Traced physical problems back to car
Discussion in 'Prius c Main Forum' started by Mr. Man, Apr 11, 2021.
  1. Elektroingenieur
    2,515
    3,288
    Three Touring
    There are inspection procedures in the Repair Manual (more info) for some of the suspension components, but you may need a vehicle lift. You can test the front and rear shock absorbers without any special equipment, however: Toyota says to “Compress and extend the shock absorber rod 4 times or more,” with the standard result that “There is no abnormal resistance or sound.”
    Here’s a video showing this done as part of the Toyota Express Maintenance process:
    Front (3:35):
    Rear (4:27):
    Mr. Man likes this.
  2. Mr. Man
    Mr. Man Junior Member
    89
    Chicago
    Thanks! I’ll look into this stuff.
    Elektroingenieur likes this.
  3. Mr. Man
    89
    Chicago
    I inherited a memory foam seat cushion today. Just wondering, should I be focusing on one which has some sort of back support? Or is just a seat cushion enough?
  4. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    ^ That's a question best answered by your doctor. Did you ever go in for a diagnosis? That thumb thing I had is 100% cured now. I don't wear a brace anymore and my hand is back to full strength.
    But none of that started until I took the step of getting in front of a doctor who could tell me what the actual root problem was.
    fuzzy1 likes this.
  5. Mr. Man
    89
    Chicago
    What exactly does that entail? What kind of doctor?
    I just saw my doctor for a checkup and he advised about how to tend to the piriformis - says many patients have this problem - but he didn't exactly examine the injury.
  6. Mr. Man
    89
    Chicago
    thank you btw
  7. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    I just went to my regular GP. I haven't even been using this one very long.
    He ran me through a series of tests, mostly just manipulating my hand probing for painful movements. It only took a few minutes, and he told me he saw a case like mine about every 3 weeks.
    Once I knew what it was, it was easy to learn exercises to rebuild strength and get the right kind of wrist brace to keep it from getting inflamed until everything was back in shape. Of course I still had to buckle down and you know, do the exercises and stretches and stuff... but it really wasn't bad.
    I don't know anything about problems of the piriformis, but I'm happy to hear that you've talked to your doctor about it to get some proper guidance.
    Mr. Man likes this.
  8. fuzzy1
    10,713
    Mine was answered by the PT therapist that my primary care practitioner referred me to.
    A generic inherited cushion is unlikely to be a correct fit for a particular patient's problem.
  9. Mr. Man
    89
    Chicago
    Ha well perhaps. I think it’s pretty decent. The brand is called everlasting comfort. The things I inherit from my parents tend to be pretty good quality.
    I don’t think I have the money to see a physical therapist at the moment but I would certainly like to. Looking into it.
  10. Mr. Man
    89
    Chicago
    If anybody knows a good brand of this cushion for the car for people with this issue, that would be appreciated.
  11. fuzzy1
    10,713
    The issue here isn't quality, it is fit to your particular issue.
  12. Mr. Man
    89
    Chicago
    Thanks very much, I will be currently looking into finally getting a seat cushion that will address this. You said you had already done this - I don't suppose you have a recommendation?
  13. Mr. Man
    89
    Chicago
    Call me crazy, but I was wondering if there would be any value in trying to add some padding to the accelerator and the brake. Is it possible that some damage to my legs or lower back could be from vibrations in those pedals, or in my braking in general?
  14. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    Okay, you're crazy.
    Padding the pedals? Just try different shoes if you want to test that theory. Way easier and much less likely to cause an accident.
  15. Danny13pruisc3
    175
    28
    maryland
    try different pillows and cushions.. doesn't exactly have to be memory foam.. I do a lot of driving for hours doing deliveries out of state..
    also the wear and tear on your seat from previous owners might have diminished the cushion that's there.. or even yourself if you're heavy.
    As a cheap option for pillows you might want to check garage sales, ebay, and thrifts stores.. i scored one from a handicapped chair in a thrift store for like 3 bux.. those things were designed to be sat on all day.. memory foam might not be strong enough.
  16. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    I thought Uber packed it up when the courts decided you have to be a W4 employee, not an 1099
