inherent loss mechanism in traditional (Otto cycle) gas engines. The loss is also proportional to engine RPM and displacement, which is why bigger engines are bigger fuel hogs.
    The Prius uses an Atkinson cycle, which effectively means that its variable intake valve timing produces a variable displacement. When 'Idling', its valves are set for minimum displacement, and the transmission lets it spin at minimum speed (0 rpm when rolling at 0-45 mph, 992 rpm when rolling 46+ mph). Both factors give it a big advantage over your Corolla.
    I am an electrical engineer. And as Qbee noted, a generator's shaft does see resistance proportional to the load drawn out of the electrical terminals, in addition to some friction loss.
  9. fuzzy1
    10,603
    From the LA Times article ...
    Earlier I asked whether or not Toyota suffered more of these incidents than other brands. These comments appear to be a direct answer.
    This directly challenges the many claims that brakes can always overcome the engine. The CR video at ABC News even demonstrates this problem. CR make no reference to this possibly being linked to the adoption of ABS, forcing brake overheating, as some have claimed here.
    From the CR video -- "Most people have never put their car into Neutral".
    This statement flabbergasted me. I must be getting really old.
    How few minutes, besides 'not enough', does Driver Education take these days?
  10. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    There is nothing new here. The prior incidents were investigated by the NHTSA going back to 2002 as the article said. The article quotes the NHTSA stating that 'no evidence was found....' That's why they closed the cases.
    The other key point is that the ones who are paying for these crashes, deaths, injuries and damages also are absolutely silent on the matter. The insurance companies have not issued one word on any of these issues. It's the insurance companies and their pit bull the IIHS that would have a vested interest in making these accidents disappear if there was a technology issue causing it. The IIHS has never been hesitant to get on GMA or the Today Show and promote one safer vehicle or technology over another. If there was such a problem and there was a solution to such problem the IIHS would be duty-bound on behalf of its pricipals to broadcast both.
    Thus since 2002 and over 20 million vehicles the 'reports' of alleged unintended acceleration are all unsubstantiated or if true the cause is unknown. All of them. This is the key fact IMO.
  11. bwilson4web
    16,391
    This really 'pisses me off.' The reason is the NHTSA appears to be colluding with the NFB to push HR 734 and S 841 through Congress. Meanwhile, it looks like they have been down playing 'run away' acceleration. I've looked for 'quiet car' pedestrian accidents in the Fatality Analysis Reporting System (FARS) and found nothing to justify this legislation.
    Instead, the NHTSA is now suspect as are their databases. Follow-up in "Fred's House of Politics."
  12. Celtic Blue
    2,224
    139
    Midwest
    I noticed a common link in the follow up story... there was no common link (other than the manufacturer's name.)
    And that's actually one of the strongest defenses for Toyota--the "pattern" seems to have nothing to do with car's mechanicals. Prius-Tacom-Lexus-Camry, whatever these don't share a lot and even what they might share (e.g. cruise control) is going to be hard to blame for the incidents listed.
  13. radioprius1
    radioprius1 Climate Conspirisist
    1,355
    155
    Iceland
    They're mostly women drivers. Who know what really happened.
  14. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    Common sense and high school physics support the claim that ABS has changed the equation. Brakes can not overheat when they are completely locked. The heat energy is dispersed in all that tire smoke that comes off rapidly heating tires. That's where it goes. If the discs are not sliding against the rotors there is no heat produced at that point period.
  15. philobeddoe
    575
    107
    Los Angeles
    stand on the brakes ... glaze rotors ... die
    shift to neutral, apply brakes, steer to safety ... live
    shaZAAM!
  16. jburns
    829
    111
    Archdale, NC
    Pretty much sums it up.
  17. fuzzy1
    10,603
    ... as long as allegations that the vehicles cannot shift to neutral are scarce and unverified.
  18. philobeddoe
    575
    107
    Los Angeles
    well, just in case i'm installing a "self-destruct" mod, so if my car goes absolutely haywire and it won't shift into neutral, i pull a lever and a unicorn leaps out of the center console ... i ride the unicorn to safety while the car evaporates into a cloud of environmentally friendly pixie dust which has a secondary affect of "cooling" the atmosphere ... :D
  19. fuzzy1
    10,603
    I have first-hand experience with a car transmission jamming in gear, unable to shift to neutral or anything else, so I know that it is possible. Or was on a 1963 Rambler.
    Fortunately, like my pedal misapplication incident, and my floormat jam incident, it was a single fault. But if I could personally experience each of these lone faults, is it a stretch to believe that some multiple-fault incidents may occur among a sample population of 200,000,000 drivers? Statistics, not pixie dust.
    I'm not fearing them because each was resolved with at most a moment's danger, less hazard than commonly encountered in ordinary traffic. But statistics do mean that not all these faults will occur in as benign circumstances as I encountered. And some drivers will not have respond as well.
  20. philobeddoe
    575
    107
    Los Angeles
    i was just being a wiseguy
    i know it's "possible" that a Prius can lock out of neutral via a software failure, simply because virtually anything is statistically possible
    that's why i'm playing it safe with the unicorn :thumb:
