tpms light
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by 510bg, Aug 5, 2013.
  1. 510bg
    510bg Member
    142
    Just stopped at the dealer service center asked to fill tire to 42 front 40 rear they said no due to the TPMS light going off they said they would go 5 above spec based on the inside door. I'm pretty sure they are BSing but I wanted to confirm on Prius chat.
    52,878
    i'm at 42/40, no prolemo.
  3. 510bg
    510bg Member
    142
    Ok gotta go to a tire shop or buy my own equipment
  4. 510bg
    510bg Member
    142
    How often do you check the tire pressure?
  5. bisco
    52,878
    around once a month, they hold pretty well. i got a screw a few weeks ago and sensor came on. first time in 9 years.
  6. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I have this software on my XP OS laptop (only OS it will work on) It has tire pressure readouts.
  7. mrbigh
    3,686
    699
    Long Island, NY
    I'm in the same situation with out a single problem with the TPMS.
  8. retired4999
    2,652
    627
    Eau Claire, Wi.
    I have been running my psi at 42 front 40 psi rear since 2005. No problems here!
  9. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    The dealer's answer is ridiculous. The TPMS will trigger if a tire drops below the preset psi number. You can reset that number (see owner's manual for the procedure). But even if you don't, having a higher pressure in the tires doesn't do anything- you would simply have to have more loss of air in any tire before the alert would be triggered. For example, say the system is set to warn you when any tire goes below 28 psi. If you start at 33, it goes off when you lose 5 psi. If you have 40 psi, it won't warn you until you have lost 12 psi, which you ought to notice just by driving. I prefer to run 42/40 and have reset the TPMS accordingly.
    510bg likes this.
  10. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    If it goes 5 psi BELOW, the light will come on.
  11. rogerv
    1,639
    317
    Right, I wasn't clear in my previous post, but it is triggered if a tire drops 5 psi below the preset desired psi number in the system. It doesn't compensate without you putting in a higher number if you raise your pressures to 42/40 as a lot of us have done. OTOH, more sophisticated systems track the pressure in each tire, and in the case of Cadillac, warn you of over inflation as well as under, again based on where you have the pressures when you initialize the TPMS.
    Maybe the dealer person mentioned didn't understand that raising the pressure would not have the same effect as lowering the pressure by 5 psi, thereby triggering an alert.
    usbseawolf2000 likes this.
