TPMS lifespan?
Discussion in 'Gen 2 Prius Main Forum' started by gring40, May 14, 2023.
Tags:
  1. gring40
    gring40 Junior Member
    59
    Northern Illinois
    We have a 2006 with 40k miles, so about 2.5k a year, mostly local. All tires had a slow leak, faithfully reported by TPMS, reportedly due to ‘dry rot’, maybe rim leaks, but OK tread; no water-test leaks evident. We got new tires and the leaks are gone; TPMS is happy. Understand that TPMS battery lifespan should be about 7 years, and cannot figure how the system can still be working well after 17 years now. Any insight or explanation for this?
    52,927
    none. mine is still going strong after 11 years. hard to figure, maybe worse in southern heat?
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Are you REALLY saying that you were driving on 16 year old tires ??
    If so, that is beyond stupid. :eek:
    52,927
  5. ChapmanF
    19,088
    I had one transmitter poop out about a year ago at 12 years. Other 3 still keep on ticking.
    douglasjre likes this.
  6. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    My 2008 need all 4 replaced last year. Colorado cold was hard on all batteries.
    ColoradoBoo likes this.
  7. gring40
    59
    Northern Illinois
    Oh no, tires have been replaced several times, as needed. Saying that TPMS system is original.
    Dualblue and bisco like this.
  8. Mendel Leisk
    42,389
    The TPMS light on our ‘10 (build date August’09) lit up about a month back (about a month after reinstalling OEM’s), and I thought ok that’s it for the sensors. Then after a few days light went out again.
    It was pretty chilly when the light triggered, but now,
    #8 Mendel Leisk, May 14, 2023
  9. gring40
    59
    Northern Illinois
    I find it normal for tire pressures close to the TPMS threshold to trigger the warning lamp when it is chilly, and then to turn the lamp off when the weather gets warmer.
  10. ChapmanF
    19,088
    When the time comes for your transmitters to poop out, look for the warning light to blink for a minute and then turn steady.
    Did they all poop out at once (C2121, C2122, C2123, C2124 trouble codes all at the same time)? Or did they all get replaced on principle, after one pooped out?
  11. Tombukt2
    Tombukt2 Senior Member
    13,886
    2,521
    Durham NC
    The pacific branded sensors that came on car are only 39x a set of four on e bay . We use the green logo units
  12. sam spade 2
    7,035
    2,804
    2017 Prius c
    Heat is hard on batteries, all kinds.
    Just keep driving until one fails and then replace all 4 if you intend to keep the car.
    I think most people don't have to worry until about 10 years.
  13. gring40
    59
    Northern Illinois
    OK, I’ll wait for this sign plus some OBD trouble codes, tho it was scary to just replace the tires and not the TPMS.
  14. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Pretty sure the battery usage is minimal when the wheels aren't rotating, so with only 40k on them they may last longer than others.
  15. gring40
    59
    Northern Illinois
    Good thought; fingers crossed!
  16. Mendel Leisk
    42,389
    And when they fail, doing nothing is an option.
    gring40 likes this.
  17. Aegean
    Aegean Active Member
    464
    209
    Alexandria VA
    At 15 years, I replaced all 4 TPMS but 2 were still fine. The TPMS lasted more time than my hybrid battery.
    gring40 likes this.
  18. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,019
    NJ-USA
    "Average" life span of a TPMS sensor battery is 10 years- with average driving. Much lower use will result in the sensors reporting in less frequently.
    Sensors transmit data about 1 time per minute when the car is moving, vs 1 time per 5-10 minutes when stationary. A sudden pressure change will trigger an immediate report.
    The system should turn on the warning light if pressure drops to 80% or less of "sticker" value.
    gring40 likes this.
  19. JoeB
    JoeB Junior Member
    17
    Rockaway NJ
    My 2009 2nd gen is at 200k miles and still appears to be on the first set of TPMS sensors. This winter, they reported accurately when either a slow leak (since fixed) or cold weather dropped a tire pressure to below normal.
    gring40 likes this.
  20. ColoradoBoo
    ColoradoBoo Senior Member
    1,359
    988
    Monument, Colorado USA
    Yep our extreme temps here in Colorado don't do those little batteries in the TPMS's any favors....ours usually start going out around the 10-year mark.
    So I'm expecting some to start going in my 2014 Tundra. (Just replaced her 12-volt battery but she lasted 5-years so that was good...replaced it with the same one from O'Reillys.) The battery still worked but tester was showing it was down to 40% and "replace"
