Toyota's Sets PHEV Release Date
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by hill, Oct 3, 2009.
  1. drees
    drees Senior Member
    1,782
    247
    Just minor correction here - they said they're sticking with NiMH for hybrids - PHEVs and EVs will require Lithium batteries because of the power/energy to weight/size advantage.
  2. hampdenwireless
    hampdenwireless Active Member
    1,104
    86
    Baltimore MD
    Its not going to be that high. $39,900 - $7500 plus in many states they probably will not be sales taxed or that will be refundable as well.
    We don't know.
    $32,400 is right around where I would consider the purchase.
    A Prius PHEV at $29,000 - $3750 credit = $26,250 (half due to smaller battery) would be a nice deal as well.
    The AMT does not effect as many people in 2009 and 2010 due to the ARRA.
  3. hill
    9,039
    Source / link ?
    First, even the heavy clunky RAV4-ev with its 780 pound nickel metal hydride pack could travel 100-125 miles or more ... so perhaps you can go into more detail than power/energy to weight/size advantage cursory comment.
    As for cost? Consider that back maybe 8 years ago or so ... the price was $225 nickel metal hydride to $350 lithium per kWh, according to the California Air Resources Board.
    Consider the 700 lb NiMH pack, amortizing its CARB-estimated $13,000 cost at 6.5 cents per mile, no Lithium battery pack has so far exceeded 50,000 miles in a production car. While Lithium is lighter, you have to consider life-cycle costing, and Lithium's slight advantage in weight is not worth the shorter life, thermal and toxic dangers, and wildly more expensive life-cycle cost. Lithium certainly has promise, but it aint a silver bullet.
    Toyota is up on Nickel metal hydride for a reason.
  4. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    The biggies, NY / Cali / NJ, are not states that refund monies out of the goodness of their cold dark hearts. Sales taxes in these states are 8+% meaning another $3000+ in local taxes has to be tacked onto the acquisition price. These states need the funds too badly to give them away. Yes some states certainly do; CT, WV, CO come to mind I believe.
    The buyers still must qualify for a $40000+ loan with the lenders - or come up with a significant amount of cash :eek:. This immediately limits the scope of who can buy regardless of the Tax Credit. In today's new financial environment fewer and fewer buyers qualify for this amount of a loan. Some well-to-do buyers certainly will be able to do so. Again, these are the very ones that are most effected by AMT.
    In your Prius calculation you didn't take into account the cost of amortizing the R&D for the PHEV system. You've got to look at adding upwards of about $10,000 to your estimate. Those costs have to be taken into account. $1 Billion / 100,000 units.
    I've been pointing these 'hidden hooks' out for at least three years now. When the PHEV Prius does actually arrive with a price tag of ~$37,000, a range of 15-20 EV miles and a very low level of real interest ( meaning actual sales ) a lot of the pundits will be saying "Epic Fail". This won't be an issue only for Toyota.
    GM is pinning ALL their hopes on the Volt at $40000. At least Toyota has the hugely successful traditional Prius to keep churning out sales and profits. GM nas nothing to fall back on if the Volt isn't wildly successful immediately.
    I don't see either vehicle being anything more than a curiosity and an ultra-niche vehicle.
  5. drees
    drees Senior Member
    1,782
    247
    Green Car Congress: Toyota to Stay with NiMH for Mass-Market Hybrids
    I thought there was more detail in that report - I may be reading in between the lines a bit there.
    Not sure if this is the latest data (the Lithium power/weight ratio looks low) but here's some quick data:
    Nickel-metal hydride battery - Wikipedia, the free encyclopedia
    Lithium-ion battery - Wikipedia, the free encyclopedia
    Are you sure? Because only recently could decent Lithium cells be bought for ~$350 / kWh.
    It all depends on the exact chemistry of the Lithium battery. Some lithium cells are significantly more energy dense than NiMH. Some are only slightly more so, but are also much more durable and have higher power / weight ratios.
    Just an example of how much lighter Lithium is compared to NiMH - The Tesla pack weighs about 900 lbs and stores up to 53 kWh. The RAV4-EV pack has half the energy but weighs nearly as much.
  6. Cacti
    Cacti Poleikleng
    193
    Massachusetts
    Has anyone read the book "Plug-In Electric Vehicles, What Role For Washington?" Covers all the issues.
