TPMS Management with Techstream
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by wjtracy, Mar 5, 2016.
  1. wjtracy
    wjtracy Senior Member
    11,371
    3,608
    Northern VA (NoVA)
    As many of us are finding out, the TPMS system in our tires only lasts about 8-10 years, then the TPMS unit batteries give out, and then you get a flashing TPMS warning light on your display.
    Replacing these TPMS sensors can be costly at a repair shop, so this is a good time to use the Techstream software with mini VCI to minimize your repair costs.
    This YouTube video gives a pretty good description fixing one TPMS sensor for a Toyota Highlander:
    For my 2006 Prius, I found the fifth tire (ID5 in Techstream - the spare tire) was not used, so it had a code of 0000000.
    The bad TPMS for my car was ID1 (right front tire for my Prius it turned out). I was curious to know if I could simply shut off ID1 in Techstream, so I set it to 0000000. Sure enough that stopped the error code and flashing TPMS warning light.
    The next thing I am going to do is buy the Denso replacement sensor from Amazon like the guy in the Highlander video. Hopefully setting the code to 0000000 was not a mistake as far as being able to edit the value again in the future.
    UPDATE:
    So looks like the 0000000 hack may not work after all:(
    On my Gen2 it does indeed turn off the TPMS light, but it seems like the effect is temporary. I will see how long the TPMS light stays off this time, but I believe it was over a week last time.
    Also entering the same Code twice does not work, as the four codes entered must be unique.
    So I appear to be out of ideas to turn off the TPMS light permanently, except the possible idea of entering zero codes for all four tires. The only other hack idea I have left is to buy a new TPMS and hook it up externally say to spare tire to turn off the TPMS light.
    #1 wjtracy, Mar 5, 2016
    booi and jdcollins5 like this.
  2. Mendel Leisk
    41,908
    Thanks for this. Still, my approach, if and when they die: fugedabout it. Guess it'll take legislation, for Toyota to implement an easier to service system.
  3. dpeverhart
    dpeverhart Member
    126
    23
    I
    Interesting. What field did you set to 0000000? Is it the sensor ID field?
  4. wjtracy
    11,371
    3,608
    Northern VA (NoVA)
    Exactly...instead of entering say 83C5183 just enter 0000000. The other hack approach would be to enter the same code twice for a working sensor (have not tried that yet). I am hoping entering 0000000 does not permanently disable the sensor, so not quite ready to proclaim success. When you assign the codes, you have to enter all 4 tires, so you first need to go to the data screen and write down all the codes.
    But bottom line seems to be, you can use Techstream to easily turn off the TPMS system if you just want to bag it after the sensors start failing. I want to see how long they can last.
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Just FYI - I was checking my TPMS with Techstream. The Gen 3 spare tire does not have a TPMS sensor and has the 0000000 code set.
  6. wjtracy
    11,371
    3,608
    Northern VA (NoVA)
    UPDATE:
    So looks like my 0000000 hack may not work after all:(
  7. Stevewoods
    Stevewoods Senior Member
    663
    1,200
    Seattle, WA
    FOUL, I cry FOUL. Curse you sir and all your issues:p
    I ordered the Mini VCI over the weekend. I have no idea how to work it, nor do I think I will be able to work it. But, if I were, the first thing I was going to do was to shut down the tire pressure sensor!
    Hmmm, Have to have a new goal for it -- if it ever arrives! :D
  8. Mendel Leisk
    41,908
    What's the object of shutting down a sensor? Is it for scenario where one has a dead battery, but the others are still working? To avoid false alarm from the one dead one?
  9. Stevewoods
    663
    1,200
    Seattle, WA
    Because every change of seasons, changing temps cause tires to dip a bit in pressure. I am at work. Wifey gets in Prius, drives it a couple of blocks, gets the Tire warning, refuses to drive another foot. I have to leave work and deal with it! Maybe I am over-reacting, but the whole "my tire light is on," gets old pretty quick. o_O
    I do check the tire pressure every couple of weeks with my German analog gauge. They are fine. Except when they are not.
  10. wjtracy
    11,371
    3,608
    Northern VA (NoVA)
    My apologies, but managing TPMS is still a good way to use mini-VCI.
