TPMS (tire pressure) malfunction (?) on 2015 Prius V
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Badger52, Jan 9, 2024.
  1. Badger52
    Badger52 Junior Member
    Virginia
    2015 Prius v wagon
    Hey all, My TPMS light has come on, and I haven't been able to get it to go off. Here's the data:
    1 - Checked all four tires and inflation within a .lb or so of being perfect.
    2 - OEM original spare in trunk reads only 15 PSI on my handheld meter, door label says it should be inflated to 60 PSI, though it is HARD AS A ROCK....which makes no sense at all, so maybe it DOES have a sensor, though GEN 3 is said to NOT have a spare tire sensor. Any ideas?
    3 - Tried hitting the RESET BUTTON under the dash, but no response; tried it with basic elec. on, and with car fully on, and absolutely no change or blinking of any kind, so am a bit lost now.
    Any advice out here?
    Thanks for reading,
    John in FL.
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,071
    6,937
    Texas Hill Country
    Odds are good one of the sensors is bad.
    Kado123, Badger52 and Brian1954 like this.
  3. Air_Boss
    Air_Boss Senior Member
    4,256
    1,195
    New Yawk
    Agree. TPMS batteries have a finite time and cycle life.
  4. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    On our 2006 we had one TPMS go bad at 9 years, the other three lasted several more years. In any case, sounds like one of the TPMS has died. In most cases no TPMS on the spare.
    Badger52 likes this.
  5. Mendel Leisk
    42,323
    Maybe time for a new gauge too. Is this a cheap digital?
    Too, if all your regular tires appear to be ok, and your gauge is says the spare's at 15 psi, definitely look into it. Has it ever been topped up?
    Kado123 and Badger52 like this.
  6. ChapmanF
    19,008
    The button under the dash is used for setting what tire pressure you want the system to check for. When you have all four tires inflated to the pressure you want, if that is different from the originally programmed pressures, you use that button to have the car remember your new pressures. It will then give the warning at a threshold some % lower than those.
    If you haven't changed your mind about the pressures it's already programmed for, then what that button does isn't anything you care about.
    Does the warning light on the dash come right on solid after the car is turned on? (After going out once, briefly, after the lamp test) Or does it come on blinking for a minute or so and then go solid?
    The solid-from-the-start version is normally trying to tell you about an actual pressure issue. The blinks-then-solid version is telling you about a problem with the TPMS system.
    Do you have a scan tool that can show you the TPMS trouble codes? If not, I believe you can blink them this way:
    Blink (a/k/a Flash) Codes – How to. | PriusChat
  7. Badger52
    Virginia
    2015 Prius v wagon
    Hi Mendel - Thanks for asking :). My guage is a regular, non-digital one. No...have never topped off the spare, but I will drain some air out, and then see if I can get a correct reading off of it.
    DogDaze and Mendel Leisk like this.
  8. Badger52
    Virginia
    2015 Prius v wagon
    Hi Chapman - Thanks for responding! The warning light blinks for a bit before staying solid. I don't have a scanner, but I can get is scanned for free from a friend.
    DogDaze likes this.
  9. ChapmanF
    19,008
    Probably indicates the transmitter inside one of the tires has used up its battery.
    Pretty much any tire place can dismount the tire and swap in a new transmitter and mate it to the car and send you on your way.
    You face the question of whether to just replace the one that's conked out (the tire place should have a handy wand they can use to see which one that is), or all four because "if one battery went, how far behind can the other three be?".
    Sort of a matter of taste. Some will go for all four. I just changed my first conked-out one a couple years ago and am still waiting for the next shoe to drop. If a deer jumps on my car in the meantime, I never need to buy the other three.
    Also kind of depends on the tire place you use, and whether they'll give you some discount for doing all four, or if it's just four times the cost of doing one.
    DogDaze likes this.
  10. Mendel Leisk
    42,323
    Or just leave ‘em be, at least until the next tire replacement.
    DogDaze likes this.
