Toyota's runaway-car worries may not stop at floor mats-LA TIMES
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Jasonsprite, Oct 18, 2009.
  1. philobeddoe
    philobeddoe ΜΟΛΩΝ ΛΑΒΕ
    575
    107
    Los Angeles
    That's a problem. Did you test it at speed?
    How about Reverse and Park.
    If it's not immediate, they should recall and reprogram.
  2. fuzzy1
    10,603
    It is a feature. RTFM page 171, though it doesn't specify how much delay.
    Yes, I have tested it at speed, when new (until finding it discouraged in the manual) and again yesterday. So have numerous other folks here.
    I haven't tested R and P at speed.
    The manual discourages shifting to N at speed due to unspecified possible damage. The known possible damage mechanism, as expressed here, is overspeeding MG1. That seems to be a risk only when N is entered when ICE is off (possible only below 46 mph), then speed increases above 46 mph (i.e. coasting down a steep hill). There seems to be some margin built-in margin. This scenario will not be encountered with a runaway ICE, and regardless, is much less serious than a runaway car.
  3. ManualOnly
    ManualOnly New Member
    193
    28
  4. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    Obviously, your question about "neutral" has already been answered. But, I want you to do an experiment for me. Start your Prius and drive to one end of your residential street. Turn around and as you are driving past your house, hand your Prius key fob to a family member through the driver window (while still moving forward at 5mph - never come to a complete stop), then continue driving at 10mph down your residential street. What happens?
    (alternatively, you can just toss the key onto your front lawn - with a string or something attached so you don't have to search for it later)
  5. philobeddoe
    575
    107
    Los Angeles
    or, keep a 30 gal barrel of kerosene in the back, and if you lose control of the car, set it afire ... then blow your magic unicorn whistle
    when your unicorn runs up next to your car, leap from the window onto its back and ride off to safety
    if any flying monkeys try to stop you, the unicorn can gore them!!!
    then your Prius will explode before anyone comes to harm, and you can ride the unicorn to over to Tupac and Biggie's house and get high on pop rocks and coke!!
  6. Rybold
    2,760
    322
    Southern California
    CAUTION: Don't shift into reverse if you are going UNDER 5mph. It will actually shift and it will sound and feel like your transmission just ripped away from your engine. (Many years ago, I was in a huge hurry while pulling into a gas station, went too far past the pump and quickly shifted to reverse (before coming to a complete stop), and it actually made the shift. Tires did not squeel, but instead the transmission made the most terrible sound I've ever heard and the whole car JOLTED. I panicked, and immediately began testing my transmission to make sure I hadn't just screwed it up big time. It was okay, but I learned a HUGE lesson and I will never make the mistake again. If you shift into reverse in a Toyota at 40mph, it will default to neutral. But I am warning you, do NOT try this UNDER 5mph - or you will be in for the scare of your life. (Of course, this is on a 2004 Corolla, and the Prius - being electric at 4mph - may be programmed to respond differently)
  7. philobeddoe
    575
    107
    Los Angeles
    meh ... i've already done it ... that didn't happen
    i don't know what the heck you're driving, but every auto trans i've ever owned had a reverse lock out
    respectfully, i think you're high :D
    ok, gotta go walk my unicorn and put him to bed
    g'night
  8. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    The Prius will shift into reverse and park while moving forward. An electronic lock-out keeps it from happening at speed, but at very slow forward speeds it will shift. The results are sudden and dramatic for Park. Although presumably not damaging, I don't recommend shifting into Park at anything faster than zero.
    Tom
  9. qbee42
    18,058
    3,081
    Northern Michigan
    The Prius indicates that a key is no longer present, but will drive until shut down. After that you are stuck.
    Tom
  10. philobeddoe
    575
    107
    Los Angeles
    shifting to PARK in the Gen II at 2mph or greater is locked out ...
    that is, you are immediately shifting to NEUTRAL
    same with REVERSE
    it's Neutral
  11. qbee42
    18,058
    3,081
    Northern Michigan
    Exactly. I've done it too. Less than two mph is the "very slow forward speed" to which I refer. Dropping the parking pawl into place at just short of 2 mph is quite a shock. If you haven't tried it, another experiment is due.
    Tom
  12. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
  13. philobeddoe
    575
    107
    Los Angeles
    i done it :thumb:
  14. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    That was awesome! :) That was my favorite post of the day, especially going to visit Tupac and Biggie. lol
  15. bwilson4web
    16,391
  16. philobeddoe
    575
    107
    Los Angeles
  17. qbee42
    18,058
    3,081
    Northern Michigan
    Make sure to tell people to wear them upside down. That way, in the event of runaway, they can look down, read the pin, and be reminded of what to do.
    Tom
  18. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Great idea! Maybe we could make people wear them on their pockets too. That would seem to be the most appropriate way to wear them since it would be in direct view when the person is bending over to kiss their A%$ goodbye! :D
  19. philobeddoe
    575
    107
    Los Angeles
    i plan on only making them available to 911 dispatchers for a limited time
  20. fuzzy1
    10,603
    But that would be unfair to the numbskulls and bimbos who don't have cell phones. Or who, in a life threatening emergency, dial a friend instead of 911.
    I was also going to say that this would be unfair to those in areas without cell service, but many of the potential beneficiaries there have already been deselected from the gene pool.
