TPMS Troubleshooting
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TheRuffHouse, Jun 21, 2026.
  1. TheRuffHouse
    TheRuffHouse New Member
    Hohenwald, TN
    Hi all,
    Long time listener, first time caller. I have a 2008 Prius Base, that I replaced the TPMS sensors on. I will admit they're cheap Amazon sensors. The computer can see them and their associated ID numbers and the computer can see their pressures and temperatures. But when I try to scan them for diagnostics, they fail, saying they don't respond. I cannot get the light on the dash to turn off, what am I missing here?
  2. Brian1954
    Brian1954 Senior Member
    2,659
    1,060
    South Central PA, USA
    What computer are you talking about?
    What are you using to scan the TPMS sensors?
  3. TheRuffHouse
    Hohenwald, TN
    I took the car to Discount Tire and they scanned the sensors and "loaded" them into the TPMS Computer. I took a picture of the sensor IDs from their scanner.
    I am using an Autel MaxiAP200 Bluetooth OBD Scanner. I don't know exactly what module of the car I'm in when I read the data. Before I had the sensors installed, the Tire Pressure would read "0" or "-" in every corner. After having the sensors installed, they read the pressure and temperature, but it's odd to me that the light is still on. If I open the TPMS function (which I'm assuming is the TPMS module), it doesn't show any faults. Not sure what is happening here.
  4. pasadena_commut
    pasadena_commut Senior Member
    3,011
    933
    Southern California
    Each sensor has a low pressure setting. For the sake of argument, let's say it should be 27 psi but is set to 35 psi on at least one of yours. If that tire's pressure was 34 psi it would turn on the tpms light. So you need to be sure all those low pressure settings are appropriate. I know where that is in Techstream, presumably it is somewhere in the braking section for the AP200 too. In theory you could set that low limit different for the front than the back, and only a few pounds less than the optimal tire pressure, but it isn't a great idea because when the tires are rotated one of the tires will probably be out of range. Maybe use 28 or 29 psi on all tires. 30 seems awfully close to 32 but I suppose if one kept religiously on top of tire pressure it would be OK. 31 is just begging for a TPMS light.
    There is also a TPMS reset button under the steering wheel, maybe you need to do that procedure if the lower limits are already OK and the pressures are good.
    #4 pasadena_commut, Jun 22, 2026
  5. Brian1954
    2,659
    1,060
    I will take you through this troubleshooting one step at a time.
    When you turn the car on (Ready),
    1. does the tire pressure warning light flash on/off for 30 to 60 seconds, and then the light stays on.
    OR
    2. does the tire pressure warning light come on without flashing?
  6. TheRuffHouse
    Hohenwald, TN
    I was able to figure this out. I ran live data and realized if the car sees the live data from the TPMS, it must be reading them. My OBD scanner was displaying in kPa, and that's when I realized I could change the units. I changed the units to PSI and saw that the "low parameter" of the FR was 16psi and the "low parameter" of the RR was set to 55psi. No idea how they got this way. So I set all the tire pressures to door sticker, and reset the tire pressure by pushing and holding "set tire" for 3 flashes. I then drove for about 2 minutes and the lights cleared.
    Brian1954 likes this.
  7. pasadena_commut
    3,011
    933
    Southern California
    Did you set the the low parameter to something reasonable too?
