TRAC works and works well!!
Discussion in 'Gen 3 Prius Main Forum' started by Tideland Prius, Sep 26, 2009.
  1. qbee42
    qbee42 My other car is a boat
    18,058
    3,082
    Northern Michigan
    The rear end whipping around comes from the rear wheels locking, not the front. As long as the rear wheels continue to turn, they will supply directional stability. When the front wheels lock, a car will plow along mostly straight ahead. It was common for the rear to lock first because of the lack of weight in back, although, as you point out, an equalization system attempted to put most of the braking force up front. Ideally the front and rear would lock at exactly the same time.
    Tom
  2. Tideland Prius
    16,684
    Then you'd get a 4-wheel power slide lol... that may or may not be a good thing.
  3. qbee42
    18,058
    3,082
    Northern Michigan
    I used to get those in my Jeep C-J5. I'd goose it around a snowy corner in 4 wheel drive and let it slide; ease off the gas and off she went. Once in awhile I would forget that I was in 2 wheel drive and bad things would happen. That short wheel base would spin very fast.
    Tom
  4. Tideland Prius
    16,684
    hee hee hee.
