TPMS with Torque Pro? Any figure this out?
Discussion in 'Gen 3 Prius Technical Discussion' started by Jeffrimerman, Jun 9, 2018.
  1. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    I think the only way is with the techstream software and an old laptop. Unless something changed I think it only runs on windows xp. Maybe there is new software out there. It was all free for me. Maybe an old laptop at the thrift store.
  2. fuzzy1
    10,707
    Getting the IDs from the sensors requires a radio receiver tuned to this purpose. No software phone app, by itself, can perform this hardware function. That "tire assistant" reads out whatever IDs are registered in the car, not any transmitted IDs directly from new or different tire sensors.
    You can buy TPMS equipment that will read the sensor IDs and data directly from the tire sensor, but it will have a 3-digit price tag, not 2 digits. I have two older ATEQ devices (sensor reader, and car programmer) for this function, but there are newer / better / cheaper products available.
  3. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    Sorry I should have read more. I see they need the IDs. I bought some used sensors so I wrote them down. I wonder if a tire place will charge a minimal fee to pop the tire off so it can be written down then put back on.
  4. fuzzy1
    10,707
    It would be much faster and cheaper and less intrusive for them to just use their RF tools to read the IDs through the sidewalls. When I missplaced the IDs on a seasonal set I bought, the same shop re-read and reprogrammed them in for free the next year. All done in maybe a couple minutes. Then I made very sure to properly re-read them out from the car to make a saved copy ...
    ... and while filing that copy, I found the missing original. :mad:
    ASRDogman likes this.
  5. gromittoo
    gromittoo Active Member
    719
    288
    philadelphia
    2013 Prius v wagon
    So I should make friends with someone who owns one of these three digit price-tag tools first, to get the IDs of all of the wheels. Then I should purchase Techstream and a cable to enter those IDs into the TPMS module.
    That is why sears wanted so much to change the TPMS IDs stored in the TPMS module.
    American cars can be made to "Re-learn" the sensors. You put the car into "re-learn" mode and you use a $13 tool.that sends an RF pulse into the TPMS sensor through the sidewall. The TPMS sensor replies with a signal that the car understands that contains, and the horn beeps to confirm that the pulse was received. Takes about a minute to do.
    According to a Youtube video I watched: the procedure on a Toyota is similar, but the tool costs $869, and the TPMS IDs get stored in the tool, istead of directly read by the car. After you pulse the four t you plug the tool into the ODBII port, and it writes the new IDs into the TPMS module. The video show it taking 30 seconds with the expensive tool.
  6. fuzzy1
    10,707
    This seems to be the norm on U.S.-based brands, but not on Asian brands.
    The price you quote is for just one specific model. There are many others from various makers at various price points, depending on your shop or home needs and wants. You should be able to find something for around a couple hundred now, and they will work on most car brands, not just on a single brand. My ATEQs do both my Toyota and Subaru, and cost about $350 for the reader-programmer pair at that time. If you otherwise already knew the IDs, then the programmer only, for $150, was sufficient. But better and cheaper products are available now.
    The first time I needed TPMS ID reprogramming, the nearest Les Schwab tire shop was charging $20 for this service for walk-in customers not buying other products or services. But then they balked when the vendor updating their programmer database hadn't yet caught up to my model year, so I had to go pay 3X that at the car dealership. By the second time, I had acquired the tools, so have never paid for such service again. And with two TPMS cars in the household needing twice-yearly seasonal swaps, even those overpriced and outdated ATEQ tools have long since paid for themselves.
  7. gromittoo
    719
    288
    philadelphia
    2013 Prius v wagon
    Current Techstream definitely runs on Windows 10. I bought it on Amazon July 2019, but I never got the Techstream installation to work.
  8. Attila Fekete
    Attila Fekete Member
    164
    59
    Budapest, Hungary
    I have Techstream running on Win10 64 bit version perfectly.
    No issue with Techstream itself, but you need to have proper driver for the “cable”.
    (I have not even tried the one provided on the CD.)
  9. KonJarek
    KonJarek New Member
    Poland
    Yes, Torque Pro can do it, at least for 3 first tires (I didn't figure out yet how to get data from second frame and only 3 tires are in the first frame):
    Header: 750
    pressure PID: 2130
    temperature PID: 2116
    start codes: atcea2a\natta2a
    stop code: atcea
    pressure equation (X=A, B or C depending of tire number): X*0,0172-0,4829
    temperature equation (X=A, B or C depending of tire number): X-40
    For the last tire it's necessary to use flow control to get data from CAN, I hope that it will be possible to merge both frames and extract byte with value for 4th (and possibly 5th) tire. I hope anyone have solution for that.
  10. dreze00
    dreze00 New Member
    LA
    Hello, thanks for this info. Would you mind taking a screen shot of your custom PID entry? I have added a few custom ones, but they were basic ones like the HV battery fan speed.
    Is the pressure start code atcea2a? Or atcea2a\natta2a? Plus I don't understand the equation. is it A*0,0172-0,4829 written exactly like this on the equation line?
    Thanks for your help.
  11. kellogs
    kellogs New Member
    Manitowoc
    So, nowadays, is there any stand alone solution to get those pressure values at eye level ?
  12. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    Autel AP200 reads data and can write sensor numbers.
    Brian1954 likes this.
  13. ChapmanF
    19,020
    If the goal is to simply display the four pressures while driving, I'm sure a ScanGauge can do it. The original ScanGauge II could not, then they announced a firmware upgrade for it that allows showing the tire pressures. I've never gotten around to sending mine in for the update. They have a newer ScanGauge III out with more of a smartphone-like display (SG II was just a two-line text LCD) and if it can't I'd be surprised.
  14. kellogs
    kellogs New Member
    Manitowoc
