TPMS question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by GreenGene, Oct 25, 2007.
  1. GreenGene
    GreenGene New Member
    177
    Northern Virginia
    I understand from other threads that the sensors for Tire Pressure Monitoring System in the Prius are attached to the tire valve stems and rims, and that it's important to let the tire installer know about it.
    Well, I just got back from Merchants Tire, and the guy I talked to said they replace all valve stems unless they are custom. But the Prius valve stems aren't custom - they came that way.
    Do I
    (1) try to explain (wondering all the while why, with all the Priuses around here, I should need to explain)
    or
    (2) try someplace else?
    Also, if the owner's manual has any useful information about the TPMS sensors and just where they are with regard to the tires, I'd love to know on what page(s) that information appears. I have a feeling that I would be advised to take something in writing to Merchants before they believe me .... but at that point, will I be able to trust them?
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    Tell him they wheels have sensors on the stems and to leave them alone.
    Tom
  3. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    they mean replaceable valve stems. these are not replaceable. unless they've got $400 or so to reimburse you.
