1. Air_Boss
    Air_Boss Senior Member
    4,236
    1,191
    New Yawk
    After setting TPs to 41F/40R and resetting the TPMS via the under-dash button, and driving the v5 around, I still get the intermittent then constant TPMS warning indicator. It's not the TPs. Perhaps it's the TPMS sensors? Any ideas? TIA.
  2. moparjer
    moparjer Junior Member
    Oregon
    I'm just guessing but did you check the spare? My RAV4 TPMS light would come on when the spare was low.
  3. Air_Boss
    4,236
    1,191
    New Yawk
    Worth checking, though I am under the impression the spare does not have TPMS.
  4. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    The would be correct according to the manual. When you use the reset button, are you sure you're getting the confirmation blinks on the dash?
  5. Air_Boss
    4,236
    1,191
    New Yawk
    I checked the spare and it has a rubber valve stem (and was inflated to 50).
    I don't get the three confirmation blinks; it is already blinking from "GO", when I try to reset it.
  6. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Are these the original wheels?
    The system must be reset with the vehicle in the "On" state, not with the hybrid system running. Leave it in the On state for a few minutes, then shut it off.
  7. Air_Boss
    4,236
    1,191
    New Yawk
    Original. The hybrid system starts when the ON button is pushed. How can it be On if it's shut off?
  8. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    That's the problem. Keep your foot off the brake, push the power button twice. Now you're in "On" mode but the hybrid system is off. Same as turning an ignition key to on without starting the engine. The dash lights up and everything is on but the hybrid system. Pushing it just once gives you the "ACC" function with only audio and apps. You should also have a solid orange power button.
    Air_Boss likes this.
  9. Air_Boss
    4,236
    1,191
    New Yawk
    Aha...
  10. Air_Boss
    4,236
    1,191
    New Yawk
    No joy. Single push gets me an orange button LED but no indicator lights or beeps. Two pushes gets me an orange LED, a full panel of lights, a flashing TPMS light, no beeps (other than seatbelt warning), and no reset.
  11. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    I guess I have to refer you to the manual under the "do it yourself maintenance" section. there's no beeps involved.
  12. Air_Boss
    4,236
    1,191
    New Yawk
    I've read that, and having done so, there's no reset occurring...
  13. Air_Boss
    4,236
    1,191
    New Yawk
    TPMS light is no longer illuminated... After previously failing to respond to either calibrated tire pressure matching or reset button...
