TPMS lifespan?
Discussion in 'Gen 2 Prius Main Forum' started by gring40, May 14, 2023.
Tags:
  1. ski.dive
    ski.dive Active Member
    967
    247
    Hutchinson Island,FL. Mt. Snow,VT
    My TPMS stopped working 8 years ago, I never replaced them= I just monitor the tire pressure on my own.
  2. gring40
    gring40 Junior Member
    59
    Northern Illinois
    And what about the dashboard warning light?
  3. Mendel Leisk
    42,364
    What about it, lol.
    We're looking at that light about 5 months out of the year, when the snow tires are on. It gets easier.
  4. ColoradoBoo
    ColoradoBoo Senior Member
    1,354
    982
    Monument, Colorado USA
    Just do a quick walk-around the car before getting in to check the tires. Some folks will, even, give them a kick to make sure they aren't soft.
  5. gring40
    59
    Northern Illinois
    OK, but to be clear, after the TPMS batteries fail, that dash warning light stays on, and can’t be turned off?
  6. ColoradoBoo
    1,354
    982
    Correct...it's a safety feature, no way to turn it off unless you got behind the dash and disconnected the wire from the light.
    gring40 likes this.
  7. ski.dive
    967
    247
    I covered the TPMS warning light with double sided tape on an Indian Head Nickle, that I place over the warning light.
    No more TPMS light...You can use double sided tape on a regular Nickle or Quarter to cover the light
    #27 ski.dive, May 20, 2023
  8. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    I wonder if anyone was brave enough to set the ID to all 0s to see if it disables…
  9. ChapmanF
    19,041
    I've just had the second one stop transmitting, two years and a bit after the first one.
    But the one that just stopped was ok right until the tire it was in got burst by a fallen rock in Yellowstone, and has not worked at all since the tire was replaced. So I can't say for sure whether it was about to poop out from old age anyway, or got killed by the bursting of the tire, or got damaged when the nearby Walmart replaced the burst tire.
  10. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    If you get the Chinese one I'll tell you it last 3 years if it works at all. First-hand knowledge here
  11. ChapmanF
    19,041
    Even weirder: the one that stopped transmitting when I had that tire changed at Walmart outside of Yellowstone, I never got around to replacing. I bought another transmitter, and then thought "these tires are about ready to replace, maybe I'll wait till I do that", and never changed that transmitter out.
    Back in January, after a year and a half with the TPMS light blink on every startup, that transmitter resurrected itself. It was during that crazy cold snap, and I noticed the TPMS light wasn't on anymore, and wondered "how'd that happen?". And a scan tool showed good data from all 4 transmitters.
    I don't know the explanation. Something about the Walmart tire change left the sensor messed up, and the cold snap reset it?
    Anyway, it's still in there, and still doing just fine. So the updated tally is: my car's 16 years old now, and I replaced one transmitter at 12 years when its battery conked out, and the other 3 are still original, and I have a spare I bought a year and a half ago and I guess I'll use it for whichever one of the original 3 conks out next.
    VelvetFoot likes this.
