Traction battery codes, now wont move
Discussion in 'Prius v Technical Discussion' started by Sunny Dis(position), Apr 5, 2023.
  1. Sunny Dis(position)
    Sunny Dis(position) New Member
    Tenn
    Greetings everyone,
    Long term lurker , 2012 Prius V trim 5 , 164,000 miles, we are second owner. Began throwing codes 3 months ago- P0A7F and P0A80, bought and installed Dr Prius App( Hooray), reset codes and researched replacement options. Settled on Project Lithium option but delayed just long enough for them to sell out. Awaiting new supply. New 12 AGM starter battery one year ago.
    Thought it was smart to pull cover off traction battery and see level of corrosion on the connections--looks moderate--put back together and now full panel of flashing lights and wont come out of Park or Neutral.
    Now 3 codes P0A7F, P0A80, and P3015P0A0D. Battery monitor shows SOC 0%( maybe I did'nt get the orange fuse disconnect back correctly?) and one battery pack that has been looking suspect all along #5 - 14.21. Most packs are 15.26-15.43
    Did I mess up? Would like to be able to drive to local mechanic who will help me swap the traction battery when I can get one,
    Thanks
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,974
    4,716
    Texas Hill Country
  3. ChapmanF
    15,614
    Yup, that's what P0A0D means. (Well, it means the safety interlock circuit, which also includes covers on the inverter under the hood, but if nobody fooled with those, it's normally going to be the orange plug.)
  4. Sunny Dis(position)
    Tenn
    Thank you both,
    That #2 push did the trick. Up and moving now
    Air_Boss likes this.
  5. Tim Jones
    Tim Jones Senior Member
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    The 12 volt battery does not start the car. The traction battery does that.
  6. Tim Jones
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    I never had that problem... seen way to many videos before I messed with my traction battery