    Eventually the final "fix" for me is to buy a sensor from Amazon, take the tire over to a tire repair place, and they can put the TPMS in. I can then register the code with Techstream. And the only way I know which tire was bad is via Techstream.
    Having 3 good TPMS is better than None!...None is what you get when one goes bad on a Toyota. Looks like I lost one at 9.5 years and the 3 others are still ticking.
    Other vehicles (Cruze etc) let you see the pressures on the car's screen, but I think Toyota only gives us the warning light, so that is the problem.
    Ultimately I am just trying to learn the limits of what can be done DIY.
    #10 wjtracy, May 18, 2016
  11. wjtracy
    11,371
    3,608
    Northern VA (NoVA)
    My wife just said: "Hooray! the TPMS light is off today!!"
    But somehow it seems to take Gen2 a while to figure out I faked it out with the 0000000 code. We'll see how long it takes to come back on. I did do it a little different this time...outside chance it will stay off but I am not optimistic.
    This time, I put the zero code in for a "good" tire. So now it has 37 psia in the data register, even though the 37 psia is not getting updated. Last time I put the zero code in for the "bad" tire so the NA bad reading was still in there. Then I gave the "bad" tire a good TPMS code, so now it has a 37 psia real reading in the data register.
    In another thread, PiP owner @Rebound found the zero code did not work for him, suggesting the PiP updates the data more instantly than my 2006...stay tuned.
    #11 wjtracy, May 19, 2016
    Stevewoods likes this.
  12. Mendel Leisk
    41,908
    On ours the TPMS light is on with the snow tires. We somehow muddle through, lol.
  13. wjtracy
    11,371
    3,608
    Northern VA (NoVA)
    Our TPMS warning light is still off 3 days later...but we don't do many long trips these days so I do not know if we did a longer trip if the system will start to realize the tire with the 0000000 code is not getting updated. I will of course report back...
  14. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    WAG idea: Rather than 000000, duplicate the number of one of the sensors that still works. Low chance working, but why not try?
  15. wjtracy
    11,371
    3,608
    Northern VA (NoVA)
    Tried that. Turns out that idea does not work. It needs 4 unique codes.
    Right now I am good though...no lights on yet.
    #15 wjtracy, May 23, 2016
  16. wjtracy
    11,371
    3,608
    Northern VA (NoVA)
    Argh! our TPMS light came back on today, after I let the car run in PARK for a good while. Thus it appears we have a time lag in Gen2 where it takes the system a while to (week or so) to wise up to the 0000000 code. So I am out of ammo on trying to turn off the TPMS system or a tire. I keep trying things.
    >>in any case, Techstream approach for Gen2 works temporarily as long as it works
    #16 wjtracy, May 25, 2016
  17. Stevewoods
    663
    1,200
    Seattle, WA
  18. wjtracy
    11,371
    3,608
    Northern VA (NoVA)
    Having so far failed at using Techstream to disable TPMS to turn off the darn warning light, I am resorting to Google to find other solutions:
    Here are three solutions:
    How to disable TPMS - Toyota Nation Forum : Toyota Car and Truck Forums
    Turn off your TPMS light FOREVER! | Tacoma World
    Disable TPMS | Toyota Tundra Forum
    These are:
    (1) One I also thought of, hooking up good TPMS to a pressure source outside the tire;
    (2) In Toyota's, disconnecting TPMS lead wire to the combination meter
    (3) Locate DENSO TPMS receiver module (where is it?) and disconnect appropriate wires
    #18 wjtracy, May 26, 2016
  19. Mendel Leisk
    41,908
    When your other TPMS sensor batteries fail, this becomes moot?
  20. wjtracy
    11,371
    3,608
    Northern VA (NoVA)
    And here are some prior PriusChat ideas including one from pEEF
    Anyone know how to disable TPMS ? | PriusChat
    pEEf shows how to disable Gen3 TPMS with a paper clip jumper but there is no discussion of Gen2 (several asked about Gen2).
    @RobH says he reset his TPMS computer for 5 tire codes (including spare) so I wonder if we can set it for 3 tires? I ask RobH
    #20 wjtracy, May 26, 2016
    SFO likes this.
