TPMS Reminder - Batteries don't last forever
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by srellim234, May 1, 2016.
  1. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    If possible, check the signal strength of the TPMS transmitters when changing tires. It can save some grief and effort later since the batteries in those things don't last forever.
    We just had new tires installed last week but didn't check the transmitters. Saturday the solid TPMS light came on (not flashing which indicates a low tire pressure) and we happened to be close to an America's Tire where they checked them for free. The left rear wasn't transmitting any more and the two right side ones are weak. The transmitters are probably the same ones that came with the car 8 years ago and the batteries are dying. It would have been much easier if we had checked them and changed them with the tires. We only had them change the one that triggered the alert but we'll do a little preventative maintenance and replace the other three in the next few weeks.
    52,855
    thanks. is it illegal to drive without them?
  3. srellim234
    1,201
    1,694
    Laughlin, Nevada
    I think the requirement is that the car manufacturer has to put them on the car but even though it's a good idea I don't think the car owner has to maintain them. The easiest thing is to just change them every 5 or 7 years with a tire change or just live with the idiot light on the dash. It would be nice (and much cheaper) if the batteries were replaceable but from what I understand they are sealed units with the equivalent of a watch battery inside.
  4. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    I didn't know you could check the signal strength. How do you do that? I didn't notice that feature on the Mini VCI, but I haven't really looked and the car's not here this week.
  5. JC91006
    16,936
    8,647
    I've never had tpms sensor fail, even my 2004 Sienna ones are working and original to the van
    SM-N900P ?
  6. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    That's hard to believe but mine are just going bad 150k miles and 9.5 years...2 down..2 to go
    How many miles on that Sienna as miles plays a role? And how many Toyota's you got over there?
    PS- mid 2006 or so was first year AFAIK, and maybe 2007 was mandated first year
    Your 05s don't have any, probably your Sienna don't have it, your 2006 should have 'em I think you bought Sept 2006 right? Miles now? Should be ready to go bad, although perhaps not all 2006 have it.
    Techstream the TPMS in your 2006 see if you have unique codes set for each TPMS.
    #6 wjtracy, May 1, 2016
  7. bisco
    52,855
    how can miles effect battery life, do they get dizzy?
  8. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Zactly and they only get dizzy when you drive. Each TPMS is equipped with a tiny 2-way wrist radio so they know when the car stops and that's when they catch some zzz's...at least I heard they go off when not in use somehow
  9. srellim234
    1,201
    1,694
    Laughlin, Nevada
    I don't know how as I'm not much of a DYI guy. The guy at the shop went into the service bays and retrieved some kind of reader they keep in a case that had to be held close to each tire sensor. He did it while the car was turned on to READY. I wonder if it might be more of a signal strength reader you would get from a computer shop as opposed to a regular automotive diagnostic tool.
    While I was looking online earlier today I found a TireReview.com article from 4 or 5 years ago about this issue. The opinions among the automotive "experts" they checked with were all over the board, but most were in the 5-7 years and around 100,000 miles range. They all agreed that they all need replacement eventually. There was also discussion of manufacturers working on a non-battery operated sensor that would be permanent. I don't know if anyone has ever come up with that one but I certainly don't see it happening from any main stream car manufacturers. They can make too much money off replacement parts and installation.
  10. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    IIRC some cars I think Chevy Volt use the speed of the tires to pick up a low pressure, so that get's away from the darn battery issue.
    In Virginia, the TPMS does not affect passing inspection. So right now I am living with it until I decide what to do. I used Techstream to deactivate one sensor but next thing you know another one died.
  11. andrewclaus
    993
    326
    Golden, CO
    Okay, thanks. I looked online and saw a couple of readers, costing a couple hundred bucks. Not exactly a DIY tool.
    srellim234 likes this.
  12. JC91006
    16,936
    8,647
    My Sienna is driven about 5000 miles a year now. It currently has 118000 miles. I thought these sensors last forever LOL
  13. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Indirect Toyota TPMS
    Toyota vehicles Sienna (pre-2006), Camry Solara (2004-6), Highlander (2004-7), Corolla (2005-7), and Matrix (2005-7) used an indirect or ABS type TPMS. This system uses the existing wheel speed sensors in the antilock brake system (ABS)
  14. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Me too. Just had new tires put on about 4 months ago and just got a TPS dash light. Steady light. 9 years later. Not bad.
    You can go into Techstream and turn off that light.
    New TPS's are Denso's part # 550-0103 Amazon.com In fact I think it was WJ who posted this info I'm using here. If so I thank you sir.
  15. Kenny94945
    Kenny94945 Active Member
    864
    439
    Sausalito
    2016 Prius v wagon
    Any further info?
    Pictures of sensors?
    Are all 4 generation's sensors the same?
    (Guess I could look up the part number)
    Are the sensor batteries plug and play replaceable?
    (I have seen some sensors where it is a major operation to "cobb" in new batteries)
    Cost of sensors can be $100 a piece in many cars...plus the programing matching procedure.
    What's Toyota's price?
    Many here are stating Toyota sensors have a 7 year life to failure.
    10 years is not unexpected on many other car brands.
    Not illegal to not have installed...some even remove the system, so the dash light doesn't illuminate, and when they go to winter or racing rims.
    I really wish the system should actual tire pressure by .5 psi increments on the dash board screen menus....that would be useful.
    What did we ever do before TPMS? sarcasm.
  16. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Problem is if you just go into your shop or Toyota and say fix all 4, could be approaching $600 or more, so it's a pain in the butt. Many may choose to live with TPMS light. With Techstream you can essentially deactivate system by yourself but it is against the law for service shops to disable.
    I have a thread on using Techstream to manage this. Even if you don't have Techstream it is perhaps helpful. The Gen2 OEM TPMS can be got at Amazon for about $35 per tire. You still probably have to pay tire shop a fee to deflate you tires and insert. So it's best to catch it proactively when you change tires.
    Mine lasted 9.5-yrs and 150,000 miles. It's a pain that Toyota does not show Tire Pressure data on the screen...even Cruze does that, right in your face the Cruze display is. That would help get better MPG and remind users to replace when they change tires.
    TPMS Management with Techstream | PriusChat
    #16 wjtracy, May 3, 2016
  17. srellim234
    1,201
    1,694
    Laughlin, Nevada
    The America's Tire in Victorville was $60 for the one new sensor including installation. Yesterday I went back to the Upland location (they just put the tires on last week) and the manager met me in the parking lot with his scanner. He had already seen the email I sent about it.. After he personally checked them (and did see one of the two remaining weak ones had failed) the manager apologized up one side and down the other for it. He said they are supposed to check them and the tech claimed the sensors checked out fine.They offered a big discount on replacing the other three. I'll probably get that done next week.
  18. Mendel Leisk
    42,347
    I have no problem living with a bitty orange TPMS light, do it for about 3 months each winter, with our snow tires. It's even less noticeable than the passenger airbag status light. And there's no way I would repair or replace failing TPMS sensors, when they die they're gone.
    Sad thing is: I appreciate the system. But the implementation is to complicated and costly.
  19. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    That is basically a fantastic price. My shop quoted a much higher price.
    So the trick is going to the right place...probably tire shops.
    By the way, it seems to be the 17-in tires are harder on the TPMS so my observed 9.5-yr/150k miles may not apply there.
  20. srellim234
    1,201
    1,694
    Laughlin, Nevada
    I agree but we have decided to replace them only because of the cross country travel we have planned over the next couple of years. We're looking at two 2,400 mile trips planned for this summer and a 6,300 mile cross country trip next year. We figure it will just be a little added security and less stress knowing things are all working properly on those long lonely stretches away from home..