  11. DogDaze
    DogDaze Member
    203
    44
    Bay Village
    This is where I'm at with this same issue.. All was good till it wasn't.. now I can't get it to quit blinking (then solid)
    Needs tires.. but wanted to hold till early fall.. the light is just annoying.. Not sure if it's $800 annoying or not?
    btw, I have a Bluedriver ODB2 scanner and it does not flag TPMS issues.. I believe the TPMS system is isolated from everything else.
    #11 DogDaze, Jul 10, 2024
  12. rjparker
    11,071
    6,937
    Texas Hill Country
    Flashing first means at least one TPMS sensor has failed.
    It is possible to have all four replaced for $100 total. Usually less than a new tire shop will charge.
    You buy four compatible sensors from Amazon, write down their serial numbers (ids) and have a small tire repair shop install them.
    First locate a shop that has an obd2 tool to write the serial numbers into the car ecu. The tool does not have to be Techstream; specialty tpms tools are available and many independent and all big tire shops have them.
    These are the sensors I use
    DogDaze likes this.
  13. Mendel Leisk
    42,323
    This is the serial number?
  14. rjparker
    11,071
    6,937
    Texas Hill Country
    No it’s the larger seven digit code
    DogDaze, Air_Boss and Mendel Leisk like this.
  15. DogDaze
    DogDaze Member
    203
    44
    Bay Village
    Thank You for your note and the detailed information.. I need to call around to get some numbers from the local tire shops nearby.
    The Costco Tire shop nearby (apparently) does not have the ability to do the programming needed. Said he can get me the sensors, but can't program them in.
    Quick Question, I've seen some compatible sensors online. They're showing CR2450HR Batteries or similar..
    Does anyone know if the batteries can be just changed out?
    I did find this link, TPMS sensor battery replacement. Here's how, but is it worth it? which tends to indicate they could be, but it appears that the Toyota OEM TPMS are 'potted' and so, probably not worth the effort.
  16. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    ^wow I do not think you want to mess with battery replacement. By the time the battery dies you want to replace the whole unit. Not Toyota but I've had some TPMS breakdown physically and cause blow outs.
    I see one rare exception for ripping apart and fixing battery if someone wanted to create a dummy reading to turn off the TPMS light, you could have a spare reading in the glove compartment. Then you still need to play with the TPMS to figure out how to add a fake pressure reading. I did a dummy TPMS on a Gen2 used a binder clip on it. That actually worked for several years until I replaced all.
    DogDaze likes this.
  17. DogDaze
    DogDaze Member
    203
    44
    Bay Village
    Thanks for your notes.. I agree that it's probably not worth taking them apart to change the battery, but do think it's crazy that the batteries can't be replaced at the tire shops when they install new tires. I actually (and incorrectly) assumed that's what the Costco TPMS pack did when they put the tires on for me.. they recently explained they only replace the seals and refresh the valve pack.. not the batteries.
    As for after market, vs: Toyota.. I see sets of 4 (Toyota) on eBay for ~$50... tho, I tend to wonder/question battery life as one would likely have no way to know how long they've been sitting around on some shelf.. or do the batteries not get 'used; until they install them? (lots of times you have to pull the plastic to active the battery in some products)
  18. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    I think the battery is not used much when sitting on shelf. TPMS batt life seems a bit random, but should be somewhat related to miles driven. I do not know why it often seems like one battery goes bad a few years before the rest.
    DogDaze likes this.
  19. Air_Boss
    4,256
    1,195
    New Yawk
    TPMS battery life is drained primarily proportional to tire rotation (miles driven), less so due to age, though industrial Li-ion battery shelf life tends to be around ten years, and still useful somewhat beyond that.
    DogDaze and wjtracy like this.
  20. rjparker
    11,071
    6,937
    Texas Hill Country
    The sensors have rotation detection which turns them on when first installed and after the car has been started each time.
    Costco does have the ability to program your ecu with their sensors. There is one high end sensor that can be programmed to clone your existing sensor ids.
    DogDaze likes this.
